Simple post raises error codes -312/-400 using Firebird 3.0
FredFFI think it's not right to force FB3's end-user to make PK if it was not required for FB 2.1. You do not know if it is related to FB version or to something else. 100% of succumbed persons were seen at least once eating cucumbers. Let's now induce cucumbers are poison. ... |
| 27.07.2017, 11:47 |
Arioch, I added PK to table - the same as unique index - and it's working for FB 3. I just need to set property in Delphi TFDTable UpdateOptions upWhereKeyOnly and set ProviderFlags = [pfInUpdate,pfInWhere, pfInKey ] for PK fields. ... |
| 27.07.2017, 18:58 |
FredFFand it's working for FB 3. it's working for FireDAC. Firebird does not need PK, Unique, and your database itself. :-) p.s. unique is not a PK. It's an "alternate key", in addition to PK. ... |
| 27.07.2017, 19:13 |
FredFF, also I need to add that in Firebird, and in Interbase, there are none differences of how UNIQUE and PK works, at least since 1994. Syntax and behavior is the same. ... |
| 27.07.2017, 19:16 |
FredFF> I added PK to table - the same as unique index - and it's working for FB 3. Саш, я ж говорил - наподсказываешь ему щас. Как пить дать, нашу мову разумеет, но виду не кажет. Posted via ActualForum NNTP Server 1.5 ... |
| 27.07.2017, 19:53 |
Гаджимурадов Рустам, translate.ru и google.translate никто не отменял а еще раньше был какой-то сайт, который полная копия форума, пропущенная через переводчик ... |
| 28.07.2017, 17:00 |
kdvthere are none differences of how UNIQUE and PK works, at least since 1994 Really? what about NULLs ? ... |
| 28.07.2017, 17:01 |
AriochReally? what about NULLs ? this is one of exceptions, that can be ignored in this topic. ... |
| 28.07.2017, 17:23 |
Arioch, I don't need translator. Spasibo za pomosch. To be compatible with FireDAC for FB3 I have to create PK for each table. Otherwise new/edit record functioning is not working. PS Delphi is not supporting FB 3 ... |
| 28.07.2017, 18:41 |
FredFF> I have to create PK for each table. Nice. Even if it would work without it. > Otherwise new/edit record functioning is not working. That's not true, actually. Client side just need to know which fields are in PK. > PS Delphi is not supporting FB 3 What?! FireDAC supports, FIBPlus supports, IBDAC/UniDAC supports. And I'm pretty syre there are other libs with FB3 supports (full or partial). Posted via ActualForum NNTP Server 1.5 ... |
| 28.07.2017, 19:22 |
FredFFDelphi is not supporting FB 3 firebird 3 have old client API and new API. New API not used by any components, but old api compatible with all previous Firebird versions, and InterBase. ... |
| 28.07.2017, 20:57 |
start [/forum/topic.php?fid=40&gotonew=1&tid=1561480]: |
56ms |
43ms |
| others: | 245ms |
| total: | 391ms |
