Проблемы апплета из документации по 8i с JRE 1.4.1_02-b06
Сабж. Под виндами не запускается апплет OraInfoNav при установленной Sun JRE 1.4.1_02-b06. Во всяком случае, тот, который идёт с документацией по 8.1.7. Никто не сталкивался/успешно решал? ... |
| 14.04.2003, 15:40 |
Да, блин, забыл самое главное: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. ... |
| 14.04.2003, 15:41 |
Thread Status: Closed From: Philip Bondi 15-Aug-02 22:56 Subject: Oracle Documentation Library gets NULL POINTER EXCEPTION RDBMS Version: 8.1.7 Operating System and Version: Windows 2000 Error Number (if applicable): Product (i.e. SQL*Loader, Import, etc.): Oracle Documentation Library Product Version: 8.1.7 Oracle Documentation Library gets NULL POINTER EXCEPTION Hello to all: Our Java developers have an alternative version of the JRE installed. Therefore, when they install and run the Oracle Documentation Library it does not work. The "Tree - Oracle Information Navigator" window never appears for them. If they opent their Java console in their system tray, they see this stack trace. Anyone know how to fix this problem? The developers need to be able to search the docs! java.lang.NullPointerException at oracle.ewt.lwAWT.BufferedFrame.getFill(BufferedFrame.java:415) at oracle.ewt.lwAWT.BufferedFrame.reshape(BufferedFrame.java:843) at java.awt.Component.setBounds(Unknown Source) at java.awt.Component.move(Unknown Source) at java.awt.Component.setLocation(Unknown Source) at java.awt.Window.init(Unknown Source) at java.awt.Window.<init>(Unknown Source) at java.awt.Frame.<init>(Unknown Source) at oracle.ewt.popup.PopupFrame.<init>(PopupFrame.java:48) at oracle.ewt.lwAWT.BufferedFrame.<init>(BufferedFrame.java:93) at oracle.odp.Search.SearchFrame.<init>(SearchFrame.java:229) at OraInfoNav.init(OraInfoNav.java:300) at sun.applet.AppletPanel.run(Unknown Source) at java.lang.Thread.run(Unknown Source) From: Oracle, Kalpana Malligere 16-Aug-02 12:45 Subject: Re : Oracle Documentation Library gets NULL POINTER EXCEPTION Hello, Options are to use the same JRE version that comes along on the CD or could refer to the documentation section in Metalink, toc tech docs, dataserver library. The documentation is also available at either websites of technet.oracle.com or docs.oracle.com. Thanks! Kalpana Oracle Technical Support ... |
| 14.04.2003, 16:40 |
start [/forum/topic.php?desktop=1&fid=52&tid=1990997]: |
200ms |
38ms |
| others: | 236ms |
| total: | 526ms |
