ошибка ORA-12535, помогите!
Может кто-нибудь подскажет в чем-дело? В один прекрасный день пропал connect к базе на собственном компе при этом connect к другим базам на других компьютерах в сети есть! У меня стоит Windows XP Pro, Oracle 9i Server. tnsping тоже не проходит: >tnsping smartsaf TNS Ping Utility for 32-bit Windows: Version 9.2.0.1.0 - Production on 17-BAL-2005 14:18:44 Copyright (c) 1997 Oracle Corporation. All rights reserved. Used parameter files: c:\progra~1\oracle\ora92\network\admin\sqlnet.ora Used TNSNAMES adapter to resolve the alias Attempting to contact (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = SI PC)(PORT = 1521))) (CONNECT_DATA = (SERVER = DEDICATED) (SERVICE_NAME = SmartSaf))) TNS-12535: TNS:operation timed out В trace log: *********************************************************************** Fatal NI connect error 12535, connecting to: (DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=SIPC)(PORT=1521))(CONNECT_DATA=(SERVER=DEDICATED)(SERVICE_NAME=SmartSaf)(CID=(PROGRAM=C:\Program Files\Oracle\ora92\bin\sqlplusw.exe)(HOST=SIPC)(USER=SergejusI)))) VERSION INFORMATION: TNS for 32-bit Windows: Version 9.2.0.1.0 - Production Windows NT TCP/IP NT Protocol Adapter for 32-bit Windows: Version 9.2.0.1.0 - Production Time: 15-BAL-2005 13:29:44 Tracing to file: /tmp/tmp/\cli_4364_1.trc Tns error struct: nr err code: 0 ns main err code: 12535 TNS-12535: TNS:operation timed out ns secondary err code: 12560 nt main err code: 505 TNS-00505: Operation timed out nt secondary err code: 60 nt OS err code: 0 Что случилось, что делать? ... |
| 17.04.2005, 15:30:14 |
В дополнение еще log tnsping: TNS Ping Utility for 32-bit Windows: Version 9.2.0.1.0 - Production on 17-BAL-2005 14:18:44 Copyright (c) 1997 Oracle Corporation. All rights reserved. --- TRACE CONFIGURATION INFORMATION FOLLOWS --- New trace stream is /tmp/tmp\tnsping.trc New trace level is 16 --- TRACE CONFIGURATION INFORMATION ENDS --- --- PARAMETER SOURCE INFORMATION FOLLOWS --- Attempted load of system pfile source c:\progra~1\oracle\ora92\network\admin\sqlnet.ora Parameter source loaded successfully -> PARAMETER TABLE LOAD RESULTS FOLLOW <- Successful parameter table load -> PARAMETER TABLE HAS THE FOLLOWING CONTENTS <- TNSPING.TRACE_LEVEL = 16 TRACE_LEVEL_CLIENT = 16 TRACE_DIRECTORY_CLIENT = /tmp/tmp TNSPING.TRACE_DIRECTORY = /tmp/tmp TRACE_UNIQUE_CLIENT = yes TRACE_FILE_CLIENT = cli.trc LOG_FILE_CLIENT = sqlnet.log LOG_DIRECTORY_CLIENT = /tmp/tmp --- PARAMETER SOURCE INFORMATION ENDS --- --- LOG CONFIGURATION INFORMATION FOLLOWS --- Log stream will be "standard output" Log stream validation not requested --- LOG CONFIGURATION INFORMATION ENDS --- nnfun2awanm: entry nnfgiinit: entry nnftboot: entry nnftboot: exit nnfoboot: entry nnfoboot: exit nnfoboot: entry nnfoboot: exit nnfhboot: entry nnfhboot: exit nnflcls: entry nnflcls: exit nncpcin_maybe_init: first request sent to name server will have ID 0 nncpcin_maybe_init: initial retry timeout for all name servers is 1500 csecs nncpcin_maybe_init: max request retries per name server is 1 nngsini_init_streams: initializing stream subsystem, cache size is 10 nngtini_init_msg: initializing PDU subsystem, initial pool size is 2 nncpcin_maybe_init: default name server domain is [root] nnfun2a: entry nlolgobj: entry nnfgrne: entry nnfgrne: Installing read path nnfgsrsp: entry nnfgsrsp: Obtaining path parameter from names.directory_path or native_names.directory_path nnfgsrsp: Parmeter names.directory_path not found, setting path to compiled in default nnfgspd: entry nnfgspd: setting element DCE nnfgspd: setting element CDS nnfgspd: setting element TNSNAMES nnfgspd: setting element ONAMES nnfgspd: setting element ONRS nnfgspd: setting element HOSTNAME nnfgspd: setting element LDAP nnfgspd: Path set nnfgspd: exit nnfgrne: Going though read path adapters nnfgrne: Switching to DCE adapter nnfgrne: Original name: smartsaf nnfgrne: Name did not qualify, skipping to next adapter nnfgrne: Switching to CDS adapter nnfgrne: Original name: smartsaf nnfgrne: Name did not qualify, skipping to next adapter nnfgrne: Switching to TNSNAMES adapter nnfgrne: Original name: smartsaf nnftinit: entry nnftinit: Tnsnames refresh interval is 0 nlpaxini: entry nlpaxini: exit nnftmlf_make_local_addrfile: entry nnftmlf_make_local_addrfile: construction of local names file failed nnftmlf_make_local_addrfile: exit nlpaxini: entry nlpaxini: exit nnftmlf_make_system_addrfile: entry nnftmlf_make_system_addrfile: system names file is c:\progra~1\oracle\ora92\network\admin\tnsnames.ora nnftmlf_make_system_addrfile: exit nnftinit: exit nnftqnm: entry nnfcagmd: entry nnfcagmd: Attempting to find metadata for type a.smd nnfcagmd: Attribute name a.smd is a predefined meta type, syntax is 4. nnfcagmd: exit nnfttran: entry --- c:\progra~1\oracle\ora92\network\admin\tnsnames.ora TABLE HAS THE FOLLOWING CONTENTS --- JXFS2.OFFICE.5CI.LT = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = dance)(PORT = 1521))) (CONNECT_DATA = (SERVICE_NAME = jxfs2))) INST1_HTTP = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = SIPC)(PORT = 1521))) (CONNECT_DATA = (SERVER = SHARED) (SERVICE_NAME = MODOSE) (PRESENTATION = http://HRService))) JXFS = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = dance)(PORT = 1521))) (CONNECT_DATA = (SERVICE_NAME = jxfs))) SMARTSAF = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = SIPC)(PORT = 1521))) (CONNECT_DATA = (SERVER = DEDICATED) (SERVICE_NAME = SmartSaf))) JXFS2 = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = dance)(PORT = 1521))) (CONNECT_DATA = (SERVICE_NAME = cebit))) EXTPROC_CONNECTION_DATA.OFFICE.5CI.LT = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC0))) (CONNECT_DATA = (SID = PLSExtProc) (PRESENTATION = RO))) SMARTSAF.OFFICE.5CI.LT = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = sipc)(PORT = 1521))) (CONNECT_DATA = (SERVICE_NAME = smartsaf))) --- END c:\progra~1\oracle\ora92\network\admin\tnsnames.ora TABLE --- nnfttran: exit nnfttran: entry nnftqnm: Using tnsnames.ora address (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = SIPC)(PORT = 1521))) (CONNECT_DATA = (SERVER = DEDICATED) (SERVICE_NAME = SmartSaf))) for name smartsaf nnfcraa: entry nnfgrne: Name successfully queried nnfgrne: Obtaining answer records for smartsaf nnftans: entry nnfcran: entry nnfcran: 64 rrs requested, 1 remaining, 1 total nnfcran: exit nnfgrne: exit nlolgserv: entry nnfggav: entry nnfggav: exit nnfgfrm: entry nnfgfrm: exit nlolgserv: exit nlolgobj: exit nlolfmem: entry nlolfmem: exit nnfun2awanm: Getting the path of sqlnet.ora nnfun2awanm: Getting the adapter name nnfun2awanm: exit nscall: entry nsmal: entry nsmal: 164 bytes at 0xb6fd00 nsmal: normal exit nscall: connecting... nladini: entry nladini: exit nladget: entry nladget: exit nsc2addr: entry nttbnd2addr: entry nttgetport: entry nttgetport: port resolved to 1521 nttgetport: exit nttbnd2addr: looking up IP addr for host: SIPC nttbnd2addr: exit nsc2addr: normal exit nsopen: entry nsmal: entry nsmal: 492 bytes at 0xbb85f0 nsmal: normal exit nsopenmplx: entry nsmal: entry nsmal: 2348 bytes at 0xbb87e8 nsmal: normal exit nsopenmplx: normal exit nsopen: opening transport... nttcon: entry nttcon: toc = 1 nttcnp: entry ntvlin: entry ntvllt: entry ntvllt: tcp.validnode_checking not turned on ntvllt: exit ntvlin: exit nttcnp: Validnode Table IN use; err 0x0 nttcnp: creating a socket. nttcnp: exit nttcni: entry nttcni: trying to connect to socket 1828. ntt2err: entry ntt2err: soc 1828 error - operation=1, ntresnt[0]=505, ntresnt[1]=60, ntresnt[2]=0 ntt2err: exit nttcni: exit nttcon: exit nserror: entry nserror: nsres: id=0, op=65, ns=12535, ns2=12560; nt[0]=505, nt[1]=60, nt[2]=0; ora[0]=0, ora[1]=0, ora[2]=0 nsopen: unable to open transport nsbfr: entry nsbfr: normal exit nsbfr: entry nsbfr: normal exit nsmfr: entry nsmfr: 2348 bytes at 0xbb87e8 nsmfr: normal exit nsmfr: entry nsmfr: 492 bytes at 0xbb85f0 nsmfr: normal exit nsopen: error exit nscall: error exit nscall: entry nscall: connecting... nsclose: entry nsclose: normal exit nladget: entry nladget: exit nsmfr: entry nsmfr: 164 bytes at 0xb6fd00 nsmfr: normal exit nladtrm: entry nladtrm: exit nscall: error exit ... |
| 17.04.2005, 15:43:59 |
М.б., какой-нибудь пакетный фильтр поставил? А с других машин к тебе могут законнектиться? ... |
| 17.04.2005, 16:23:44 |
Нет, пакетного фильтра не ставил. С других компов при коннекте ко мне та же ошибка, хотя раньше все работали. ... |
| 17.04.2005, 16:30:16 |
Я посмотрел tnsping trace log к другому серверу в сетке (к которому есть коннект): все похоже, а разница начинается при открытии socket'a У меня : trying to connect to socket 1828. ntt2err: entry ntt2err: soc 1828 error А к другому: nttcni: trying to connect to socket 1824. nttcni: connected on ipaddr 192.168.92.84 nttcni: exit nttcon: NT layer TCP/IP connection has been established. То есть у меня идет неудачная попытка открытия socket'a и с другим номером Где-то здесь загводка, похоже ... |
| 17.04.2005, 16:39:01 |
Ход мыслей правильный, надо копать, что за код ошибки возвращает маздайка. Номер сокета значения не имеет. ... |
| 17.04.2005, 16:45:30 |
Я так понимаю, возвращает ошибку: ntt2err: soc 1828 error - operation=1, ntresnt[0]=505, ntresnt[1]=60, ntresnt[2]=0 ntt2err: exit nttcni: exit nttcon: exit nserror: entry nserror: nsres: id=0, op=65, ns=12535, ns2=12560; nt[0]=505, nt[1]=60, nt[2]=0; ora[0]=0, ora[1]=0, ora[2]=0 nsopen: unable to open transport ... |
| 17.04.2005, 16:58:02 |
похоже у тебя firewall включен попробуй в регистрах HKEY_LOCAL_MACHINE\SOFTWARE\ORACLE\HOME<X> добавить USE_SHARED_SOCKET=TRUE ... |
| 18.04.2005, 09:16:02 |
обезательно перезагрузить операционку ... |
| 18.04.2005, 09:42:46 |
Ничего не изменилось. ... |
| 18.04.2005, 12:03:17 |
так выглядет регистр ? ... |
| 18.04.2005, 12:35:27 |
Да, вообщем-то ... |
| 18.04.2005, 13:08:10 |
а под каким портом листенер слушает ? если firewall включен то открой тот порт ... |
| 18.04.2005, 13:21:23 |
Да, порт 1521 открыт. И через него коннект с другими серверами в сетке идет. Пытался и отключать firewall, все то же. ... |
| 18.04.2005, 14:57:57 |
кинь содержание LISTENER.ORA и TNSNAMES.ORA ... |
| 18.04.2005, 15:20:41 |
Вот: # LISTENER.ORA Network Configuration File: c:\progra~1\oracle\ora92\network\admin\listener.ora # Generated by Oracle configuration tools. LISTENER = (DESCRIPTION_LIST = (DESCRIPTION =(CONNECT_TIMEOUT=30) (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = SIPC)(PORT = 1521)) ) (ADDRESS_LIST = (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC0)) ) ) ) SID_LIST_LISTENER = (SID_LIST = (SID_DESC = (SID_NAME = PLSExtProc) (ORACLE_HOME = c:\progra~1\oracle\ora92) (PROGRAM = extproc) ) (SID_DESC = (GLOBAL_DBNAME = SmartSaf) (ORACLE_HOME = c:\progra~1\oracle\ora92) (SID_NAME = SmartSaf) ) ) и вот: # TNSNAMES.ORA Network Configuration File: c:\progra~1\oracle\ora92\network\admin\tnsnames.ora # Generated by Oracle configuration tools. SMARTSAF = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = SIPC)(PORT = 1521)) ) (CONNECT_DATA = (SERVER = DEDICATED) (SERVICE_NAME = SmartSaf) ) ) JXFS2 = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = dance)(PORT = 1521)) ) (CONNECT_DATA = (SERVICE_NAME = cebit) ) ) EXTPROC_CONNECTION_DATA.xxx.yyy.zzz = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC0)) ) (CONNECT_DATA = (SID = PLSExtProc) (PRESENTATION = RO) ) ) ... |
| 18.04.2005, 15:27:32 |
а у тебя нету Etrust software инсталировано ? если есть, выключи и тогда попробуй ... |
| 18.04.2005, 15:52:05 |
Это антивирусная программа, да? То, таковой нет. ... |
| 18.04.2005, 16:11:30 |
Снес всю антивирусную защиту и заработало!!! Администраторы сети централизованно устанавливали везде свой антивирусный ... и после этого и начались проблемы ... |
| 18.04.2005, 19:37:28 |
Какое антивирусное ПО стояло? как победили потом эту проблему? ... |
| 28.12.2009, 09:06:27 |
Eras, спасибо :-) ... |
| 19.09.2018, 15:41:44 |
start [/forum/topic.php?desktop=1&fid=52&tid=1883439]: |
34ms |
| others: | 198ms |
| total: | 281ms |
