XE as CAW
С точки зрения Licensing можно ли XE БД использовать в качестве Centralized AWR Warehouse ? В Licensing Information указано что у XE нет Diagnostics Pack, но по ней самой и нет необходимости смотреть dba_hist_*. Возможно ли на XE версии накапливать, хранить и обрабатывать снапшоты с других БД? ... |
| 12.10.2021, 17:19:04 |
XE as CAW
Cheese))), Зачем, когда можно EE? https://docs.oracle.com/en/database/oracle/oracle-database/19/dblic/Licensing-Information.html#GUID-75262092-CD86-4B30-A21B-92ECC1C2E130 авторA separate single instance Oracle Database can be installed and used as an infrastructure repository for RMAN, Oracle Enterprise Manager Cloud Control, Automatic Workload Repository (AWR) Warehouse, Global Data Services Catalog, Sharding Catalog, and Grid Infrastructure Management Repository without additional license requirements, provided that all the targets are correctly licensed. It may not be used or deployed for other uses. The infrastructure repositories for RMAN, Oracle Enterprise Manager Cloud Control, AWR Warehouse, Global Data Services Catalog, and Sharding Catalog can be shared in one database, or deployed in separate databases. Enterprise Edition must be used for the infrastructure repository database(s). ... |
| 12.10.2021, 20:05:18 |
start [/forum/topic.php?desktop=1&fid=52&tid=1879827]: |
228ms |
42ms |
| others: | 194ms |
| total: | 509ms |
