Trigger and current_user or computer IP/name (Firebird 3.0)
Код: sql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. My problem: current_user is always SYSDBA, USER_IP is always null. How to get PC name instead of IP address? I have current user logged in Delphi application. How to update current_user value? Thanks, Fred ... |
| 11.01.2019, 00:17 |
Перестань подключаться в embedded режиме. Читай Release Notes. Posted via ActualForum NNTP Server 1.5 ... |
| 11.01.2019, 01:34 |
Dimitry Sibiryakov, I do not use embedded mode - local database access. Thanks, Fred ... |
| 11.01.2019, 02:07 |
I've got host name of computer by using other query: Код: sql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. How can I get user name? We are using our own login system so only apps knows who was login. ... |
| 11.01.2019, 03:01 |
1. Use SRC tag (button) for SQL queries and scripts. 2. Show your connection params/connection string. Posted via ActualForum NNTP Server 1.5 ... |
| 11.01.2019, 09:20 |
On user login you can save his US_NAME: Код: plsql 1. Then you can use: Код: plsql 1. ... |
| 11.01.2019, 10:13 |
FredFF, it is a VERY bad idea to select mon$ within triggers. You may get exponential performance decrease by the number of users. ... |
| 11.01.2019, 10:55 |
FredFFI do not use embedded mode - local database access. Read Release Notes at last. In Firebird 3.0 it IS embedded mode. Posted via ActualForum NNTP Server 1.5 ... |
| 11.01.2019, 13:48 |
FredFFlocal database access. in addition to DS answer need to add, that "local access" is not equal to tcp localhost access. When you do not specify server at the connection string, like server:c:\db\data.fdb or localhost:c:\db\data.gdb this is NOT a tcp connection, So, it is strange to expect IP in mon$attachments (or anywhere) while there is no IP. And, if you use your own login system (all users are logged as SYSDBA or other USER), just pass user name from the client application, that's it. ... |
| 11.01.2019, 14:35 |
start [/forum/topic.php?desktop=1&fid=40&tid=1560846]: |
23ms |
43ms |
| others: | 251ms |
| total: | 357ms |
