Компьютер не видит всю память 3,4 гб. из (всего 7 гб.) ОС Linux 64 разряда
Добрый день! Компьютер не видит всю память 3,4 гб. из (всего 7 гб.) ОС Linux 64 разряда, БИОС сбрасывал на default. Советы - предложения! serku@lpc:~$ inxi -F System: Host: lpc Kernel: 4.9.0-8-amd64 x86_64 (64 bit) Desktop: Cinnamon 3.8.8 Distro: LMDE 3 (cindy) Machine: Device: desktop Mobo: Gigabyte model: EP43-S3L v: x.x BIOS: Award v: F6 date: 07/23/2008 CPU: Quad core Intel Xeon X5450 (-HT-MCP-) cache: 6144 KB clock speeds: max: 3000 MHz 1: 2000 MHz 2: 2000 MHz 3: 2000 MHz 4: 2000 MHz Graphics: Card: NVIDIA GF116 [GeForce GTS 450 Rev. 2] Display Server: X.Org 1.19.2 drivers: nouveau (unloaded: modesetting,fbdev,vesa) Resolution: 1920x1080@60.00hz GLX Renderer: Gallium 0.4 on NVCF GLX Version: 3.0 Mesa 13.0.6 Audio: Card-1 NVIDIA GF116 High Definition Audio Controller driver: snd_hda_intel Card-2 Intel 82801JI (ICH10 Family) HD Audio Controller driver: snd_hda_intel Sound: Advanced Linux Sound Architecture v: k4.9.0-8-amd64 Network: Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169 IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: 00:1f:d0:90:f7:b9 Drives: HDD Total Size: 640.1GB (0.8% used) ID-1: /dev/sda model: WDC_WD6400AAKS size: 640.1GB Partition: ID-1: / size: 202G used: 4.6G (3%) fs: ext4 dev: /dev/sda3 Sensors: System Temperatures: cpu: 41.0C mobo: N/A gpu: 43.0 Fan Speeds (in rpm): cpu: N/A Info: Processes: 193 Uptime: 3 min Memory: 581.9/3389.0MB Client: Shell (bash) inxi: 2.3.5 serku@lpc:~$ sudo inxi -m Memory: Used/Total: 582.6/3389.0MB Array-1 capacity: 8 GB (est) devices: 4 EC: None Device-1: A0 size: 1 GB speed: 800 MHz type: N/A Device-2: A1 size: 2 GB speed: 800 MHz type: N/A Device-3: A2 size: 2 GB speed: 800 MHz type: N/A Device-4: A3 size: 2 GB speed: 800 MHz type: N/A serku@lpc:~$ free total used free shared buff/cache available Mem: 3470328 560004 2412356 25052 497968 2733572 Swap: 0 0 0 ... |
| 12.02.2019, 18:14:49 |
А какая память? По сколько банков памяти на одной стороне? А то в какой-то момент начали клепать память разную для AMD (дешевле) и Intel+AMD (дороже). Контроллер памяти AMD видел все планки нормально, а Intel, только планки, совместимые с ним. В BIOS сколько памяти показывает? ... |
| 13.02.2019, 06:31:56 |
serkuDevice-1: A0 size: 1 GB Device-2: A1 size: 2 GB Device-3: A2 size: 2 GB Device-4: A3 size: 2 GBЯ бы на месте производителей БИОСов поджигал бы комп, когда видел бы такую конфигурацию памяти :-) ... |
| 13.02.2019, 11:32:02 |
alexeyvg,Эмоционально, давай теперь поподробнее!!! ... |
| 13.02.2019, 13:30:57 |
ПК видит все планки памяти физически, о чем в отчете сказано. Проблема либо с дистрибутивом, либо где-то в настройках ОС выключено (не спец по nix системам, это в другой раздел). В качестве маленького шанса: проц серверный на десктопной матери, может в этом подглючивает, биос последний обновить? ... |
| 13.02.2019, 14:01:53 |
serkuЭмоционально, давай теперь поподробнее!!! Банки памяти в 64-х разрядных системах объединяются как минимум по 2. Твоя планка на один гиг не позволяет использовать первый банк, поскольку неспособна объединиться с планкой на два гига. Posted via ActualForum NNTP Server 1.5 ... |
| 13.02.2019, 14:06:39 |
Dimitry Sibiryakov, От производителя зависит 7168 Megabytes Usable Installed Memory Slot 'DIMM0' has 2048 MB Slot 'DIMM1' has 2048 MB Slot 'DIMM2' has 2048 MB Slot 'DIMM3' has 1024 MB ... |
| 13.02.2019, 15:04:31 |
serkualexeyvg,Эмоционально, давай теперь поподробнее!!!По крайней мере, не будет использоваться интерливинг для слотов A0 и A2 И как он вообще будет использоваться, непонятно - может, для всей памяти будет отключён, может, для этих слотов, может, только для 1 Гб Но к исходному вопросу это, скорее всего, не имеет отношения (хотя может ОС от такого сошла с ума?) Смотреть нужно на допустимую организацию памяти для вашей платы и чипсета - далеко не всегда можно просто воткнуть любые модули, и всё. Кстати, ещё не раскрыт вопрос, видит ли всю память BIOS (не модули, а именно какой объём памяти показывается в BIOS) Ещё можно загрузиться с загрузочной флешки, и посмотреть, сколько памяти видно. Ещё одна мысль - вопросы по ОС лучше задать в разделе по этой ОС. По крайней мере, когда убедиттесь, что BIOS/альтернативная ОС видят память ... |
| 13.02.2019, 15:29:02 |
Спасибо всем, сегодня проверю: 1. доступность памяти в Биосе, 2. приведу память к единообразию (особенно по объему), 3. поищу свежую пошивку на БИОС Позже отпишусь по результату! ... |
| 13.02.2019, 15:38:42 |
В дополнение — Windows 10 на 64 разряда, результат тот же 3,4 из 7(Гб). ... |
| 13.02.2019, 15:43:02 |
serkuArray-1 capacity: 8 GB (est) devices: 4 EC: None Device-1: A0 size: 1 GB speed: 800 MHz type: N/A Device-2: A1 size: 2 GB speed: 800 MHz type: N/A Device-3: A2 size: 2 GB speed: 800 MHz type: N/A Device-4: A3 size: 2 GB speed: 800 MHz type: N/A я плохо понимать по-русски, тут написано 8 = 1+2+2+2 ? ... |
| 13.02.2019, 16:39:29 |
serkuВ дополнение — Windows 10 на 64 разряда, результат тот же 3,4 из 7(Гб).Ага, значит, всё таки железо/биос Вот, кстати, инструкция http://download.gigabyte.ru/manual/motherboard_manual_ga-ep43-(d)s3l(r)_e.pdf Там много про память. ... |
| 13.02.2019, 16:42:53 |
авторПо крайней мере, не будет использоваться интерливинг для слотов A0 и A2 Чередование работать будет в стандарте это есть, но разумеется в рамках объема меньшего модуля (но должны быть одинаковые частоты и объемы банков памяти - это уже обязательно) И да, как же жили без канальности памяти раньше - никто не страдал?) авторя плохо понимать по-русски, тут написано 8 = 1+2+2+2 ? В скобках указано est - это сокращенно от estimated (примерно англ.), ну вот создатель данного дистрибутива считает, что примерно это так.. Как маркетологи винчестеров считают, что в их измерении 1000, а не 1024..) ... |
| 13.02.2019, 17:37:47 |
rahzerавторПо крайней мере, не будет использоваться интерливинг для слотов A0 и A2 Чередование работать будет в стандарте это есть, но разумеется в рамках объема меньшего модуляПонятно, спасибо. rahzerно должны быть одинаковые частоты и объемы банков памяти - это уже обязательно)Подозреваю, что у ТС модули набраны со старых компов россыпью, какие там банки/частоты :-) ... |
| 13.02.2019, 17:43:03 |
serku, да не будет так работать. в соседних планках должны стоять модули с одинаковым объемом памяти. Если переставить 1 гиг в А1-А3 комп вообще может не завестись, типа, "памяти нет". кстати, я х.з. как там на этой плате модули чередуются, может быть А0+А1 и А2+А3, а может быть А0+А2 и А1+А3. Должно быть обозначено цветом. ... |
| 13.02.2019, 17:52:19 |
Попробуйте поменять 1ГБ-планку на 2ГБ. Конечно лучше 2 по 4ГБ, но DDR2 таких я не видел - слишком редки. На Али продают, но совместимы только с AMD. Поря бы задуматься об обновлении всей платформы. Новый i3 уделывает такой Xeon - не говоря уже об энергопотреблении, хотя у самого сейчас один комп на 775 сокете с Xeon, но память DDR3. ... |
| 14.02.2019, 10:43:21 |
Memory remap feature в BIOS ... |
| 14.02.2019, 11:51:26 |
Всем привет! Проверил в БИОСе, показывает объем памяти — 3,4 Гб. Думаю проблема в БИОСе, нашел поновее прошивку F8, буду обновлять, а там посмотрим! ... |
| 14.02.2019, 15:40:38 |
serku, да не будет так работать. ... |
| 14.02.2019, 21:03:02 |
1) Проверьте планки памяти по отдельности, чтобы каждая определялась 2) Дальше проверяйте парами все модули, чтобы найти связку, которая не работает 3) Проверьте (ну или можете сюда написать), какие ТТХ каждой планки (вольтаж, частоты и т.п.) Дальше будем думать.. Возможно, 1ГБ модуль не подходит, либо (в некоторых БИОСах) можно отключить режим многоканальности и частоты вручную задать - поиграться этими параметрами. ... |
| 15.02.2019, 07:20:16 |
Добрый день! Проблема была в памяти, заменил модули (2)+(1) Гб. На (1)+(1) от одного производителя, и заработало! Система теперь видит 6 Гб. В Биосе тоже стало показывать 6 Гб. Всем спасибо! ... |
| 15.02.2019, 08:37:17 |
start [/forum/topic.php?desktop=1&fid=30&tid=1528925]: |
198ms |
73ms |
| others: | 240ms |
| total: | 562ms |
