Вопрос по ADO.Net + WPF.
Добрый день, уважаемые коллеги! Вот фрагмент кода... С#: using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.Windows; using System.Windows.Controls; using System.Windows.Data; using System.Windows.Documents; using System.Windows.Input; using System.Windows.Media; using System.Windows.Media.Imaging; using System.Windows.Navigation; using System.Windows.Shapes; using System.Data; using System.Data.SqlClient; namespace workingWithDB { /// <summary> /// Interaction logic for MainWindow.xaml /// </summary> public partial class MainWindow : Window { public MainWindow() { InitializeComponent(); } private void Window_Loaded(object sender, RoutedEventArgs e) { //GridView1.Visible = true; string cs = "user id=user; password=userpassword; server=server.domain.local; initial catalog=PrimeBase; integrated security=false"; SqlConnection sqlc = new SqlConnection(); sqlc.ConnectionString = cs; sqlc.Open(); //Делаем выборку всех записей из БД string sqlq = "select * from logins"; ; SqlCommand sqlcmd = new SqlCommand(sqlq, sqlc); SqlDataAdapter sqlda = new SqlDataAdapter(); sqlda.SelectCommand = sqlcmd; DataSet ds = new DataSet(); sqlda.Fill(ds, "logins"); this.dataGrid1.DataContext = ds; this.listBox1.DataContext = ds; sqlc.Close(); } } } XAML: <Window x:Class="workingWithDB.MainWindow" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" Title="MainWindow" Height="350" Width="525" Loaded="Window_Loaded" xmlns:my="clr-namespace:workingWithDB"> <Grid> <DataGrid AutoGenerateColumns="False" Height="119" HorizontalAlignment="Left" Margin="12,12,0,0" Name="dataGrid1" VerticalAlignment="Top" Width="479" DataContext="{Binding}" /> <ListBox Height="135" HorizontalAlignment="Left" Margin="12,0,0,12" Name="listBox1" VerticalAlignment="Bottom" Width="479" /> </Grid> </Window> Моя цель - убедить элементы dataGrid1 и listBox1 отображать данные из БД PrimeBase...Пока не получается. :-( Очень прошу Вас помочь разобраться в этом вопросе! Заранее спасибо! С уважением. ... |
| 22.07.2010, 13:04:29 |
получилось что путное? ... |
| 28.07.2010, 13:24:15 |
start [/forum/topic.php?desktop=1&fid=21&tid=1442728]: |
50ms |
40ms |
| others: | 215ms |
| total: | 355ms |
