Row set is not bookmarkable ??? ХЛП ПЛЗ !!!
Dim rs_Tbl2 As New ADODB.Recordset Dim cmd As ADODB.Command Dim x As Integer Dim cn1 As ADODB.Connection Set cn1 = New ADODB.Connection With cn1 .ConnectionString = "Provider=SQLOLEDB.1;Integrated Security=SSPI;Persist Security Info=False;Initial Catalog=Northwind;Data Source=Jeck2" '& '_ .Open End With x = 10248 Set cmd = New ADODB.Command With cmd .ActiveConnection = cn1 .CommandText = "CustOrdersDetail" .CommandType = adCmdStoredProc .Parameters.Append .CreateParameter(, adInteger, adParamInput, , x) End With Set rs_Tbl2.Source = cmd.Execute rs_Tbl2.CursorLocation = adUseServer ' или adUseClient rs_Tbl2.CursorType = adOpenStatic ' или adOpenKeyset rs_Tbl2.Open rs_Tbl2.MoveLast rc = rs_Tbl2.RecordCount Set Me.DataGrid1.DataSource = rs_Tbl2 Me.DataGrid1.Refresh Выдает ошибку Row set is not bookmarkable Как преодолеть или сделать по-другому ? ... |
| 18.02.2003, 16:10 |
start [/forum/topic.php?fid=60&gotonew=1&tid=2171414]: |
128ms |
41ms |
| others: | 232ms |
| total: | 445ms |
