Kod dlja otpravki pisma s Access
Privet. Mne dali takoi kod dlja otpravki pisem po pochet s Accessa no ispolnaja jevo v 2 stroke pojevljajetsa oshibka. Mozet kto opesnit shto ne tak? Option Compare Database Private Sub Send_Letters_Click() Dim ola As Outlook.Application Dim itm As Outlook.MailItem Dim DisplayText As String Dim Address As String Dim fname As String Set ola = Outlook.Application Set itm = ola.CreateItem(olMailItem) DisplayText = "Aibo" Address = DisplayText & " <" & HyperlinkPart("aibo@aibo.com", acDisplayText) & ">" itm.Recipients.Add Address itm.Subject = "Testejam mailto" itm.Body = "Joproj?m test?jam mailto" fname = HyperlinkPart("c:\Formulas.txt") itm.Attachments.Add fname itm.Send End Sub ... |
| 23.07.2003, 16:22 |
2 строка это Set itm = ola.CreateItem(olMailItem) ? У меня пошло. Может забыли референс для Outlook ? У себя я , правда, пишу : Dim Outlook As Outlook.Application Dim Mail As MailItem Set Outlook = New Outlook.Application Set Mail = CreateItem(olMailItem) ... |
| 23.07.2003, 16:28 |
A kakoi komandoi mozna zapustit v Accese okno na podobije kak "Oupen fail" v katorom ozna ukazath fail i potom puth k failu i samo nazvanije faila vpisivajetsa v jacheiku atachmenta formi shtobi potom nenuzna samamu pechatath. Tipa C:\My documents\My picture\space.jpg ... |
| 23.07.2003, 17:22 |
start [/forum/topic.php?fid=60&gotonew=1&tid=2171009]: |
31ms |
45ms |
| others: | 238ms |
| total: | 360ms |
