Filter на DAO.Recordset
Необходимо подключиться к таблице Clipper через DAO. Не могу отфильтровать записи(rst.Filter="поле='значение'"). Выводится вся таблица. Это в принципе работает, или я что-то сделал не так? Заранее благодарен. ... |
| 25.07.2003, 15:38 |
Это не Clipper, но может подойдет ? MSDN Filter Property Example This example uses the Filter property to create a new Recordset from an existing Recordset based on a specified condition. The FilterField function is required for this procedure to run. Sub FilterX() Dim dbsNorthwind As Database Dim rstOrders As Recordset Dim intOrders As Integer Dim strCountry As String Dim rstOrdersCountry As Recordset Dim strMessage As String Set dbsNorthwind = OpenDatabase("Northwind.mdb") Set rstOrders = dbsNorthwind.OpenRecordset("Orders", _ dbOpenSnapshot) ' Populate the Recordset. rstOrders.MoveLast intOrders = rstOrders.RecordCount ' Get user input. strCountry = Trim(InputBox( _ "Enter a country to filter on:")) If strCountry <> "" Then ' Open a filtered Recordset object. Set rstOrdersCountry = _ FilterField(rstOrders, "ShipCountry", strCountry) With rstOrdersCountry ' Check RecordCount before populating Recordset; ' otherwise, error may result. If .RecordCount <> 0 Then .MoveLast ' Print number of records for the original ' Recordset object and the filtered Recordset ' object. strMessage = "Orders in original recordset: " & _ vbCr & intOrders & vbCr & _ "Orders in filtered recordset (Country = '" & _ strCountry & "'): " & vbCr & .RecordCount MsgBox strMessage .Close End With End If rstOrders.Close dbsNorthwind.Close End Sub Function FilterField(rstTemp As Recordset, _ strField As String, strFilter As String) As Recordset ' Set a filter on the specified Recordset object and then ' open a new Recordset object. rstTemp.Filter = strField & " = '" & strFilter & "'" Set FilterField = rstTemp.OpenRecordset End Function Note To see the effects of filtering rstOrders, you must set its Filter property, and then open a second Recordset object based on rstOrders. Note When you know the data you want to select, it's usually more efficient to create a Recordset with an SQL statement. This example shows how you can create just one Recordset and obtain records from a particular country. Sub FilterX2() Dim dbsNorthwind As Database Dim rstOrders As Recordset Set dbsNorthwind = OpenDatabase("Northwind.mdb") ' Open a Recordset object that selects records from a ' table based on the shipping country. Set rstOrders = _ dbsNorthwind.OpenRecordset("SELECT * " & _ "FROM Orders WHERE ShipCountry = 'USA'", _ dbOpenSnapshot) rstOrders.Close dbsNorthwind.Close End Sub ... |
| 25.07.2003, 16:14 |
Вдогонку : может забывал после фильтра еще раз открывать курсор ? rstTemp.Filter = strField & " = '" & strFilter & "'" Set FilterField = rstTemp.OpenRecordset ... |
| 25.07.2003, 16:18 |
start [/forum/topic.php?fid=60&gotonew=1&tid=2170999]: |
157ms |
42ms |
| others: | 201ms |
| total: | 438ms |
