форматирование переменной типа DateTime в ASP
Подскажите, пожалуйста, как нужным образом отформатировать переменную типа DateTime в ASP. Нужно: при задании региональных установок типа American получить на выходе строку типа Russian. Насколько я понимаю VB функция Format в ASP неприменима. От функции FormatDateTime тоже мало прока. ... |
| 18.09.2003, 16:59 |
А тебе придеться разбирать Дату и время на части используя стандартные функции, а делее склеивать их как тебе охота! DatePart Function Returns a Variant (Integer) containing the specified part of a given date. Syntax DatePart(interval, date[,firstdayofweek[, firstweekofyear]]) The DatePart function syntax has these named arguments: Part Description interval Required. String expression that is the interval of time you want to return. date Required. Variant (Date) value that you want to evaluate. firstdayofweek Optional. A constant that specifies the first day of the week. If not specified, Sunday is assumed. firstweekofyear Optional. A constant that specifies the first week of the year. If not specified, the first week is assumed to be the week in which January 1 occurs. Settings The interval argument has these settings: Setting Description yyyy Year q Quarter m Month y Day of year d Day w Weekday ww Week h Hour n Minute s Second The firstdayofweek argument has these settings: Constant Value Description vbUseSystem 0 Use the NLS API setting. vbSunday 1 Sunday (default) vbMonday 2 Monday vbTuesday 3 Tuesday vbWednesday 4 Wednesday vbThursday 5 Thursday vbFriday 6 Friday vbSaturday 7 Saturday The firstweekofyear argument has these settings: Constant Value Description vbUseSystem 0 Use the NLS API setting. vbFirstJan1 1 Start with week in which January 1 occurs (default). vbFirstFourDays 2 Start with the first week that has at least four days in the new year. vbFirstFullWeek 3 Start with first full week of the year. Remarks You can use the DatePart function to evaluate a date and return a specific interval of time. For example, you might use DatePart to calculate the day of the week or the current hour. The firstdayofweek argument affects calculations that use the "w" and "ww" interval symbols. If date is a date literal, the specified year becomes a permanent part of that date. However, if date is enclosed in double quotation marks (" "), and you omit the year, the current year is inserted in your code each time the date expression is evaluated. This makes it possible to write code that can be used in different years. Note For date, if the Calendar property setting is Gregorian, the supplied date must be Gregorian. If the calendar is Hijri, the supplied date must be Hijri. The returned date part is in the time period units of the current Arabic calendar. For example, if the current calendar is Hijri and the date part to be returned is the year, the year value is a Hijri year. mahoune ... |
| 19.09.2003, 09:46 |
start [/forum/topic.php?fid=60&gotonew=1&tid=2170745]: |
159ms |
27ms |
| others: | 210ms |
| total: | 436ms |
