VB+Excel: saveAS?
У меня на листе 1 есть кнопка как при помощи этой кнопки вызвать стандартную "микрософт офисную" форму сохранить как? ... |
| 27.01.2004, 08:00:21 |
VB+Excel: saveAS?
См RTFM: Dialog Object Represents a built-in Microsoft Excel dialog box. The Dialog object is a member of the Dialogs collection. The Dialogs collection contains all the built-in dialog boxes in Microsoft Excel. You cannot create a new built-in dialog box or add one to the collection. The only useful thing you can do with a Dialog object is use it with the Show method to display the corresponding dialog box. Using the Dialog Object Use Dialogs(index), where index is a built-in constant identifying the dialog box, to return a single Dialog object. The following example runs the built-in Open dialog box (File menu). The Show method returns True if Microsoft Excel successfully opens a file; it returns False if the user cancels the dialog box. dlgAnswer = Application.Dialogs(xlDialogOpen).Show ... |
| 27.01.2004, 11:29:50 |
start [/forum/topic.php?fid=60&gotonew=1&tid=2170171]: |
184ms |
| others: | 205ms |
| total: | 456ms |
