VB+Access parameterized query
V obshem probleam sv sledueshem kaim brzom mozhno programnim putem sdelatj parametrizirovannij zapros k Access 2000 Dim rsPosition As ADODB.Recordset Set rsPosition = New ADODB.Recordset Dim strSQL As String Dim prm As ADODB.Parameter Dim cmdPosition As ADODB.Command Set cmdPosition = New ADODB.Command rsPosition.LockType = adLockOptimistic rsPosition.CursorType = adOpenDynamic rsPosition.CursorLocation = adUseServer cmdPosition.ActiveConnection = Module1.conAis cmdPosition.CommandType = adCmdText Set prm = cmdPosition.CreateParameter("pos_descr", adChar, adParamInput, 50) cmdPosition.Parameters.Append prm prm.Value = DataCombo1.Text strSQL = "select base_salary from position where position_description=pos_descr" cmdPosition.CommandText = strSQL Set rsPosition = cmdPosition.Execute v rezultate oshibka Too few parametrs expected one ? V cehm mozhet bitj delo ? ... |
| 27.01.2004, 13:01:28 |
Не мучай жопу. Пиши rsPosition.Open "select base_salary from position where position_description=" & x, Module1.conAis, adOpenDynamic, adLockOptimistic ... |
| 27.01.2004, 13:31:48 |
ты запускаешь SQL Statment. А command надо использовать при запуске stored procedures Код можно изменить примерно так, Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. ... |
| 27.01.2004, 13:35:54 |
start [/forum/topic.php?fid=60&gotonew=1&tid=2170168]: |
165ms |
47ms |
| others: | 201ms |
| total: | 461ms |
