DBcombo
Kak sowetowali sdelal. No ne poluchaetsya. Private Sub Form_Load() Dim ado As ADODB.Recordset Dim db As ADODB.Connection Set db = New ADODB.Connection db.CursorLocation = adUseClient db.Open "PROVIDER=MSDASQL;dsn=p;uid=;pwd=;" Set ado = New ADODB.Recordset ado.Open "select imya from Polzowateli", db, adOpenStatic, adLockOptimistic Set DBCombo1.RowSource = ado DBCombo1.ListField = "imya" End Sub Do stroki "Set Dbcombo1.Rowsource=ado" dohodit i wydaet soobshenie: Run -Time Error '91' Object variable or with block variable not set ... |
| 10.05.2004, 08:14:24 |
start [/forum/topic.php?fid=60&gotonew=1&tid=2169606]: |
191ms |
46ms |
| others: | 214ms |
| total: | 496ms |
