HELP
Есть у кого нить примеры как добавить(удалить) в базе SQL7.0 записи. Немогу разобрать синтаксис написания. Помогите ... |
| 25.06.2004, 12:44:03 |
HELP
ИМХО - так топики называть вредно сказывается на времен отклика см. правила Добавить: BOLINSERT Adds a new row to a table or a view. Syntax INSERT [ INTO] { table_name WITH ( < table_hint_limited > [ ...n ] ) | view_name | rowset_function_limited } { [ ( column_list ) ] { VALUES ( { DEFAULT | NULL | expression } [ ,...n] ) | derived_table | execute_statement } } | DEFAULT VALUES < table_hint_limited > ::= { FASTFIRSTROW | HOLDLOCK | PAGLOCK | READCOMMITTED | REPEATABLEREAD | ROWLOCK | SERIALIZABLE | TABLOCK | TABLOCKX | UPDLOCK } Удалить: BOLDELETE [ FROM ] { table_name WITH ( < table_hint_limited > [ ...n ] ) | view_name | rowset_function_limited } [ FROM { < table_source > } [ ,...n ] ] [ WHERE { < search_condition > | { [ CURRENT OF { { [ GLOBAL ] cursor_name } | cursor_variable_name } ] } } ] [ OPTION ( < query_hint > [ ,...n ] ) ] < table_source > ::= table_name [ [ AS ] table_alias ] [ WITH ( < table_hint > [ ,...n ] ) ] | view_name [ [ AS ] table_alias ] | rowset_function [ [ AS ] table_alias ] | derived_table [ AS ] table_alias [ ( column_alias [ ,...n ] ) ] | < joined_table > < joined_table > ::= < table_source > < join_type > < table_source > ON < search_condition > | < table_source > CROSS JOIN < table_source > | < joined_table > < join_type > ::= [ INNER | { { LEFT | RIGHT | FULL } [OUTER] } ] [ < join_hint > ] JOIN < table_hint_limited > ::= { FASTFIRSTROW | HOLDLOCK | PAGLOCK | READCOMMITTED | REPEATABLEREAD | ROWLOCK | SERIALIZABLE | TABLOCK | TABLOCKX | UPDLOCK } < table_hint > ::= { INDEX ( index_val [ ,...n ] ) | FASTFIRSTROW | HOLDLOCK | NOLOCK | PAGLOCK | READCOMMITTED | READPAST | READUNCOMMITTED | REPEATABLEREAD | ROWLOCK | SERIALIZABLE | TABLOCK | TABLOCKX | UPDLOCK } < query_hint > ::= { { HASH | ORDER } GROUP | { CONCAT | HASH | MERGE } UNION | FAST number_rows | FORCE ORDER | MAXDOP | ROBUST PLAN | KEEP PLAN } PS: Правда это от 2000, но думаю синтаксис не сильно отличается :) ... |
| 25.06.2004, 13:10:17 |
HELP
2paparome Мне кажется, по таким вопросам нужно просто к BOLу отсылать, а не копировать его сюда :)... ИМХО, конечно... ... |
| 25.06.2004, 15:07:05 |
HELP
авторМне кажется, по таким вопросам нужно просто к BOLу отсылать, а не копировать его сюда :)... Повторение - мать учения! Забыл? ... |
| 25.06.2004, 16:08:51 |
start [/forum/topic.php?fid=60&gotonew=1&tid=2169327]: |
189ms |
51ms |
| others: | 236ms |
| total: | 522ms |
