закрыть другое (DOS) приложение.
Здравствуйте. Можно ли из MS Access на VBA закрыть другое приложение, причем досовское? Заранее благодарен за пример. ... |
| 03.09.2004, 08:51:17 |
может это ? ---------- APPLEMAN ---------- TerminateProcess VB Declaration Declare Function TerminateProcess& Lib "kernel32" (ByVal hProcess As Long, _ ByVal uExitCode As Long) Description Kills a process. Use with VB Works, but should be avoided. Post a WM_CLOSE message to the main window of an application to close it. Parameter Type/Description hProcess Long—The handle of the process to terminate. uExitCode Long—An exit code for the process. Return Value Long—Nonzero on success, zero on failure. Sets GetLastError. Platform Windows 95, Windows NT ... |
| 03.09.2004, 09:47:09 |
start [/forum/topic.php?fid=60&gotonew=1&tid=2168931]: |
56ms |
47ms |
| others: | 208ms |
| total: | 362ms |
