VBA Excel
With Worksheets(m_s1).Range("My_Range2") Dim iRange As Range Dim row As Integer Dim col As Integer Set c = .Find(ComboBox1.Value, LookIn:=xlValues) ' search name of month If Not c Is Nothing Then firstAddress = c.Address ' received $K$29 MsgBox "18.firstAddress = " & firstAddress ' received $K$29 Do If Range(firstAddress).Offset(0, 1).Value = ComboBox2.Value Then выход из процедуры Exit Sub ' , а КАК ВЫЙТИ из группы End With ? Set c = .FindNext(c) End If Loop While Not c Is Nothing And c.Address <> firstAddress End If End With СПАСИБО. ... |
| 28.09.2004, 16:33:29 |
start [/forum/topic.php?fid=60&gotonew=1&tid=2168824]: |
58ms |
42ms |
| others: | 201ms |
| total: | 357ms |
