Ошибка при добавлении записи в базу
База Access. Dim db_file As String Dim conn As ADODB.Connection Dim rs As ADODB.Recordset db_file = IniMassivPrivate("База", App.Path & "\conn.ini") conn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & db_file & ";Persist Security Info=False" Set rs = New Recordset Invalid use of New keyword rs.CursorType = adOpenKeyset rs.LockType = adLockOptimistic rs.Source = "baza" rs.ActiveConnection = conn rs.Open rs.AddNew rs.Fields("mec") = Combo1.Text rs.Fields("ep") = txtEP rs.Fields("et") = txtET rs.Fields("er") = lblER rs.Fields("gt") = txtGT rs.Fields("gp") = txtGP rs.Fields("gr") = lblGR rs.Fields("vt") = txtVT rs.Fields("vp") = txtVP rs.Fields("vr") = lblVR rs.Fields("rez") = lblRez rs.Update rs.Close conn.Close ... |
| 22.04.2005, 11:47:00 |
Set rs = New ADODB.Recordset ... |
| 22.04.2005, 11:50:36 |
start [/forum/topic.php?fid=60&gotonew=1&tid=2167919]: |
45ms |
25ms |
| others: | 192ms |
| total: | 297ms |
