Аргументы по умолчанию
Добрый день!!! Как у функции объявить аргументы по умолчанию? Пример на Си: Код: plaintext 1. 2. 3. 4. 5. Как сделать на VBA тоже самое? ... |
| 18.02.2006, 15:35:19 |
Например так: Public Function NameFunction(lpName As String, Optional lpId As Long, Optional lpIDUp As Long, Optional lpParameter As Long = 0, Optional stWHERE As String = "") As Long ... |
| 18.02.2006, 16:00:31 |
Извините, описался: Код: plaintext 1. HELP ACCESS Understanding Named and Optional Arguments When you call a Sub or Function procedure, you can supply arguments positionally, in the order they appear in the procedure's definition, or you can supply the arguments by name without regard to position. For example, the following Sub procedure takes three arguments: Sub PassArgs(strName As String, intAge As Integer, dteBirth As Date) Debug.Print strName, intAge, dteBirth End Sub You can call this procedure by supplying its arguments in the correct position, each delimited by a comma, as shown in the following example: PassArgs "Mary", 29, #2-21-69# You can also call this procedure by supplying named arguments, delimiting each with a comma. PassArgs intAge:=29, dteBirth:=#2/21/69#, strName:="Mary" A named argument consists of an argument name followed by a colon and an equal sign (:=), followed by the argument value. Named arguments are especially useful when you are calling a procedure that has optional arguments. If you use named arguments, you don't have to include commas to denote missing positional arguments. Using named arguments makes it easier to keep track of which arguments you passed and which you omitted. Optional arguments are preceded by the Optional keyword in the procedure definition. You can also specify a default value for the optional argument in the procedure definition. For example: Sub OptionalArgs(strState As String, Optional strCountry As String = "USA") . . . End Sub When you call a procedure with an optional argument, you can choose whether or not to specify the optional argument. If you don't specify the optional argument, the default value, if any, is used. If no default value is specified, the argument is it would be for any variable of the specified type. The following procedure includes two optional arguments, the varRegion and varCountry variables. The IsMissing function determines whether an optional Variant argument has been passed to the procedure. Sub OptionalArgs(strState As String, Optional varRegion As Variant, _ Optional varCountry As Variant = "USA") If IsMissing(varRegion) And IsMissing(varCountry) Then Debug.Print strState ElseIf IsMissing(varCountry) Then Debug.Print strState, varRegion ElseIf IsMissing(varRegion) Then Debug.Print strState, varCountry Else Debug.Print strState, varRegion, varCountry End If End Sub You can call this procedure using named arguments as shown in the following examples. OptionalArgs varCountry:="USA", strState:="MD" OptionalArgs strState:= "MD", varRegion:=5 ... |
| 18.02.2006, 17:04:14 |
start [/forum/topic.php?fid=60&gotonew=1&tid=2166350]: |
66ms |
25ms |
| others: | 224ms |
| total: | 360ms |
