Начальное значение для диалога выбора папки
#34727989
Ссылка:
В модуле:
1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. 91. 92. 93. 94. 95. 96. 97. 98. 99. 100.
Option Explicit
Private Const MAX_PATH = 260
Private Const BIF_RETURNONLYFSDIRS = &H1&
Private Const BIF_STATUSTEXT = &H4
Private Const WM_USER = &H400
Private Const BFFM_INITIALIZED = 1
Private Const BFFM_SELCHANGED = 2
Private Const BFFM_SETSTATUSTEXT = WM_USER + 100
Private Const BFFM_SETSELECTION = WM_USER + 102
Private Const SHGFI_DISPLAYNAME = &H200
Private Const SHGFI_PIDL = &H8
Private Const WM_SETTEXT = &HC
Private Declare Function BrowseForFolder Lib "shell32" Alias "SHBrowseForFolder" _
(lpbi As udtBrowseInfo) As Long
Private Declare Sub CopyMemory Lib "kernel32" Alias "RtlMoveMemory" _
(Destination As Any, Source As Any, ByVal Length As Long)
Private Declare Function GetPathFromIDList Lib "shell32" Alias "SHGetPathFromIDList" _
(ByVal pidl As Long, ByVal pszPath As String) As Long
Private Declare Function SHGetFileInfo Lib "shell32" Alias "SHGetFileInfoA" _
(ByVal pszPath As Any, ByVal dwFileAttributes As Long, psfi As udtShowFileInfo, ByVal cbFileInfo As Long, ByVal uFlags As Long) As Long
Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" _
(ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, lParam As Any) As Long
Type udtBrowseInfo 'brs
hwndOwner As Long
pidlRoot As Long
pszDisplayName As String
lpszTitle As String
ulFlags As Long
lpfn As Long
lParam As String
iImage As Long
End Type
Type udtShowFileInfo 'sfi
hIcon As Long
iIcon As Long
dwAttributes As Long
szDisplayName As String * MAX_PATH
szTypeName As String * 80
End Type
Private Sub BrowseCallbackProc(ByVal plngHndWnd As Long, _
ByVal plngUMsg As Long, _
ByVal plngParam As Long, _
ByVal pstrLpData As String)
Dim strPath As String * MAX_PATH
Dim sfiMyPath As udtShowFileInfo
If plngUMsg = BFFM_SELCHANGED Then
GetPathFromIDList plngParam, strPath
If Asc(strPath) = 0 Then
SHGetFileInfo plngParam, 0 , sfiMyPath, Len(sfiMyPath), SHGFI_DISPLAYNAME Or SHGFI_PIDL
strPath = sfiMyPath.szDisplayName
End If
SendMessage plngHndWnd, BFFM_SETSTATUSTEXT, 0 &, ByVal strPath
ElseIf plngUMsg = BFFM_INITIALIZED Then
SendMessage plngHndWnd, BFFM_SETSELECTION, True, ByVal pstrLpData
SendMessage plngHndWnd, WM_SETTEXT, 0 , ByVal "Browse for Folder"
End If
End Sub
Public Function BrowseFolder(ByVal pstrStartFolder As String) As String
Dim brsMyBrwsInfo As udtBrowseInfo
Dim lngRetFldrBrws As Long
Dim strReturn As String
CopyMemory brsMyBrwsInfo.lpfn, AddressOf BrowseCallbackProc, 4
With brsMyBrwsInfo
.ulFlags = BIF_RETURNONLYFSDIRS Or BIF_STATUSTEXT
.hwndOwner = Screen.ActiveForm.hwnd
.lParam = StrConv(Trim$(pstrStartFolder), vbUnicode)
.lpszTitle = "Please select your directory:"
End With
lngRetFldrBrws = BrowseForFolder(brsMyBrwsInfo)
If lngRetFldrBrws Then
GetPathFromIDList lngRetFldrBrws, strPath
strReturn = Left$(strPath, InStr(strPath, vbNullChar) - 1 )
Else
strReturn = pstrStartFolder
End If
BrowseFolder = IIf(strReturn = vbNullString, vbNullString, _
IIf(Right$(strReturn, 1 ) = "\", strReturn, strReturn & "\"))
End Function
В форме:
1. 2. 3. 4.
Option Explicit
Private Sub Command1_Click()
BrowseFolder "C:\Temp"
End Sub
Успехов.
