Цикл While
Люди подскажите, есть ли варианты прерывания цикла While наподобие Exit For? Или это осуществимо только по GoTo? ... |
| 06.03.2008, 12:50 |
Цикл While
FAndrewExit Do Provides a way to exit a Do...Loop statement. It can be used only inside a Do...Loop statement. Exit Do transfers control to the statement following the Loop statement. When used within nested Do...Loop statements, Exit Do transfers control to the loop that is one nested level above the loop where Exit Do occurs. А надо While...Wend ... |
| 06.03.2008, 13:42 |
start [/forum/topic.php?fid=60&gotonew=1&tid=2162578]: |
56ms |
55ms |
| others: | 205ms |
| total: | 369ms |
