Зависает Работа с циклом
последний цикл Do Loop постоянно зависает. Вроде бы всё перепробовал, но тщётно. Public Class Form1 Dim i As Integer Dim real As Integer Dim tempmax As Integer Dim tempmin As Integer Dim voimsus1 As Integer Dim voimsus2 As Integer Dim voimsus3 As Integer Dim kokkuvoimsus As Integer Dim p As Integer Dim termo As Integer Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load For m = 0 To 50 Step 5 ComboBox1.Items.Add(Format(m, "00")) Next For m = -5 To -50 Step -5 ComboBox2.Items.Add(Format(m, "00")) Next End Sub Private Sub Label2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Label2.Click End Sub Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick termo = 1 If CheckBox3.Checked = True Then Do Until real = tempmax Label2.Top = Label2.Top - termo Label1.Text += termo Exit Do CheckBox3.Checked = False Loop ElseIf CheckBox3.Checked = False Then Do Until real = tempmin Label2.Top = Label2.Top + termo Label1.Text -= termo Exit Do CheckBox3.Checked = True Loop End If If Label1.Text = tempmax Then CheckBox3.Checked = False End If If Label1.Text = tempmin Then CheckBox3.Checked = True End If End Sub Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click tempmin = CInt(ComboBox2.Text) real = CInt(Label1.Text) tempmax = CInt(ComboBox1.Text) Timer1.Start() Do If CheckBox3.Checked = True Then voimsus1 = 1000 ElseIf CheckBox3.Checked = False Then voimsus1 = 0 End If If CheckBox1.Checked = True Then voimsus2 = 60 ElseIf CheckBox1.Checked = False Then voimsus2 = 0 End If If CheckBox2.Checked = True Then voimsus3 = 15 ElseIf CheckBox2.Checked = False Then voimsus3 = 0 End If kokkuvoimsus = voimsus1 + voimsus2 + voimsus3 Label6.Text = kokkuvoimsus Loop Until kokkuvoimsus = 1075 End Sub ... |
| 02.01.2010, 17:00 |
start [/forum/topic.php?fid=60&gotonew=1&tid=2160260]: |
66ms |
27ms |
| others: | 219ms |
| total: | 369ms |
