Проблема SQL запроса в Visual Basic, HELP!!
Отрывок из кода: Set Rs.ActiveConnection = Cn Rs.LockType = adLockReadOnly Rs.Source = "select coalesce(mailbox, street) as St," & _ "coalesce(pbzip, zip) as PLZ, addressterm, title, name, christianname," & _ "addressletter , compname, town" & _ "from (" & _ "select addressterm, title, name, christianname, addressletter," & _ "compname, town, street, zip, pbzip, pbox," & _ "replace(replace(pbox, 'Mailbox', ''), ' ', '') as mailbox" & _ "from address where cast(GGUID as uniqueidentifier)" & _ "like '" & UserForm1.CoBxASP.Value & "'" & _ ") as temptab" Rs.Open здесь выдает ошибку при debugging Rs.MoveFirst в БД запрос работает идеально без каких-либо проблем, что здесь не так и что можно сделать - ума не приложу, ВБ я не особо знаю.. ... |
| 10.10.2010, 23:34 |
start [/forum/topic.php?fid=60&gotonew=1&tid=2159363]: |
36ms |
| others: | 195ms |
| total: | 279ms |
