Случайное целое число например от 1 до 60
Тупой конечно вопрос. Rnd кажется как то предвзято генерирует, т.е. первое случайное всегда будет одно и то же, как припоминаю. Или чего-то путаю. Но надо действительно случайное без завязки на предыдущие результаты. ... |
| 09.08.2012, 16:20 |
Randomize ... |
| 09.08.2012, 16:34 |
| 09.08.2012, 16:34 |
The Rnd function returns a value less than 1 but greater than or equal to zero. The value of number determines how Rnd generates a random number: For any given initial seed, the same number sequence is generated because each successive call to the Rnd function uses the previous number as a seed for the next number in the sequence. Before calling Rnd, use the Randomize statement without an argument to initialize the random-number generator with a seed based on the system timer. To produce random integers in a given range, use this formula: Int((upperbound - lowerbound + 1) * Rnd + lowerbound) Here, upperbound is the highest number in the range, and lowerbound is the lowest number in the range. Note To repeat sequences of random numbers, call Rnd with a negative argument immediately before using Randomize with a numeric argument. Using Randomize with the same value for number does not repeat the previous sequence. ... |
| 09.08.2012, 16:35 |
start [/forum/topic.php?fid=60&gotonew=1&tid=2157521]: |
76ms |
55ms |
| others: | 220ms |
| total: | 405ms |
