Sorting with InternalCalc field
I have created new field for FDQuery as FieldKind = fkInternalCalc and all other fields are as fkData. After clicking column all other fields are sorted OK but the internalcalc field does not sort data! All events are below: Код: pascal 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. Why this field does not sort data? Thanks in advance. I can read in Russian. ... |
| 06.06.2018, 03:28 |
Are you sure FieldKind is fkInternalCalc and not fkCalculated ? Posted via ActualForum NNTP Server 1.5 ... |
| 06.06.2018, 06:14 |
P.S. This is not Firebird-related problem, it is client-side (should be asked in Delphi forum). Posted via ActualForum NNTP Server 1.5 Модератор: Тема перенесена из форума "Firebird, InterBase". ... |
| 06.06.2018, 06:16 |
Гаджимурадов Рустам, Yes, I know that Calculated field is not sortable, so I changed to InternalCalc. When I debug I catch event OnCalcField fired up but data is not sorted at all - very weird order. Thanks, Fred ... |
| 06.06.2018, 17:59 |
FredFFYes, I know that Calculated field is not sortable, so I changed to InternalCalc.May be FireDAC's developer (Arefiev) can help you, he used to answer related questions here. ... |
| 06.06.2018, 20:46 |
Гаджимурадов Рустам, How to contact him directly. I need his email Thanks, Fred ... |
| 06.06.2018, 21:27 |
FredFF> How to contact him directly. I need his email "Dmitry Arefiev" It is his account here, I\'ve messaged him, just wait. And EMBT support should/can help you as well. Posted via ActualForum NNTP Server 1.5 ... |
| 06.06.2018, 21:57 |
What is the RAD Studio version ? ... |
| 07.06.2018, 16:13 |
Dmitry Arefiev, Delphi conditional Product Product Version Package Version CompilerVersion VER300 Delphi 10 Seattle / C++Builder 10 Seattle 23 230 30.0 I have created simple project for table using two fields one is fkData and another fkInternalCalc. Use OnCalcField event to fill internal calc field. Then in run-time tried to click column to sort - result the same - I see it's doing something but result is not in asc or desc order. Total mess. ... |
| 07.06.2018, 18:07 |
FredFF, I cannot reproduce the issue. Please send your test project to darefiev at gmail dot com. ... |
| 07.06.2018, 19:20 |
Dmitry Arefiev, Dima. I sent you test project. I did not receive any message from you. Are you able to replicate issues that I experienced with? It's always happened at the beginning (first sort or second) then sorting working OK. Thanks, Fred ... |
| 15.06.2018, 03:15 |
FredFF> Dima. I sent you test project. ... It's always happened FredFF> at the beginning (first sort or second) then sorting working OK. Да выкладывай прямо сюда, если проект не работает с внешними СУБД. Может, кто-то скачает, воспроизведёт и подскажет, в чём проблема. Posted via ActualForum NNTP Server 1.5 ... |
| 17.06.2018, 17:48 |
start [/forum/topic.php?fid=58&gotonew=1&tid=2040737]: |
71ms |
67ms |
| others: | 208ms |
| total: | 406ms |
