Trigger,Procedure
Esli ja meniaiu znachenie proc v tablize al_t_a_f_user,to mne vydetsia oshibka: Trigger ne dolgen etogo videti. Podskagite v chem moia oshibka? CREATE TRIGGER al_tr_proc AFTER UPDATE OF proc ON al_t_a_f_user REFERENCING OLD AS OLD_UPD NEW AS NEW_UPD FOR EACH ROW BEGIN IF (:new_upd.PROC = 1) THEN al_p_x; END IF; IF (:new_upd.PROC = 2) THEN al_p_y; END IF; END; / create procedure al_p_x as begin delete from t_daten where gj in (select distinct gj from i_daten) and periode in (select distinct periode from i_daten); insert into t_daten select * from i_daten; end; / create procedure al_p_y as begin delete from i_daten; insert into i_daten select * from t_daten where gj=(select gj from al_v_a_f_user) and periode=(select periode from al_v_a_f_user); end; / ... |
| 30.10.2001, 12:46:53 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1993496]: |
42ms |
42ms |
| others: | 270ms |
| total: | 403ms |
