Ошибка при создании БД, 8.1.7
При создании БД в Oracle 8.1.7 возникает ошибка ORA-03113: end-of-file on communication chanel Что делать? Спасибо. ... |
| 13.12.2001, 13:38:12 |
Вот что говорит по этому поводу Instant Messages: ORA-03113 end-of-file on communication channel Cause: An unexpected end-of-file was processed on the communication channel. The problem could not be handled by the Net8, two task, software. This message could occur if the shadow two-task process associated with a Net8 connect has terminated abnormally, or if there is a physical failure of the interprocess communication vehicle, that is, the network or server machine went down. Action: If this message occurs during a connection attempt, check the setup files for the appropriate Net8 driver and confirm Net8 software is correctly installed on the server. If the message occurs after a connection is well established, and the error is not due to a physical failure, check if a trace file was generated on the server at failure time. Existence of a trace file may suggest an Oracle internal error that requires the assistance of customer support. ... |
| 13.12.2001, 13:48:57 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1993474]: |
171ms |
34ms |
| others: | 238ms |
| total: | 493ms |
