Проблемма вызова внешней процедуры
Помогите вызвать внешнюю процедурку выдает - ORA-28576: потеряно соединение RPC с агентом внешней процедуры вот мои настойки подскажите в чем ошибка или может гдето забыл какое разрешение включить listiner.ora LISTENER = (DESCRIPTION_LIST = (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = Serv)(PORT = 1521)) ) (DESCRIPTION = (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC0)) ) ) SID_LIST_LISTENER = (SID_LIST = (SID_DESC = (GLOBAL_DBNAME = DBA) (ORACLE_HOME = D:\oracle\ora81) (SID_NAME = DBA) ) (SID_DESC = (PROGRAM = extproc) (SID_NAME = PLSExtProc) (ORACLE_HOME = D:\extproc) ) ) tnsnames.ora DBA = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = testsrv)(PORT = 1521)) ) (CONNECT_DATA = (SERVICE_NAME = DBA)) ) extproc_connection_data= (description= (address=(protocol=ipc)(key=extproc0)) (connect_data= (sid=plsextproc))) ... |
| 15.05.2002, 07:23:41 |
короче это надо так Note: Before you try external procedures, be sure that the machine where you're running the Oracle server supports shared or dynamically linked libraries. Virtually all UNIX machines qualify, as do Windows NT machines. Steps in Creating an External Procedure Below are the 4 steps to create an external procedure. Additional detail is provided below using an implementation of a random number generator for PL/SQL to illustrate each step. 1. Ensure that your DBA has enabled a listener for external procedures in your Net8 environment. (This involves changes to tnsnames.ora and listener.ora.) This is a one-time job for a given server. 2. Identify or create the .so or .DLL file which contains the shared library. 3. In Oracle, issue the SQL statement CREATE LIBRARY..., which defines an alias in the data dictionary for the external shared library file. This registers the program with the database engine so that it knows where to find it when it is called. 4. Create the PL/SQL function or procedure body, typically within a package, that will register with PL/SQL the desired routine from the external library. The body of the procedure or function will use the EXTERNAL clause in place of a BEGIN...END block. Step 1: Set Up the Listener What actually happens when your code needs to use the external procedure? First, your code calls a predefined PL/SQL body. When the PL/SQL runtime engine notices such a call, it looks for the special Net8 listener named EXTERNAL_PROCEDURE_LISTENER, which in turn spawns a session-specific process called extproc. It is extproc that invokes your routine in the shared library. You need to create a new listener with a specific name, EXTERNAL_PROCEDURE _LISTENER. This listener process will execute alongside other listener(s) that you already have running. NOTE: You cannot change the names EXTERNAL_PROCEDURE_LISTENER or extproc. In the listener.ora fragment given, everything that's not in lowercase italics must match the listing. In your listener.ora file, you will need the following entries: Click Here to copy entries to Windows Clipboard EXTERNAL_PROCEDURE_LISTENER = (ADDRESS_LIST = (ADDRESS = (PROTOCOL=IPC) (KEY=epsid) ) ) SID_LIST_EXTERNAL_PROCEDURE_LISTENER = (SID_LIST = (SID_DESC= (SID_NAME=epsid) (ORACLE_HOME=full_directory_path) (PROGRAM=extproc) ) ) Where: epsid A short identifier that is used by Net8 to locate the listener. Its actual name is rather arbitrary, since your programs will never see it. epsid has to be the same identifier in the address list and in the SID list. full_directory_path The full pathname to your ORACLE_HOME directory, such as /u01/app/oracle/product/8.0.3 on UNIX or C:\ORANT on Windows NT. Notice that there are no quotes around the directory name. NOTE: If desired, listener.ora can point the listener's log into your desired directory: LOG_DIRECTORY_EXTERNAL_PROCEDURE_LISTENER=/u01/app/oracle/admin/SID/logbook And, for debugging, you can control "tracing" for your new listener with entries like this: TRACE_DIRECTORY_EXTERNAL_PROCEDURE_LISTENER=/u01/app/oracle/admin/SID/logbook TRACE_LEVEL_EXTERNAL_PROCEDURE_LISTENER=user The tnsnames.ora file on the machine where the server is running will need an entry like the following: Click Here to copy entries to Windows Clipboard EXTPROC_CONNECTION_DATA = (DESCRIPTION = (ADDRESS = (PROTOCOL=IPC) (KEY=epsid) ) (CONNECT_DATA= (SID=epsid)) ) ) Again, epsid must match the key used in the listener.ora file. Tip If you intend to use external procedures on your server, remember to modify your database startup and shutdown procedures to incorporate the listener start and stop commands. On UNIX, this typically means editing a startup shell script. On Windows NT, a Net8 listener is automatically installed as a system service the first time you start it from the command line. However, the listener will not launch automatically on boot unless you configure it to do so. You can use the control panel to designate which listeners launch on system startup. To remove the external procedure service on NT, delete the entries from listener.ora and tnsnames.ora, and use the NT command instsrv <service name> remove as follows: instsrv OracleTNSListener80external_procedure_listener remove (The instsrv utility is available in the NT 4.0 Server Resource Kit. Without it, you'll probably have to edit the registry.) After making these configuration file changes, you'll need to start the new listener process. In UNIX, this is typically performed from the command line: lsnrctl start external_procedure_listener If your database server is running on Windows NT, the first time you start the listener, you'll use the LSNRCTL80 command. From the command prompt, for example, the command would be: LSNRCTL80 start external_procedure_listener Thereafter (on NT) you can start and stop specific listeners from the Services component of the Control Panel. Step 2: Identify or Create the Shared Library Step 1 is completely independent of any external procedure that you may create on your system. The remaining steps, while specific to our random number procedure, include discussion that applies to almost any external procedure. To keep our example simple, this external procedure will not require any C language programming: we will call a standard C library function, rand, which generates a 16-bit random number. On many platforms, rand already exists in a shared object library; on UNIX, it's often in /lib/libc.so, and on NT, in c:\winnt\system32\CRTDLL.DLL. Random number algorithms have certain quirks you need to realize. First, such generators can be deterministic; that is, the algorithm may return the same sequence of "random numbers" every time unless first "seeded" with a quasi-random number. Often, the previous random number is stored and used as a seed. But for the very first call, your program provides the seed, perhaps using some function of the current system time. If you call rand later with an identical seed value, you will get an identical pseudo-random sequence. rand has a companion "seeding" function, srand, that allows you to supply your own seed value. Calling srand before calling rand stores the seed value as a global in memory, for use by the next call to rand. Subsequent calls from the same session need not call srand, since rand will re-seed itself. Step 3: Issue CREATE LIBRARY Statement Now that we have identified /lib/libc.so as the file containing our needed functions, the next thing we have to do is create a library in the Oracle database. Creating a library is a way of telling Oracle that we want to refer to a specific shared object file by a programmer-defined name. For many UNIX systems, /lib/libc.so will contain the needed function as shown here: CREATE OR REPLACE LIBRARY libc_l AS '/lib/libc.so'; Executing this command requires the CREATE LIBRARY privilege. Click Here for more information on syntax for external procedures. Note that you have to use a fully qualified pathname; attempting to use an environment variable such as $ORACLE_BASE in the filename will not work. If your database server runs on Windows NT, your library would likely be created as follows: CREATE OR REPLACE LIBRARY libc_l AS 'c:\winnt\system32\CRTDLL.DLL'; Regardless of platform, you only need to create a single library in this fashion for each shared object file you use. That is, even though you have only issued a single CREATE LIBRARY command for libc.so (or CRTDLL.DLL), you can define any number of external procedures that use routines from that file. Step 4: Create the PL/SQL Body The final step is to create a function or procedure definition which registers the desired routine from the shared library. This feature lets you write the body of a PL/SQL procedure or function in C instead of PL/SQL. To the caller it looks like any other PL/SQL subprogram. Assuming that your C language skills are ready for any custom programming needed in Step 3, Step 4 is potentially the most complex one. Because of the differences between PL/SQL arguments and C language arguments (in datatype, character set, whether they can be null, etc.), Oracle provides a lot of "instrumentation" to allow you to properly map PL/SQL arguments to C language arguments. Click Here for details on "Mapping Parameters". Tip All of the samples in the Knowledge Base put the needed modules in a PL/SQL package. One of many benefits of packages is that they enable us to use the RESTRICT_REFERENCES pragma with our module(s). This pragma allows us to tell Oracle that the user-defined function is "safe" and can therefore be used in SQL statements. Using our random number example, the specification for an appropriate PL/SQL package might look like this: CREATE OR REPLACE PACKAGE random_utl AS FUNCTION rand RETURN PLS_INTEGER; PRAGMA RESTRICT_REFERENCES (rand, WNDS, RNDS, WNPS, RNPS); PROCEDURE srand (seed IN PLS_INTEGER); PRAGMA RESTRICT_REFERENCES (srand, WNDS, RNDS, WNPS, RNPS); END random_utl; Notice that the package specification is completely devoid of clues that we intend to implement the two subprograms as external procedures. We can't yet tell that rand and srand are any different from conventional PL/SQL modules. And that is exactly the point! From a usage perspective, external procedures are interchangeable with conventional procedures. Assuming that your library is defined correctly, this package will work as-is on either UNIX or Windows NT. (Even in cases where you can't use the same external code on different operating systems, it may be possible to make the PL/SQL specification the same. You could then make the external code the only thing that differs—which is very desirable if you have to support multiple platforms.) CREATE OR REPLACE PACKAGE BODY random_utl AS /* Tested with: (1) Solaris 2.5.1 and Oracle 8.0.3 || (2) Windows NT 4.0 and Oracle 8.0.3 */ FUNCTION rand RETURN PLS_INTEGER /* Return a random number between 1 and (2**16 - 1), using || the current seed value. */ IS EXTERNAL -- tell PL/SQL that this is an external procedure LIBRARY libc_l -- specify the library that we created above NAME "rand" -- function's real name is lowercase LANGUAGE C; -- we are calling a function written in C PROCEDURE srand (seed IN PLS_INTEGER) /* Store a seed value used by external rand() function */ IS EXTERNAL LIBRARY libc_l NAME "srand" -- srand (lowercase) is function's real name LANGUAGE C PARAMETERS (seed ub4); -- map to unsigned four-byte integer END random_utl; In this example, we have chosen to make the names of the PL/SQL modules identical to those in the shared object library. It is not necessary that they match; in fact, you may wish to make them different so that you can talk about (or document) the parameters independently. Notice the PARAMETERS clause in the body of srand. Each of the formal parameters to the PL/SQL module must have at least one corresponding entry in a PARAMETERS clause. Although there is an extensive set of defaults which can eliminate the need for this clause, this explicit PARAMETERS clause makes it perfectly clear how the parameters will be mapped between PL/SQL and C. Step 5: Using the External Procedure Now that we've "registered" the external procedure with a PL/SQL package, we can test it: SET SERVEROUTPUT ON SIZE 100000 DECLARE rnd_value PLS_INTEGER; seed PLS_INTEGER; BEGIN /* Generate a seed value from the current system time. */ SELECT TO_CHAR(SYSDATE, 'SSSSS') INTO seed FROM DUAL; /* Call the srand external procedure to store our seed in memory. */ random_utl.srand (seed); /* Now demonstrate some random numbers. */ FOR v_cnt IN 1 .. 10 LOOP rnd_value := random_utl.rand; DBMS_OUTPUT.PUT_LINE ('rand() call #' || v_cnt || ' returns ' || rnd_value); END LOOP; END; This brief test routine simply seeds the library routine with a quasi-random number derived from the current system time, then calls the random number generator ten times in a row. One of our trial runs produced the following results: rand() call #1 returns 27610 rand() call #2 returns 27964 rand() call #3 returns 27908 rand() call #4 returns 21610 rand() call #5 returns 14085 rand() call #6 returns 14281 rand() call #7 returns 9569 rand() call #8 returns 9397 rand() call #9 returns 24266 rand() call #10 returns 142 You'll notice immediately that the numbers from our trial run are not totally random. This isn't Oracle's fault! The problem lies with the algorithm used in rand. Moreover, rand returns numbers only in the range 1 through 65535. Many C libraries include the XPG4 standard function rand48, which overcomes these limitations at the expense of mildly increased complexity. Click Here to view the c source code of an external procedure that uses rand48. The file name is rand48ut.c Click Here to view the SQL source code of an external procedure that uses rand48. The file name is rand48ut.sql ... |
| 16.05.2002, 11:11:44 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1993340]: |
206ms |
42ms |
| others: | 226ms |
| total: | 533ms |
