tnsping говорит, что failed to resolve name. Не могу поставить клиента
нет, tnsping говорит, что failed to resolve name. А вот tnsnames # TNSNAMES.ORA Network Configuration File: D:\oracle\ora81\network\admin\tnsnames.ora # Generated by Oracle configuration tools. INST1_HTTP = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = coi-srv03)(PORT = 1521)) ) (CONNECT_DATA = (SERVER = SHARED) (SERVICE_NAME = RENORA) (PRESENTATION = http://admin) ) ) EXTPROC_CONNECTION_DATA = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC0)) ) (CONNECT_DATA = (SID = PLSExtProc) (PRESENTATION = RO) ) ) RENORA = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = coi-srv03)(PORT = 1521)) ) (CONNECT_DATA = (SERVICE_NAME = RENORA) ) ) а вот listener # LISTENER.ORA Network Configuration File: D:\oracle\ora81\network\admin\listener.ora # Generated by Oracle configuration tools. LISTENER = (DESCRIPTION_LIST = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = coi-srv03)(PORT = 1521)) ) (ADDRESS_LIST = (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC0)) ) ) ) SID_LIST_LISTENER = (SID_LIST = (SID_DESC = (SID_NAME = PLSExtProc) (ORACLE_HOME = D:\oracle\ora81) (PROGRAM = extproc) ) (SID_DESC = (GLOBAL_DBNAME = RENORA) (ORACLE_HOME = D:\oracle\ora81) (SID_NAME = RENORA) ) ) а вот sqlnet NAMES.DIRECTORY_PATH= (TNSNAMES) ... |
| 23.09.2002, 15:33 |
Сравни параметр service_names в init.ora на сервере с service_name в tnsnames.ora на клиенте. Или пропиши в tnsnames.ora SID базы. Попробуй просто ping по имени хоста с машины клиента. Бывает еще порт 1522. Короче танцы с бубном :-)) ... |
| 23.09.2002, 16:45 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1993049]: |
64ms |
46ms |
| others: | 213ms |
| total: | 375ms |
