Глобальные переменные (:global.).
Можно ли проверить существование глобальной переменной, без применения средств обработки исключений. ... |
| 09.10.2002, 10:45 |
/* ** Built-in: DEFAULT_VALUE ** Example: Make sure a Global variable is defined by ** assigning some value to it with Default_Value */ BEGIN /* ** Default the value of GLOBAL.Command_Indicator if it is ** NULL or does not exist. */ Default_Value('***','global.command_indicator'); /* ** If the global variable equals the string we defaulted ** it to above, then it must have not existed before */ IF :Global.Command_Indicator = '***' THEN Message('You must call this screen from the Main Menu'); RAISE Form_Trigger_Failure; END IF; END; ... |
| 09.10.2002, 12:55 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1992972]: |
60ms |
32ms |
| others: | 214ms |
| total: | 352ms |
