Про ORA-12612 TNS:connection is busy
Периодически при работе арма возникает ошибка: ORA-12612 Message 12612 not found product=RDBMS; facilty = ORA из документации: --------------------------------------------------- ORA-12612 TNS:connection is busy Cause: Attempted operation failed because it conflicts with an on-going action or status of the connection. Action: Not normally visible to user. For further details, turn on tracing and reexecute the operation. If error persists, contact Worldwide Customer Support. Из-за чего это может быть и насколько серьезно ? P.S. База на Sun Solaris, рабочие места windows 98 ... |
| 29.11.2002, 10:02 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1992604]: |
29ms |
31ms |
| others: | 299ms |
| total: | 408ms |
