ora-24314
Citaiu v Oracle9i Database Administration's Guide: Starting and Shut Down a Database with SQL*PLUS, tam napisono: 1. c:\sqlplus /nolog -- prohodit 2. connect /as sysdba --> ora - 2431: service handle not initialized. Cacoi is servesov? Spasibo ... |
| 14.03.2003, 18:46 |
ora-24314
The following have been verified: 1) No errors in $ORACLE_HOME/install/make.log 2) No orphan SQL*PLUS processes (ps -ef | grep <SID>). See <Note:152474.1> ORA-24314 While Running sqlplus "connect / as sysdba" 3) ORACLE_HOME and ORACLE_SID are set correctly 4) Relink all was not helpful ... |
| 17.03.2003, 11:22 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1991464]: |
64ms |
35ms |
46ms |
| others: | 208ms |
| total: | 400ms |
