RAC на Linux. Не стартует GSD.
При установленом RedHat Advanced Server 2.1, Oracle 9.0.2, запущенном watchdog Возникает ошибка при запуске gsd.sh [main] [18:5:6:765] [OPSMDaemon.main:726] initializeDaemon status = true [main] [18:5:6:770] [OPSMDaemon.<init>:201] In setCoordinator [main] [18:5:16:879] [OPSMDaemon.<init>:201] checkCoordinator status = true [main] [18:5:16:884] [OPSMDaemon.<init>:201] status = true [main] [18:5:16:889] [OPSMDaemon.<init>:201] m_coordinatorNode = rac2 [main] [18:5:16:894] [OPSMDaemon.<init>:201] Coordinator Node: rac2 my node:rac2 [main] [18:5:16:904] [RawDeviceConfig.init:113] initializing OCRTree [main] [18:5:17:37] [OCR.<init>:64] Detected Cluster [main] [18:5:17:44] [OCR.<init>:65] Cluster existence = true [main] [18:5:17:50] [OCRTree.<init>:80] Going to load the ocr librarysrvmocr [main] [18:5:17:59] [OCRTree.<init>:80] loaded ocr libraries [main] [18:5:17:65] [OCRTree.<init>:80] in OCR constructor [main] [18:5:17:71] [OCRTree.<init>:80] Initializing OCR: NEW initializeDaemon: localNodeName = rac2 Native Code Debug is ONinitializeOCR: procr_init retval = 15 initializeOCR: procr_init failed [main] [18:5:17:93] [OCRTree.<init>:80] Status obtained from native code false [main] [18:5:17:99] [OCRTree.<init>:80] ocr Error code = 15 [main] [18:5:17:105] [OCRTree.<init>:80] OCR Initialization failed for othan than INVALID_FORMAT error [main] [18:5:17:113] [OPSMDaemon.main:729] oracle.ops.mgmt.rawdevice.RawDeviceException: PRKR-1064 : 1I55 8A:;NG5=85 2 OCR oracle.ops.mgmt.rawdevice.RawDeviceException: PRKR-1064 : 1I55 8A:;NG5=85 2 OCR at oracle.ops.mgmt.rawdevice.RawDeviceConfig.<init>(RawDeviceConfig.java:100) at oracle.ops.mgmt.rawdevice.RawDeviceConfig.init(RawDeviceConfig.java:113) at oracle.ops.mgmt.daemon.OPSMDaemon.<init>(OPSMDaemon.java:207) at oracle.ops.mgmt.daemon.OPSMDaemon.main(OPSMDaemon.java:726) [main] [18:5:17:117] [line# N/A] Exiting from main..no point trying to start the daemon [root@rac2 bin]# Устройства RAW созданы : [root@rac2 bin]# ls -l /dev/raw* crw------- 1 oracle dba 162, 1 Мар 13 12:52 /dev/raw1 crw------- 1 oracle dba 162, 10 Мар 13 12:54 /dev/raw10 crw------- 1 oracle dba 162, 11 Мар 13 12:54 /dev/raw11 crw------- 1 oracle dba 162, 12 Мар 13 12:54 /dev/raw12 crw------- 1 oracle dba 162, 13 Мар 13 12:54 /dev/raw13 crw------- 1 oracle dba 162, 14 Мар 13 12:54 /dev/raw14 crw-r--r-- 1 oracle dba 162, 15 Мар 20 16:35 /dev/raw15 crw------- 1 oracle dba 162, 16 Мар 13 12:54 /dev/raw16 crw------- 1 oracle dba 162, 17 Мар 13 12:54 /dev/raw17 crw------- 1 oracle dba 162, 18 Мар 13 12:54 /dev/raw18 crw------- 1 oracle dba 162, 19 Мар 13 12:54 /dev/raw19 crw------- 1 oracle dba 162, 2 Мар 13 12:52 /dev/raw2 crw------- 1 oracle dba 162, 20 Мар 13 12:54 /dev/raw20 crw------- 1 oracle dba 162, 21 Мар 13 12:54 /dev/raw21 crw------- 1 oracle dba 162, 22 Мар 13 12:54 /dev/raw22 crw------- 1 oracle dba 162, 23 Мар 13 12:55 /dev/raw23 crw------- 1 oracle dba 162, 3 Мар 13 12:53 /dev/raw3 crw------- 1 oracle dba 162, 4 Мар 13 12:53 /dev/raw4 crw------- 1 oracle dba 162, 5 Мар 13 12:53 /dev/raw5 crw-r--r-- 1 oracle dba 162, 50 Мар 17 15:45 /dev/raw50 crw------- 1 oracle dba 162, 6 Мар 13 12:54 /dev/raw6 crw------- 1 oracle dba 162, 7 Мар 13 12:54 /dev/raw7 crw------- 1 oracle dba 162, 8 Мар 13 12:54 /dev/raw8 crw------- 1 oracle dba 162, 9 Мар 13 12:54 /dev/raw9 ... |
| 21.03.2003, 12:35 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1991377]: |
183ms |
40ms |
| others: | 252ms |
| total: | 531ms |
