Каким параметром давится в SQLPlus строка "Input truncated to 9 characters&
Вот, такой вот вопрос. ... |
| 04.04.2003, 15:09 |
Message: "Input Truncated To 'N' Characters" is received when running a script at the SQL*Plus prompt. This message is caused by the lack of a carriage return (CR) at the end of the last line of the script. Solution: --------- Go to the end of the last line, hit delete, and then insert a CR. Save the script. ... |
| 05.04.2003, 02:22 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1991152]: |
178ms |
52ms |
| others: | 272ms |
| total: | 561ms |
