Parameter PLSQL Native Compilation
Keywords: COMPILATION; NATIVE; PERFORMANCE; PL/SQL; Products: 11/PLSQL; Platforms: GENERIC; PURPOSE ------- The purpose of this bulletin is to describe native compilation of PL/SQL program units, including configuration and limitations. SCOPE & APPLICATION ------------------- This bulletin is intended to consolidate information available from a number of other sources as well as correct some errors in current versions of the official Oracle9i documentation. This bulletin also covers some rather subtle points that are not discussed explicitly in the documentation. It does not provide a tutorial on PL/SQL in general; an understanding of the PL/SQL language is assumed. NATIVE COMPILATION OF PL/SQL STORED PROGRAM UNITS IN ORACLE9i ------------------------------------------------------------- Introduction ------------ In versions prior to Oracle9i, all PL/SQL stored program units are compiled to P-code. The resulting P-code is stored in the database and interpreted at runtime. While this results in a very portable solution, it does have some performance consequences; interpreted languages are usually slower than natively compiled languages. As a performance enhancement, Oracle9i provides the capability to natively compile PL/SQL code into shared libraries. These shared libraries are then loaded and executed whenever the corresponding PL/SQL program unit is invoked at runtime. Native compilation of PL/SQL, once it has been properly configured, is transparent to both the user compiling a PL/SQL program unit and to the end user invoking that same PL/SQL program unit. Oracle9i generates C code corresponding to the PL/SQL code and then compiles and links the resulting C code into shared libraries using the compiler and linker for that platform. Therefore, a C compiler must be installed on the same host for native compilation to work. The next section discusses the initialization parameters that are used to configure PL/SQL native compilation. Subsequent sections discuss other considerations when using native compilation. Initialization Parameters Related to PL/SQL Native Compilation -------------------------------------------------------------- plsql_compiler_flags Determines whether PL/SQL code is compiled native or interpreted and determines whether debug information is included. This parameter is settable at both the system and session levels. Possible values are: 'INTERPRETED' - compile in interpreted mode 'NATIVE' - compile in native mode 'DEBUG' - include debug information 'NON_DEBUG' - no debug information Defaults are: 'INTERPRETED','NON_DEBUG' Examples: alter session set plsql_compiler_flags='NATIVE'; alter session set plsql_compiler_flags='INTERPRETED','DEBUG'; Disallowed combinations: 'NATIVE','INTERPRETED' - for obvious reasons 'DEBUG','NON_DEBUG' - for obvious reasons 'NATIVE','DEBUG' - debugging of natively compiled PL/SQL is not yet supported This parameter affects ONLY those PL/SQL program units explicitly compiled AFTER the parameter is set. plsql_native_make_file_name Determines the full path to the makefile used to create the shared libraries that contain the natively compiled PL/SQL code. This parameter is settable only at the system level. This parameter is mandatory if plsql_compiler_flags = 'NATIVE'. This parameter should be set to the full pathname of the makefile provided with Oracle9i for this purpose. The provided makefile is called 'spnc_makefile.mk' and resides in $ORACLE_HOME/plsql. Since $ORACLE_HOME can vary from one installation to another, this parameter does not have any default; it must be set explicitly. Examples: alter system set plsql_native_make_file_name= '/usr/app/oracle/product/9.0.1/plsql/spnc_makefile.mk'; plsql_native_make_utility Determines the full path to the make utility used to process the makefile specified via plsql_native_make_file_name. This parameter is settable only at the system level. This parameter is mandatory if plsql_compiler_flags = 'NATIVE'. This parameter should be set to the full pathname of the 'make' utility on your machine. If the PATH environment variable is set appropriately, you may find that providing just the name of the make utility will work; however, it is highly recommended that the full pathname be provided to avoid potential problems. Since the location of the make utility can vary from one machine to another, this parameter does not have any default; it must be set explicitly. Examples: alter system set plsql_native_make_utility='/usr/ccs/bin/make'; plsql_native_library_dir Determines the directory name used to store the shared libraries that contain the natively compiled PL/SQL code. This parameter is settable only at the system level. This parameter is mandatory if plsql_compiler_flags = 'NATIVE'. This parameter should be set to the full pathname of the directory where the shared libraries are to be stored. The 'oracle' user must have write permissions on this directory or native compilation will fail. Other users' access to the directory should be restricted; in particular, no user other than 'oracle' or 'root' should be allowed to delete files from this directory. The directory is assumed to have already been created. Oracle will not create the directory for you. There is no default value; this parameter must be set explicitly. Examples: alter system set plsql_native_library_dir= '/usr/app/oracle/product/9.0.1/plsql_libs'; plsql_native_c_compiler This parameter should NOT be set with an alter system command, in init.ora or the stored parameter file (SPFILE). The provided makefile should be modified to include the appropriate default location for the C compiler. Example (spnc_makefile.mk): # Specify C Compiler # CC=/opt/SUNWspro/bin/cc plsql_native_linker This parameter should NOT be set with an alter system command, in init.ora or in the stored parameter file (SPFILE). The provided makefile should be modified to include the appropriate default location for the linker. Examples (spnc_makefile.mk): # Specify Linker # LD=/usr/ccs/bin/ld plsql_native_library_subdir_count Determines the number of subdirectories to be created in the directory specified by the plsql_native_library_dir parameter. Rationale: Performance of certain file operations can be adversely affected if the number of files in a directory grows very large. In cases where many PL/SQL program units are natively compiled, each corresponding to a shared library in plsql_native_library_dir, the number of files in this directory can become unacceptably large. By setting this parameter to some value N, you are asking that Oracle distribute the generated shared libraries across the N subdirectories of plsql_native_library_dir. The names of these subdirectories are of the form 'dn' where n is the zero-based directory number. Setting this parameter is recommended if the number of PL/SQL program units to be natively compiled exceeds 10,000. This parameter is settable only at the system level. This parameter is optional; the default value is 0 (zero) so all shared libraries are by default stored directly in plsql_native_library_dir. A Typical PL/SQL Native Compilation Session ------------------------------------------- $ sqlplus system/manager SQL> alter system set plsql_native_make_file_name= '/usr/app/oracle/product/9.0.1/plsql/spnc_makefile.mk'; System altered. SQL> alter system set plsql_native_make_utility='/usr/ccs/bin/make'; System altered. SQL> alter system set plsql_native_library_dir= '/usr/app/oracle/product/9.0.1/plsql_libs'; System altered. NOTE: The above parameters could also be set via the init.ora file. And if a stored parameter file (SPFILE) exists for this instance, the above commands will also persist these changes to the SPFILE, eliminating the need to reaccomplish these steps when the instance is restarted. NOTE: If there is some doubt about the current settings for the parameters, they can be viewed via the 'show parameters plsql' command in sqlplus or by querying the v$parameter table directly. SQL> connect scott/tiger Connected. SQL> alter session set plsql_compiler_flags='NATIVE'; Session altered. SQL> create or replace procedure nativetest as eno number; begin select empno into eno from emp where rownum <= 1; end; / Procedure created. NOTE: To verify that the procedure was created as natively compiled, use USER_STORED_SETTINGS, ALL_STORED_SETTINGS, or DBA_STORED_SETTINGS. SQL> select object_name, param_name, param_value from user_stored_settings where object_name = 'NATIVETEST'; OBJECT_NAME PARAM_NAME PARAM_VALUE ----------- --------------------- ---------------- NATIVETEST plsql_compiler_flags NATIVE,NON_DEBUG To run the natively compiled procedure: SQL> execute nativetest; PL/SQL procedure successfully completed. On Solaris, one can verify that the procedure is being executed natively by using 'pmap' to view the libraries loaded by the oracle executable. Find the name of the shared library corresponding to the PL/SQL procedure: SQL> !ls /usr/app/oracle/product/9.0.1/plsql_libs NATIVETEST__SCOTT__0.so Note that the shared library name (in this case, on Solaris) is constructed from the procedure, function or package name and the schema name. Find the process id of the current sqlplus process: SQL> !ps PID TTY TIME CMD 593 pts/10 0:00 ksh 11695 pts/10 0:00 sqlplus Find the process id of the oracle process: (Note: this assumes you connected via bequeath; otherwise the oracle process won't be a child of sqlplus) SQL> !ps -ef | grep 11695 langor 12080 11695 0 14:28:56 pts/10 0:00 grep 11695 langor 11698 11695 0 14:13:22 ? 0:01 oracleO9iProd ... langor 11695 593 0 14:13:22 pts/10 0:00 sqlplus scott/tiger Use pmap to see all of the memory segments (including shared libraries) that are currently attached to this process. You will see NATIVETEST__SCOTT__0.so listed among the libraries displayed by the pmap utility. SQL> !/usr/proc/bin/pmap 11698 | more /* partial listing of output */ EF44C000 8K read/write/exec [ anon ] EF460000 56K read/exec /usr/lib/libresolv.so.2 EF47C000 8K read/write/exec /usr/lib/libresolv.so.2 EF47E000 16K read/write/exec [ anon ] EF490000 40K read/exec /usr/ucblib/libucb.so.1 EF4A8000 8K read/write/exec /usr/ucblib/libucb.so.1 EF4B0000 8K read/exec /lang/product/9.0.1/plsqllib/NATIVETEST__SCOTT__0.so EF4C0000 8K read/write/exec /lang/product/9.0.1/plsqllib/NATIVETEST__SCOTT__0.so NOTE: It may be possible to perform a similar test on other platforms besides Solaris, but the tools required will likely differ. See your platform documentation for how to do this on your operating system platform. Dependencies, Invalidation and Revalidation ------------------------------------------- Dependencies between database objects are handled in the same manner as in previous Oracle versions. If an object upon which some natively compiled PL/SQL program unit depends changes, the PL/SQL module is invalidated. The next time the same PL/SQL program unit is executed, an attempt is made to revalidate (recompile) the module. Any time a module is recompiled as part of revalidation, it is compiled using its stored setting (i.e. the setting in force the last time the module was explicitly compiled and appearing in the USER/ALL/DBA_STORED_SETTINGS data dictionary views). The stored settings are ONLY used when recompiling as part of revalidation. Any time a PL/SQL module is explicitly compiled via 'create or replace' or 'alter ... compile', the current setting for the session is used. Although natively compiled PL/SQL program units are obviously dependent on their implementation shared libraries, the database is unable to track such dependencies (since the libraries, which reside on the file system, can be manipulated directly via OS commands). For example, attempting to execute a PL/SQL program unit whose shared library has been deleted results in error. $ rm /usr/app/oracle/product/9.0.1/plsql_libs/NATIVETEST__SCOTT__0.so $ sqlplus scott/tiger SQL> execute nativetest; * ERROR at line 1: ORA-06549: PL/SQL: failed to dynamically open shared object (DLL): ld.so.1: oracleO9iProd: fatal: /lang/product/9.0.1/plsqllib/NATIVETEST__SCOTT__0.so: open failed: No such file or directory Since the removal of the library is undetectable to Oracle until the module is executed, the program unit is not marked INVALID; therefore, there is no implicit revalidation (and recompilation). To recreate the missing library, you must explicitly recompile it or recreate it from source. SQL> alter session set plsql_compiler_flags='NATIVE'; Session altered. SQL> alter procedure nativetest compile; Procedure altered. SQL> exit $ ls /usr/app/oracle/product/9.0.1/plsql_libs NATIVETEST__SCOTT__0.so On a related note, shared libararies corresponding to a PL/SQL program unit are not automatically deleted when the program unit is dropped; these files must be manually removed when they are no longer needed. ... |
| 09.04.2003, 16:36 |
Интересно, а если отредактировать этот makefile (spnc_makefile.mk), так, чтобы он копировал бы куда-нибудь компилируемые C файлы, то можно будет получать "почти" исходный текст для wrapped packages? Жаль времени нет поэкспериментировать %( Может уважаемый Oracle X-pert знает сразу же ответ на этот вопрос -- как вяжется компиляция в native код с wrapped кодом. ... |
| 20.04.2003, 17:54 |
Все не так здорово. Декларирована работа только под несколькими компиляторами. С другими не работает. При компиляции процедуры, через, скажем, Тоад, при возникновении ошибки, сообщение об ошибке урезаеться до символа ?, и не отображаеться полностью. Соответствующий баг на металинке был закрыт от публичного доступа с пометкой "только для разработчиков" :) Очень сырая штука. ... |
| 21.04.2003, 02:21 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1990909]: |
169ms |
43ms |
| others: | 208ms |
| total: | 462ms |
