Посоветуйте размер буфера в imp и exp
Стоит RH73, 1Гб памяти.SCSI диски.Вообщем как обычно. Из каких соображений выбирать разбер буфера для imp и exp. И зависит ли это от ОС на которой стоит. ... |
| 24.04.2003, 15:37 |
BUFFER Default: operating system-dependent. See your Oracle operating system-specific documentation to determine the default value for this parameter. Specifies the size, in bytes, of the buffer used to fetch rows. As a result, this parameter determines the maximum number of rows in an array fetched by Export. Use the following formula to calculate the buffer size: buffer_size = rows_in_array * maximum_row_size If you specify zero, the Export utility fetches only one row at a time. Tables with LONG, LOB, BFILE, REF, ROWID, LOGICAL ROWID, DATE, or type columns are fetched one row at a time. Note: The BUFFER parameter applies only to conventional path Export. It has no effect on a direct path Export. Example This section shows an example of how to calculate buffer size. Consider that the following table is created: create table sample (name varchar(30), weight number); The maximum size of the name column is 30, plus 2 bytes for the indicator. The maximum size of the weight column is 22 (the size of the internal representation for Oracle numbers), plus 2 bytes for the indicator. Therefore, the maximum row size is 56 (30+2+22+2). Export Parameters To perform array operations for 100 rows, a buffer size of 5600 should be specified. :) ... |
| 30.04.2003, 15:50 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1990742]: |
174ms |
35ms |
| others: | 247ms |
| total: | 516ms |
