Help
Поставил в Init файле undo_management = AUTO undo_tablespace = undotbs выполняю sql SQL> startup nomount; ORACLE instance started. Total System Global Area 42741800 bytes Fixed Size 450600 bytes Variable Size 41943040 bytes Database Buffers 204800 bytes Redo Buffers 143360 bytes SQL> CREATE DATABASE orainet ORA-01081: cannot start already-running ORACLE - shut it down first SQL> SP2-0734: unknown command beginning "SQL> CREAT..." - rest of line ignored. SQL> 2 LOGFILE GROUP 1 ('/home/oracle/OraHome1/oradata/orainet/redo01.log') SIZE 10M, SQL> 3 GROUP 2 ('/home/oracle/OraHome1/oradata/orainet/redo02.log') SIZE 10M, SQL> 4 GROUP 3 ('/home/oracle/OraHome1/oradata/orainet/redo03.log') SIZE 10M SQL> 5 CHARACTER SET CL8MSWIN1251 SQL> 6 EXCLUSIVE SQL> 7 DATAFILE '/home/oracle/OraHome1/oradata/orainet/oi.dat' SIZE 100M AUTOEXTEND ON NEXT 20M MAXSIZE UNLIMITED; SQL> CREATE DATABASE orainet 2 * 3 ERROR at line 1: 4 ORA-01092: ORACLE instance terminated. Disconnection forced а без этих параметров undo_management = AUTO undo_tablespace = undotbs все проходит на ура может что то не так делаю? ... |
| 14.05.2003, 12:56 |
Help
Видимо пост Софтбилдера не оказал должного воздействия 2All: не сочтите за флуд плиз :-) но мне кажется это сообщение более подходит к теме ;_) -------------------------------------------------- Help! ( J. Lennon, P. McCartney ) Help! I need somebody. Help! Not just anybody. Help! You know, I need someone, help! When I was younger, so much younger than today, I never needed anybody's help in any way. But now these days are gone, I'm not so self assured Now I find I've changed my mind, I've opened up the door. Help me if you can, I'm feeling down And I do appreciate you being 'round. Help me, get my feet back on th ground. Won't you please, please, help me? And now my life has changed in, oh, so many ways, My independence seems to vanish in the haze. But ev'ry now and then I feel so insecure. I know that I just need you like I've never done before. Help me if you can, I'm feeling down And I do appreciate you being 'round. Help me, get my feet back on th ground. Won't you please, please, help me? When I was younger, so much younger than today, I never needed anybody's help in any way. But now these days are gone, I'm not so self assured Now I find I've changed my mind, I've opened up the door. Help me if you can, I'm feeling down And I do appreciate you being 'round. Help me, get my feet back on th ground. Won't you please, please, help me? Help me! Help me! ... |
| 14.05.2003, 13:05 |
Help
Попробуй указать UNDO TABLESPACE UNDO_TS DATAFILE ... Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. А еще смотри alert и trace файлы, там подробное описание ошибки найдешь. Я забыла указать SIZE для UNDO TABLESPACE при создании мне выдавлась ошибка в строке 1. А в трейс файле все объяснилось. ... |
| 14.05.2003, 13:15 |
Help
Просто я оракле не знаю а надо быстрей все это делать вот и пишу ламерские вопросы ... |
| 14.05.2003, 14:43 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1990582]: |
153ms |
59ms |
| others: | 253ms |
| total: | 525ms |
