spool append
Jest li vozmozhnost dobavlat zapisi v sqlplus - spool, ne perepisyvaja pri etom spool- File polnustiju. naprimer: 1.sql spool 1.txt select '1' from dual; spool off 2.sql spool 1.txt select '2' from dual; spool off @1 @2 <>view 1.txt 1 2 ? ... |
| 27.05.2003, 10:20:47 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1990341]: |
223ms |
54ms |
| others: | 223ms |
| total: | 564ms |
