dinamic cursor
Terbujetsya srochno podderzhka kluba. mozhno li v cursor peredavat imya tablizy kak variable. t.e. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. mozhet mozhno eto kak-to inache organizovat? Glavnoje chto bla-bla-bla dolzhno v zycle po dinamicheskomu cursor proishodit. ... |
| 27.05.2003, 11:50:02 |
dinamic cursor
читай в доке, ключевое слово - NATIVE DYNAMIC SQL ... |
| 27.05.2003, 11:53:23 |
dinamic cursor
CREATE OR REPLACE PROCEDURE query_invoice( month VARCHAR2, year VARCHAR2) IS TYPE cur_typ IS REF CURSOR; c cur_typ; query_str VARCHAR2(200); inv_num NUMBER; inv_cust VARCHAR2(20); inv_amt NUMBER; BEGIN query_str := 'SELECT num, cust, amt FROM inv_' || month ||'_'|| year || ' WHERE invnum = :id'; OPEN c FOR query_str USING inv_num; LOOP FETCH c INTO inv_num, inv_cust, inv_amt; EXIT WHEN c%NOTFOUND; -- process row here END LOOP; CLOSE c; END; / ... |
| 27.05.2003, 11:57:22 |
dinamic cursor
Remarks::Not recommended in Oracle under 8.1.7.. ... |
| 27.05.2003, 12:24:20 |
dinamic cursor
--- Remarks::Not recommended in Oracle under 8.1.7.. У нас Oracle 8.1.6.3.0 ,что есть проблемы ? ... |
| 27.05.2003, 13:28:53 |
dinamic cursor
Еще есть пакет DBMS_SQL ... |
| 27.05.2003, 13:32:49 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1990334]: |
210ms |
55ms |
| others: | 254ms |
| total: | 579ms |
