ORA-00600 при выгрузке дампа
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ORACLE 8.1.7 Выгрузка дампа прерывается с ошибкой: About to export specified users ... . exporting pre-schema procedural objects and actions . exporting foreign function library names for user BBK EXP-00008: ORACLE error 600 encountered ORA-00600: internal error code, arguments: [25012], [0], [257], [], [], [], [], [] EXP-00000: Export terminated unsuccessfully Та же ошибка (ORA-00600: internal error code, arguments: [25012], [0], [257], [], [], [], [], []) возникает при попытке открыть объекты (My objects) в PL/SQL Developer 5.0.0474 ... |
| 30.05.2003, 10:34:58 |
Obtain the trace files and alert.log for this error and log an iTAR with Oracle Support Services for diagnosis. Known Issues: Bug 2531519 CREATE INDEX (WITH PARALLEL) FAILS WITH ORA-600[25012] Fixed in 9.2.0.3 Bug 1788648 ORA-00600[25012] [2147483647] SELECTING FROM V$ TABLES Note that the argument [2147483647] indicates you have encountered this issue. Fixed in releases 8.1.7.3, 9.0.1.1 and 9.2.0.1 Bug 2212389 ORA-600 [25012] can be reported when a cursor with BINDS gets aged out and then reloaded Introduced in Oracle 9i fixed in releases 9.0.1.4 and 9.2.0.1 Bug 1678963 ORA-600[25012]/ORA-600[4142] possible on TRUNCATE of a table with a CLOB column. fixed in releases 8.1.7.2 and 9i Bug 1788648 ORA-600 [25012] [2147483647] possible selecting from certain V$ views. Fixed in releases 9.0.1.1 ... |
| 30.05.2003, 10:47:47 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1990267]: |
163ms |
41ms |
| others: | 202ms |
| total: | 446ms |
