Как подключить USERS01.DBF к другой базе ?
говорит, что не тот идентификатор базы... ... |
| 26.06.2003, 18:47:31 |
Sorry, но никак. If database, USERS01.DBF belongs to, is still intact, export objects residing in USERS01.DBF and import them into "другой базе". SY ... |
| 26.06.2003, 19:06:37 |
>Sorry, но никак. Why not to use transportable tablespace feature? ... |
| 26.06.2003, 21:10:25 |
> Why not to use transportable tablespace feature? Based on "говорит, что не тот идентификатор базы..." I assume USERS01.DBF already exists and I do not think it is transportable - if it would, Владимир would not ask the question. But you are right, if version allows you could create a transportable tablespace. However, list of restriction on transportable tablespaces is quite long so you should be very carefull with design. SY ... |
| 26.06.2003, 21:35:39 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1989777]: |
189ms |
29ms |
25ms |
| others: | 192ms |
| total: | 466ms |
