Помогите пожалуйста с oracle 11g realise 2
год назад по инструкции поставил оракл сервер c клиентом на windows 8 x64. все работало до не давнего времени. вылетает ошибка TNS-12560: TNS:protocol adapter error при попытке подключиться через sqlplus. Служба OracleServiceXE запущена и работает. _______________________________________ listener.ora # listener.ora Network Configuration File: C:\Oracle\x64\NETWORK\ADMIN\listener.ora # Generated by Oracle configuration tools. SID_LIST_LISTENER = (SID_LIST = (SID_DESC = (SID_NAME = CLRExtProc) (ORACLE_HOME = C:\oracle\x64) (PROGRAM = extproc) (ENVS = "EXTPROC_DLLS=ONLY:C:\oracle\x64\bin\oraclr11.dll") ) (SID_DESC = (GLOBAL_DBNAME = XE) (ORACLE_HOME = C:\oracle\x64) (SID_NAME = XE) ) ) LISTENER = (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = PKPVDSASTOSP1)(PORT = 1521)) ) ___________________________________________________________________________________________ sqlnet.ora # sqlnet.ora Network Configuration File: C:\Oracle\x64\NETWORK\ADMIN\sqlnet.ora # Generated by Oracle configuration tools. # This file is actually generated by netca. But if customers choose to # install "Software Only", this file wont exist and without the native # authentication, they will not be able to connect to the database on NT. SQLNET.AUTHENTICATION_SERVICES= (NONE) NAMES.DIRECTORY_PATH= (EZCONNECT, TNSNAMES, HOSTNAME) _________________________________________________________________________________________________ tnsnames.ora # tnsnames.ora Network Configuration File: C:\Oracle\x64\NETWORK\ADMIN\tnsnames.ora # Generated by Oracle configuration tools. XE = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = PKPVDSASTOSP1)(PORT = 1521)) ) (CONNECT_DATA = (SERVER = DEDICATED) (SERVICE_NAME = XE) ) ) ORACLR_CONNECTION_DATA = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1521)) ) (CONNECT_DATA = (SID = CLRExtProc) (PRESENTATION = RO) ) ) ____________________________________________ помогите пожалуйста. сроки поджимают. в чем причина что так резко все отказало.как исправить?заранее благодарен ... |
| 20.06.2016, 09:51:54 |
MITR2521TNS-12560: TNS:protocol adapter error при попытке подключиться через sqlplus. Покажите, как соединяетесь. Покажите lsnrctl status. ... |
| 20.06.2016, 10:31:32 |
Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=PKPVDSASTOSP1)(PORT=1521 ))) STATUS of the LISTENER ------------------------ Alias LISTENER Version TNSLSNR for 64-bit Windows: Version 11.2.0.1.0 - Produ ction Start Date 20-JUN-2016 10:25:44 Uptime 0 days 0 hr. 21 min. 4 sec Trace Level off Security ON: Local OS Authentication SNMP OFF Listener Parameter File C:\Oracle\x64\network\admin\listener.ora Listener Log File c:\oracle\diag\tnslsnr\PKPVDSASTOSP1\listener\alert\lo g.xml Listening Endpoints Summary... (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=PKPVDSASTOSP1)(PORT=1521))) Services Summary... Service "CLRExtProc" has 1 instance(s). Instance "CLRExtProc", status UNKNOWN, has 3 handler(s) for this service... Service "XE" has 2 instance(s). Instance "XE", status UNKNOWN, has 1 handler(s) for this service... Instance "xe", status READY, has 1 handler(s) for this service... Service "XEXDB" has 1 instance(s). Instance "xe", status READY, has 1 handler(s) for this service... The command completed successfully ... |
| 20.06.2016, 10:51:23 |
dmdmdm, Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=PKPVDSASTOSP1)(PORT=1521 ))) STATUS of the LISTENER ------------------------ Alias LISTENER Version TNSLSNR for 64-bit Windows: Version 11.2.0.1.0 - Produ ction Start Date 20-JUN-2016 10:25:44 Uptime 0 days 0 hr. 21 min. 4 sec Trace Level off Security ON: Local OS Authentication SNMP OFF Listener Parameter File C:\Oracle\x64\network\admin\listener.ora Listener Log File c:\oracle\diag\tnslsnr\PKPVDSASTOSP1\listener\alert\lo g.xml Listening Endpoints Summary... (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=PKPVDSASTOSP1)(PORT=1521))) Services Summary... Service "CLRExtProc" has 1 instance(s). Instance "CLRExtProc", status UNKNOWN, has 3 handler(s) for this service... Service "XE" has 2 instance(s). Instance "XE", status UNKNOWN, has 1 handler(s) for this service... Instance "xe", status READY, has 1 handler(s) for this service... Service "XEXDB" has 1 instance(s). Instance "xe", status READY, has 1 handler(s) for this service... The command completed successfully вся проблема не конектиться к базе щас попробывал просто запустить sqlplus c правами администратора и логин пароль system system запустился. Но при выполнении connect sys/<пароль>@<база> as sysdba пишет ORA-01031: insufficient privileges. ... |
| 20.06.2016, 11:01:55 |
MITR2521, Попробуйте закомментировать все строки в sqlnet.ora, зачастую помогает. ... |
| 20.06.2016, 11:30:24 |
UDW, дело в том что стоит и клтиент и сервер на одной машине. и там и там закоментировать? ... |
| 20.06.2016, 11:34:21 |
MITR2521год назад по инструкции поставил оракл сервер c клиентом на windows 8 x64. все работало до не давнего времени. вылетает ошибка TNS-12560: TNS:protocol adapter error при попытке подключиться через sqlplus. Служба OracleServiceXE запущена и работает. Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. помогите пожалуйста. сроки поджимают. в чем причина что так резко все отказало.как исправить?заранее благодарен ... |
| 20.06.2016, 11:47:35 |
а что говорит tnsping XE? ... |
| 20.06.2016, 11:47:54 |
MITR2521 Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. ... |
| 20.06.2016, 11:48:04 |
MITR2521dmdmdm, Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. вся проблема не конектиться к базе щас попробывал просто запустить sqlplus c правами администратора и логин пароль system system запустился. Но при выполнении connect sys/<пароль>@<база> as sysdba пишет ORA-01031: insufficient privileges. ... |
| 20.06.2016, 11:48:43 |
SQL*PlusMITR2521 Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. так подскажите пожалуйста что делать то поподробнее. я с базыми данных как таковыми ни когда не сталкивался. что мне щас нужно сделать. если можно поподробнее. ... |
| 20.06.2016, 11:52:34 |
MITR2521, у тебя 2 инстанса под Код: plsql 1. , разбирайся почему два одинаковых по SID-у запущены!? ... |
| 20.06.2016, 11:55:21 |
MITR2521, сколько файлов init.ora в папке /dbs/ ... |
| 20.06.2016, 11:57:28 |
Casper_oraMITR2521, у тебя 2 инстанса под Код: plsql 1. , разбирайся почему два одинаковых по SID-у запущены!? какие приблизительно могут быть причины?(самые распространенные) ... |
| 20.06.2016, 11:57:41 |
Это не 2 инстанса. Статус UNKNOWN - это от статической регистрации, статус READY - от динамической. ... |
| 20.06.2016, 11:59:07 |
tru55, Внимательно смотри на листенер: Код: plsql 1. 2. 3. а в начале Код: plsql 1. Два инстанса в статусе READY!!! К какому он коннектится? ... |
| 20.06.2016, 12:00:55 |
Casper_oraMITR2521, сколько файлов init.ora в папке /dbs/ один ... |
| 20.06.2016, 12:01:59 |
Casper_oratru55, Внимательно смотри на листенер: Код: plsql 1. 2. 3. а в начале Код: plsql 1. Два инстанса в статусе READY!!! К какому он коннектится? как это определить? ... |
| 20.06.2016, 12:04:13 |
MITR2521, Q.Tarantino задавал вопрос о tnsping-е, проверь что он отображает. ... |
| 20.06.2016, 12:35:41 |
Casper_oraMITR2521, Q.Tarantino задавал вопрос о tnsping-е, проверь что он отображает. C:\Users\TOSP2\Desktop>tnsping XE TNS Ping Utility for 32-bit Windows: Version 11.2.0.1.0 - Production on 20-ИЮН-2 016 12:36:38 Copyright (c) 1997, 2010, Oracle. All rights reserved. Использованы файлы параметров: C:\Oracle\x32\network\admin\sqlnet.ora Использован адаптер TNSNAMES для разрешения псевдонима Выполнена попытка связи с (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = PKPV DSASTOSP1)(PORT = 1521)) (CONNECT_DATA = (SERVER = DEDICATED) (SERVICE_NAME = XE ))) OK (10 мсек) ... |
| 20.06.2016, 12:39:29 |
MITR2521Использован адаптер TNSNAMES для разрешения псевдонима Выполнена попытка связи с (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = PKPV DSASTOSP1)(PORT = 1521)) (CONNECT_DATA = (SERVER = DEDICATED) (SERVICE_NAME = XE ))) OK (10 мсек) ну и под тем же пользователем sqlplus user/passwd@XE подключается? имя и пароль обычного юзера, без sysdba. не будем его пока трогать. ... |
| 20.06.2016, 13:10:16 |
Q.TarantinoMITR2521Использован адаптер TNSNAMES для разрешения псевдонима Выполнена попытка связи с (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = PKPV DSASTOSP1)(PORT = 1521)) (CONNECT_DATA = (SERVER = DEDICATED) (SERVICE_NAME = XE ))) OK (10 мсек) ну и под тем же пользователем sqlplus user/passwd@XE подключается? имя и пароль обычного юзера, без sysdba. не будем его пока трогать. под тем же виндовым пользователем, хотел сказать. ... |
| 20.06.2016, 13:10:44 |
Casper_oratru55, Внимательно смотри на листенер: ... Два инстанса в статусе READY!!! К какому он коннектится? Иногда лучше жевать... Коннектится он к сервису XE. При этом у листенера есть статическая регистрация сервиса (в listener.ora) и динамическая - экземпляр зарегистрировался, о чем прямо сообщил коллега tru55. А с учетом MITR2521... щас попробывал просто запустить sqlplus c правами администратора и логин пароль system system запустился. Но при выполнении connect sys/<пароль>@<база> as sysdba пишет ORA-01031: insufficient privileges. можно уверенно говорить, что до экземпляра sqlplus нормально добирается. ... |
| 20.06.2016, 13:16:07 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1888051]: |
80ms |
65ms |
| others: | 218ms |
| total: | 409ms |
