sqlplus / as sysdba
Всем привет. Не получается законнектиться в sqlplus, если подключаюсь так: sqlplus / as sysdba (получаю ошибку: ORA-12560: TNS:ошибка адаптера протокола), но если как sqlplus sys/password@orcl as sysdba - подключаюсь без проблем. Содержимое tnsnames.ora: # tnsnames.ora Network Configuration File: E:\app\israel\product\12.1.0\dbhome_1\network\admin\tnsnames.ora # Generated by Oracle configuration tools. LISTENER_ORCL = (ADDRESS = (PROTOCOL = TCP)(HOST = localhost)(PORT = 1521)) ORACLR_CONNECTION_DATA = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1521)) ) (CONNECT_DATA = (SID = CLRExtProc) (PRESENTATION = RO) ) ) ORCL = (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = localhost)(PORT = 1521)) (CONNECT_DATA = (SERVER = DEDICATED) (SERVICE_NAME = orcl) ) ) ... |
| 23.12.2016, 15:37 |
sqlplus / as sysdba
# listener.ora Network Configuration File: E:\app\israel\product\12.1.0\dbhome_1\network\admin\listener.ora # Generated by Oracle configuration tools. SID_LIST_LISTENER = (SID_LIST = (SID_DESC = (SID_NAME = CLRExtProc) (ORACLE_HOME = E:\app\israel\product\12.1.0\dbhome_1) (PROGRAM = extproc) (ENVS = "EXTPROC_DLLS=ONLY:E:\app\israel\product\12.1.0\dbhome_1\bin\oraclr12.dll") ) ) LISTENER = (DESCRIPTION_LIST = (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = localhost)(PORT = 1521)) (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1521)) ) ) ... |
| 23.12.2016, 15:38 |
sqlplus / as sysdba
# sqlnet.ora Network Configuration File: E:\app\israel\product\12.1.0\dbhome_1\network\admin\sqlnet.ora # Generated by Oracle configuration tools. # This file is actually generated by netca. But if customers choose to # install "Software Only", this file wont exist and without the native # authentication, they will not be able to connect to the database on NT. SQLNET.AUTHENTICATION_SERVICES= (NTS) NAMES.DIRECTORY_PATH= (TNSNAMES, EZCONNECT) ... |
| 23.12.2016, 15:38 |
sqlplus / as sysdba
Помогите, пожалуйста, разобраться в чем проблема. ... |
| 23.12.2016, 15:39 |
sqlplus / as sysdba
israelshamirПомогите, пожалуйста, разобраться в чем проблема. драйвер переустанови. ... |
| 23.12.2016, 15:44 |
sqlplus / as sysdba
mefman, instant client что ли? ... |
| 23.12.2016, 16:02 |
sqlplus / as sysdba
israelshamir, Версия ОС? ORACLE_SID? ... |
| 23.12.2016, 16:26 |
sqlplus / as sysdba
israelshamirПомогите, пожалуйста, разобраться в чем проблема. ORA_DBA + ORACLE_HOME, PATH, ORACLE_SID ... |
| 23.12.2016, 17:08 |
sqlplus / as sysdba
Alexey Zhidkov, OS: windows 8.1 я тут в винде в user account control settings установил ползунок в never notify и у меня отвалился сервис oracleoradb12home1tnslistener, поставил ползунок обратно на default, пытаюсь запустить сервис - получаю "The oracleoradb12home1tnslistener service on Local Computer started and then stopped. Some services stop automatically if they are not in use by other services or programs" oracle_sid сейчас не могу посмотреть ... |
| 23.12.2016, 17:26 |
sqlplus / as sysdba
Vadim Lejnin+ ORACLE_HOME, PATH, ORACLE_SID ты невнимателен. по TNS у него подключение проходит. israelshamirOS: windows 8.1 надо будет глянуть. меня берут сомнения что оракл сертифицирован под данную ОС :) ... |
| 23.12.2016, 17:42 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1886756]: |
182ms |
68ms |
| others: | 204ms |
| total: | 518ms |
