ORACLEXE\ORADATA\XE\CONTROL.DBF (при сбое жестких дисков не востоновливаеться DBF файлы)
добрый день, сам в этом деле новичок помогите разобраться с этой проблемы при сбое жестких дисков не поднимается БД ORACLEXE\ORADATA\XE\CONTROL.DBF SQL> startup ORACLE instance started. Total System Global Area 805306368 bytes Fixed Size 1289996 bytes Variable Size 209715444 bytes Database Buffers 591396864 bytes Redo Buffers 2904064 bytes ORA-00204: error in reading (block 275, # blocks 1) of control file ORA-00202: control file: 'C:\ORACLEXE\ORADATA\XE\CONTROL.DBF' ORA-27091: unable to queue I/O ORA-27070: async read/write failed OSD-04006: ReadFile() failure, unable to read from file O/S-Error: (OS 1117) The request could not be performed because of an I/O device error. SQL> alter database backup controlfile to 'c:\ctrl.bak'; alter database backup controlfile to 'c:\ctrl.bak' * ERROR at line 1: ORA-01507: database not mounted SQL> startup nomouont; SP2-0714: invalid combination of STARTUP options SQL> startup nomount ORA-01081: cannot start already-running ORACLE - shut it down first SQL> shutdown immediate; ORA-01507: database not mounted ORACLE instance shut down. SQL> startup nomount ORACLE instance started. Total System Global Area 805306368 bytes Fixed Size 1289996 bytes Variable Size 209715444 bytes Database Buffers 591396864 bytes Redo Buffers 2904064 bytes SQL> alter database backup controlfile to 'c:\ctrl.bak' 2 ; alter database backup controlfile to 'c:\ctrl.bak' * ERROR at line 1: ORA-01507: database not mounted SQL> alter database mount; alter database mount * ERROR at line 1: ORA-00204: error in reading (block 275, # blocks 1) of control file ORA-00202: control file: 'C:\ORACLEXE\ORADATA\XE\CONTROL.DBF' ORA-27091: unable to queue I/O ORA-27070: async read/write failed OSD-04006: ReadFile() failure, unable to read from file O/S-Error: (OS 1117) The request could not be performed because of an I/O device error. ... |
| 02.01.2017, 20:46 |
востоновливаеться Вырвиглаз. Может, хоть chkdsk для начала прогоните? ... |
| 02.01.2017, 20:52 |
Если данных нет - проще всего переустановить ... |
| 02.01.2017, 20:52 |
Win 2008 server, ... |
| 02.01.2017, 21:00 |
| 02.01.2017, 21:27 |
запустил chkdsk результатов не дал ... |
| 02.01.2017, 21:32 |
Data protection: incapable. Надеюсь, переводчиком сами воспользуетесь. ... |
| 02.01.2017, 21:36 |
нет шансов для запуска бд после таких сбоев ? ... |
| 02.01.2017, 22:04 |
Шансы всегда больше нуля. Вопрос, насколько. Такие же вопросы задают в общетехнических форумах "фотки бы восстановить". Как правило, фотки не стоят усилий по восстановлению. Ваша XE база - еще менее стоит. ... |
| 02.01.2017, 22:11 |
А эти файлы вообще есть, читаются? На картинке вроде RAID1, он должен выдерживать отказ одного диска без проблем совершенно. Если файлы в C:\ORACLEXE\ORADATA\XE видны, то надо 1) остановить базу через shutdown immediate 2) скопировать из этого каталога все файлы на флешку и отложить её в сторону на всякий случай 3) запустить в startup nomount 4) посмотреть какие ещё есть контрольные файлы show parameter control 5) скопировать другой контрольный в C:\ORACLEXE\ORADATA\XE\CONTROL.DBF и попробовать запустится - alter database mount и alter database open ... |
| 02.01.2017, 22:41 |
Нет там больше контрольников, т к судя по задаваемым вопросам XE там по дефаулту А значит один контрольник И скорее всего в no archive mode А т к контрольник один -бд не смонтировать Так и не было ответа,что в бд Может там ничего нет Тогда просто переустановить ... |
| 02.01.2017, 22:54 |
landyНет там больше контрольников, т к судя по задаваемым вопросам XE там по дефаулту А значит один контрольник И скорее всего в no archive mode А т к контрольник один -бд не смонтировать Так и не было ответа,что в бд Может там ничего нет Тогда просто переустановить Oracle DOC CREATE CONTROLFILE Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. Проверьте имена файлов и размер redo p.s. пересоздать controlfile, это только начало... хотя если все остальное цело, то может взлететь ... |
| 03.01.2017, 00:20 |
пример кривоватый взял, лучще такие параметры: Код: plsql 1. 2. 3. 4. 5. ... |
| 03.01.2017, 00:23 |
спасибо за комментарии сейчас попробую ... |
| 03.01.2017, 05:21 |
Лучше не надо Попытайся для начала восстановить работоспособность RAID (возможно, диск воткнуть или со старым перестроить) ... |
| 03.01.2017, 05:27 |
теперь после всего восстановление ИТП. выдал такую информацию SQL> startup ORACLE instance started. Total System Global Area 805306368 bytes Fixed Size 1289996 bytes Variable Size 209715444 bytes Database Buffers 591396864 bytes Redo Buffers 2904064 bytes ORA-00227: corrupt block detected in control file: (block 275, # blocks 1) ORA-00202: control file: 'C:\ORACLEXE\ORADATA\XE\CONTROL.DBF' ... |
| 03.01.2017, 09:10 |
максим2016теперь после всего восстановление ИТП. выдал такую информацию SQL> startup ORACLE instance started. Total System Global Area 805306368 bytes Fixed Size 1289996 bytes Variable Size 209715444 bytes Database Buffers 591396864 bytes Redo Buffers 2904064 bytes ORA-00227: corrupt block detected in control file: (block 275, # blocks 1) ORA-00202: control file: 'C:\ORACLEXE\ORADATA\XE\CONTROL.DBF' А вот теперь попробуйте пересоздать controlfile ... |
| 03.01.2017, 11:50 |
Возможно, я не в тему, но может автору будет проще - в 10XE по умолчанию два редолога по 50 мегабайт, лежат по пути типа C:\oraclexe\app\oracle\flash_recovery_area\XE\ONLINELOG, расширение .LOG ... |
| 03.01.2017, 14:55 |
спасибо большое за комментарии, придется диски отдавать специалисту по восстановлению тему можно закрыть благодарю ... |
| 03.01.2017, 15:09 |
start [/forum/search_topic.php?author=_DenZ__&author_mode=last_topics&do_search=1]: |
178ms |
33ms |
| others: | 446ms |
| total: | 711ms |
