ORA-12154 tns could not resolve the connect identifier specified
Помогите плз. Есть программка написанная на Delphi, надо законнектиться к базе Оракл. в файлике для .exe прописано [RDBMS] DB_TYPE=ORACLE ConnectionString=Provider=MSDAORA.1;Password=хххх;User ID=CB;Data Source=HD В tnsnames.ora прописан путь к базе такой: HD= (DESCRIPTION= (ADDRESS= (PROTOCOL=TCP) (HOST=10.88.100.65) (PORT=1521) ) (CONNECT_DATA= (SERVICE_NAME=hd) ) ) В sqlnet.ora: # sqlnet.ora Network Configuration File: C:\oracle\product\11.2.0\client_1\network\admin\sqlnet.ora # Generated by Oracle configuration tools. # This file is actually generated by netca. But if customers choose to # install "Software Only", this file wont exist and without the native # authentication, they will not be able to connect to the database on NT. SQLNET.AUTHENTICATION_SERVICES= (NTS) NAMES.DIRECTORY_PATH= (TNSNAMES, EZCONNECT) В listener.ora: # listener.ora Network Configuration File: C:\oracle\product\11.2.0\client_1\network\admin\listener.ora # Generated by Oracle configuration tools. LISTENER = (DESCRIPTION_LIST = (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = ODI_1.corp)(PORT = 1521)) (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC15)) ) ) ADR_BASE_LISTENER = C:\oracle При запуске выходит ошибка ORA-12154 tns could not resolve the connect identifier specified, кто нибудь сталкивался? ... |
| 06.01.2017, 14:16 |
Для начала - 1-я ссылка в поиске по "MSDAORA ORA-12154". ... |
| 06.01.2017, 18:46 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1886705]: |
139ms |
25ms |
| others: | 204ms |
| total: | 407ms |
