Поврежденные блоки. ORA-19566.
Коллеги подскажите. Сетевики при бэкапе на ленточку прислали ошибку, которая не дает делать бэкапы RMAN-03009: failure of backup command on ch1 channel at 02/28/2017 19:47:59 ORA-19566: exceeded limit of 0 corrupt blocks for file E:\ORADATA\PRODCAR\UNDOTBS01.DBF continuing other job steps, job failed will not be re-run channel ch1: starting full datafile backup set channel ch1: specifying datafile(s) in backup set including current control file in backup set including current SPFILE in backup set channel ch1: starting piece 1 at 28-FEB-17 channel ch1: finished piece 1 at 28-FEB-17 piece handle=db_PRODCAR_6197_1_937165679 tag=TAG20170228T193312 comment=API Version 2.0,MMS Version 6.3.0.0 channel ch1: backup set complete, elapsed time: 00:00:03 released channel: ch1 RMAN-00571: =========================================================== RMAN-00569: =============== ERROR MESSAGE STACK FOLLOWS =============== RMAN-00571: =========================================================== Пробовал blockrecover corruption list не помогло. Что делать? Менять tablespace? Посоветуйте. ... |
| 21.03.2017, 11:55 |
Восстанови его с бэкапа (offline, restore, recover, online) Лучше в другое место ... |
| 21.03.2017, 12:14 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1886245]: |
68ms |
58ms |
| others: | 236ms |
| total: | 431ms |
