установка oracle 11 на sles 10.1
при запуске инсталятора вылетает следующая ошибка: авторoracle$ runInstaller When I starteded runInstaller, the following error message was displayed: Checking monitor: must be configured to display at least 256 colors Failed <<<< >>> Could not execute auto check for display colors using command /usr/X11R6/bin/xdpyinfo. Check if the DISPLAY variable is set. DISPLAY=192.168.0.7:0.0; export DISPLAY не помог. пробовал поставить недостающие пакеты как указано тут , иксы вообще перестали загружаться. ... |
| 18.04.2008, 18:33 |
Код: plaintext 1. ... |
| 18.04.2008, 18:57 |
Relic Hunter Код: plaintext 1. пробую так oracle@navigadmin:/home/navadmin/database> echo $DISPLAY 192.168.0.7:0.0 oracle@navigadmin:/home/navadmin/database> xhost + 192.168.0.7 xhost: unable to open display "192.168.0.7:0.0" oracle@navigadmin:/home/navadmin/database> ./runInstaller Starting Oracle Universal Installer... Checking Temp space: must be greater than 120 MB. Actual 511398 MB Passed Checking swap space: must be greater than 150 MB. Actual 2047 MB Passed Checking monitor: must be configured to display at least 256 colors >>> Could not execute auto check for display colors using command /usr/X11R6/bin/xdpyinfo. Check if the DISPLAY variable is set. Failed <<<< Some requirement checks failed. You must fulfill these requirements before continuing with the installation,at which time they will be rechecked. Continue? (y/n) [n] y Rechecking installer requirements.... Preparing to launch Oracle Universal Installer from /tmp/OraInstall2008-04-21_11-49-40AM. Please wait ... oracle@navigadmin:/home/navadmin/database> дальше вываливается явовское исключение Exception in thread "main" java.lang.InternalError: Can't connect to X11 window server using '192.168.0.7:0.0' as the value of the DISPLAY variable. at sun.awt.X11GraphicsEnvironment.initDisplay(Native Method) at sun.awt.X11GraphicsEnvironment.access$000(X11GraphicsEnvironment.java:53) at sun.awt.X11GraphicsEnvironment$1.run(X11GraphicsEnvironment.java:142) at java.security.AccessController.doPrivileged(Native Method) at sun.awt.X11GraphicsEnvironment.<clinit>(X11GraphicsEnvironment.java:131) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Class.java:164) at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(GraphicsEnvironment.java:68) at java.awt.Window.init(Window.java:270) at java.awt.Window.<init>(Window.java:318) at java.awt.Frame.<init>(Frame.java:419) at oracle.ewt.popup.PopupFrame.<init>(Unknown Source) at oracle.ewt.lwAWT.BufferedFrame.<init>(Unknown Source) at oracle.sysman.oio.oioc.OiocOneClickInstaller.<init>(OiocOneClickInstaller.java:328) at oracle.sysman.oio.oioc.OiocOneClickInstaller.<clinit>(OiocOneClickInstaller.java:168) ... |
| 21.04.2008, 11:53 |
X-server поднять не пробовал? Хотя мо;но и по другому, исп. например Xming ... |
| 21.04.2008, 12:33 |
SalX-server поднять не пробовал? Хотя мо;но и по другому, исп. например Xming запускаю инсталятор в консоли, открытой в иксах. ставлю, по этому мануалу , как раз для нужных версий оракла и sles. До runInstaller выполнял все пункты. ... |
| 21.04.2008, 12:47 |
Разберитесь вот с этим oracle@navigadmin:/home/navadmin/database> xhost + 192.168.0.7 xhost: unable to open display "192.168.0.7:0.0" ... |
| 21.04.2008, 12:50 |
jan2aryРазберитесь вот с этим oracle@navigadmin:/home/navadmin/database> xhost + 192.168.0.7 xhost: unable to open display "192.168.0.7:0.0" Спасибо за наводку. Поборол правкой /etc/X11/xdm/Xaccess и установкой DISPLAY=:0; export DISPLAY Инсталятор запустился. ... |
| 21.04.2008, 13:33 |
Burzum Поборол правкой /etc/X11/xdm/Xaccess и установкой DISPLAY=:0; export DISPLAY Возникла точно такая же проблема а что поправили в Xaccess? * для всех хостов? сделал DISPLAY=:0; export DISPLAY все равно ругается хелп ... |
| 05.02.2010, 12:31 |
Уже что только не пробовал. Ни как не помогает. ... |
| 05.02.2010, 12:45 |
AlexGruУже что только не пробовал. Ни как не помогает. А у вас что получается после выполнения этих команд: Код: plaintext 1. ... |
| 05.02.2010, 12:59 |
Спасибо за желание помочь. Но помогла просто перезагрузка. ... |
| 05.02.2010, 13:03 |
AlexGru, Я на убунте сделал "в лоб": запустил xterm и в нем выставил переменную DISPLAY. Из этого же xterm запустил и инсталятор. ... |
| 05.02.2010, 13:09 |
Добрый день! Подскажите, как мне побороть ошибку дисплея ./runInstaller Starting Oracle Universal Installer... Checking temp space: 25 MB available, 500 MB required. Failed <<<< Checking swap space: must be greater than 150 MB. Actual 65535 MB Passed Checking monitor: must be configured to display at least 256 colors >>> Could not execute auto check for display colors using command /usr/bin/xdpyinfo. Check if the DISPLAY variable is set. Failed <<<< Some requirement checks failed. You must fulfill these requirements before continuing with the installation, Continue? (y/n) [n] y >>> Ignoring required pre-requisite failures. Continuing... Preparing to launch Oracle Universal Installer from /tmp/OraInstall2017-04-14_01-06-38PM. Please wait ..../runInstaller: line 247: 552 Segmentation fault $CMDDIR/install/.oui $* -J-Doracle.install.setup.workDir=$CWDDIR -J-D${CVU_OS_SETTINGS} -nocleanUpOnExit Выставила export DISPLAY=localhost:0.0 , всё равно ошибка ... |
| 14.04.2017, 15:08 |
novaya_90, Может, с этого стоит начать? авторChecking temp space: 25 MB available, 500 MB required. Failed <<<< ... |
| 14.04.2017, 15:26 |
londinium, поправлено, но не это первопричина. ... |
| 14.04.2017, 15:32 |
novaya_90londinium, поправлено, но не это первопричина. иксы на сервере или на рабочей станции? ... |
| 14.04.2017, 15:44 |
Q.Tarantino, Спасиб, не хватало x11 ... |
| 14.04.2017, 16:24 |
novaya_90, понял, что не хватает X11, почитал весь этот контент и видео посмотрел, НО так и не понял каким образом для Linux dboracle01 3.10.0-514.26.2.el7.x86_64 #1 SMP Tue Jul 4 15:04:05 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux решить проблему Error: Can't open display: ... |
| 07.08.2017, 08:05 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1885486]: |
174ms |
58ms |
| others: | 206ms |
| total: | 493ms |
