Как правильно такое называется? Коллекции?Что искать, чтобы понять как правильно работать?
Есть авторCREATE OR REPLACE TYPE DEKANAT."OBJ_PLAN_STRING3" AS OBJECT (index_num NUMBER(10), alevel NUMBER(10), id NUMBER(10), discipline_id NUMBER(10), code VARCHAR2(32), title VARCHAR2(256), dic_ed_discipline_id NUMBER(10), dic_ed_discipline_type_id NUMBER(10), title_help VARCHAR2(200), dic_ed_add_disc_type NUMBER(10), edit_button VARCHAR2(50), add_button VARCHAR2(50), del_button VARCHAR2(50), spec_button VARCHAR2(50), gost_cnt VARCHAR2(100), audit_cnt NUMBER(7, 2), vneaudit_cnt NUMBER(7, 2), hours_lec NUMBER(7, 2), hours_lab NUMBER(7, 2), hours_pract NUMBER(7, 2), hours_sam NUMBER(7, 2), hours_ksr NUMBER(7, 2), hours_audit NUMBER(7, 2), hours_vneaudit NUMBER(7, 2), hours_all NUMBER(7, 2), hours_gost NUMBER(7, 2), exist_descendants NUMBER(10), semester1_id NUMBER(10), hs1_lec NUMBER(7, 2), hs1_lab NUMBER(7, 2), hs1_pract NUMBER(7, 2), hs1_sam NUMBER(7, 2), hs1_ksr NUMBER(7, 2), semester2_id NUMBER(10), hs2_lec NUMBER(7, 2), hs2_lab NUMBER(7, 2), hs2_pract NUMBER(7, 2), hs2_sam NUMBER(7, 2), hs2_ksr NUMBER(7, 2), rep_kursovik VARCHAR2(512), rep_offset VARCHAR2(512), rep_exam VARCHAR2(512), rep_examoffset VARCHAR2(512), rep_contr_work VARCHAR2(512), hs1_zet NUMBER(7, 2), hs2_zet NUMBER(7, 2), zet_min NUMBER(10, 2), zet_max NUMBER(10, 2), zet NUMBER(10, 2), DIC_ED_FGOS_GEN NUMBER(10), TYPE_EDUCATION_ID NUMBER(10), rep_zachet_s_ocenkoy VARCHAR2(512), hours_inter_form NUMBER(7, 2)); Затем авторCREATE OR REPLACE TYPE DEKANAT.TBL_PLAN_STRING3 AS TABLE OF DEKANAT.OBJ_PLAN_STRING3; в PL\SQL авторDECLARE table_plan tbl_plan_string3; ... BEGIN table_plan:=tbl_plan_string3(); FOR tree_cur_rec IN tree_cur LOOP table_plan.EXTEND(1); table_plan(I):=obj_plan_string3 ( value1, value2... valuen); END LOOPl END ... |
| 21.08.2017, 10:30 |
| 21.08.2017, 10:46 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1885394]: |
169ms |
29ms |
| others: | 233ms |
| total: | 474ms |
