ORA-01033 oracle initialization or shutdown in progress
Прошу помощи у вас, ветеранов и хорошо знающих данную тему. Выходит сообщение об ошибке: ORA-01033 oracle initialization or shutdown in progress при подключении к ЛЮБОМУ пользователю БД. Сервер локальный. На машине, на которой запускается TOAD. Разбираюсь я в этом очень плохо. Вот логи (часть): admin/xe/bdump/alert_xe.log ORA-322 signalled during: alter database open... Thu Sep 10 12:35:01 2015 db_recovery_file_dest_size of 10240 MB is 0.98% used. This is a user-specified limit on the amount of space that will be used by this database for recovery-related files, and does not reflect the amount of space available in the underlying filesystem or ASM diskgroup. Dump file c:\oraclexe\app\oracle\admin\xe\bdump\alert_xe.log Sat Sep 12 18:06:16 2015 ORACLE V10.2.0.1.0 - Production vsnsta=0 vsnsql=14 vsnxtr=3 Windows NT Version V6.1 Service Pack 1 CPU : 4 - type 586, 2 Physical Cores Process Affinity : 0x00000000 Memory (Avail/Total): Ph:3150M/3988M, Ph+PgF:7139M/7974M, VA:3969M/4095M Sat Sep 12 18:06:16 2015 Starting ORACLE instance (normal) LICENSE_MAX_SESSION = 0 LICENSE_SESSIONS_WARNING = 0 Picked latch-free SCN scheme 2 Using LOG_ARCHIVE_DEST_10 parameter default value as USE_DB_RECOVERY_FILE_DEST Autotune of undo retention is turned on. IMODE=BR ILAT =10 LICENSE_MAX_USERS = 0 SYS auditing is disabled ksdpec: called for event 13740 prior to event group initialization Starting up ORACLE RDBMS Version: 10.2.0.1.0. System parameters with non-default values: sessions = 49 __shared_pool_size = 201326592 __large_pool_size = 4194304 __java_pool_size = 4194304 __streams_pool_size = 0 spfile = C:\ORACLEXE\APP\ORACLE\PRODUCT\10.2.0\SERVER\DBS\SPFILEXE.ORA sga_target = 805306368 control_files = C:\ORACLEXE\ORADATA\XE\CONTROL.DBF __db_cache_size = 591396864 compatible = 10.2.0.1.0 db_recovery_file_dest = C:\oraclexe\app\oracle\flash_recovery_area db_recovery_file_dest_size= 10737418240 undo_management = AUTO undo_tablespace = UNDO remote_login_passwordfile= EXCLUSIVE dispatchers = (PROTOCOL=TCP) (SERVICE=XEXDB) shared_servers = 4 job_queue_processes = 4 audit_file_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\ADUMP background_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\BDUMP user_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\UDUMP core_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\CDUMP db_name = XE open_cursors = 300 os_authent_prefix = pga_aggregate_target = 268435456 PSP0 started with pid=3, OS id=2768 MMAN started with pid=4, OS id=2772 DBW0 started with pid=5, OS id=2776 LGWR started with pid=6, OS id=2780 CKPT started with pid=7, OS id=2784 SMON started with pid=8, OS id=2788 RECO started with pid=9, OS id=2792 CJQ0 started with pid=10, OS id=2796 MMON started with pid=11, OS id=2800 MMNL started with pid=12, OS id=2804 Sat Sep 12 18:06:21 2015 starting up 1 dispatcher(s) for network address '(ADDRESS=(PARTIAL=YES)(PROTOCOL=TCP))'... starting up 4 shared server(s) ... Oracle Data Guard is not available in this edition of Oracle. PMON started with pid=2, OS id=2764 Sat Sep 12 18:06:23 2015 alter database mount exclusive Setting recovery target incarnation to 2 Sat Sep 12 18:06:30 2015 Successful mount of redo thread 1, with mount id 2771417055 Sat Sep 12 18:06:30 2015 Database mounted in Exclusive Mode Completed: alter database mount exclusive Sat Sep 12 18:06:30 2015 alter database open Sat Sep 12 18:06:32 2015 Errors in file c:\oraclexe\app\oracle\admin\xe\bdump\xe_lgwr_2780.trc: ORA-00322: log 1 of thread 1 is not current copy ORA-00312: online log 1 thread 1: 'C:\ORACLEXE\APP\ORACLE\FLASH_RECOVERY_AREA\XE\ONLINELOG\O1_MF_1_BLOKOKVT_.LOG' Sat Sep 12 18:06:32 2015 Errors in file c:\oraclexe\app\oracle\admin\xe\bdump\xe_lgwr_2780.trc: ORA-00322: log 1 of thread 1 is not current copy ORA-00312: online log 1 thread 1: 'C:\ORACLEXE\APP\ORACLE\FLASH_RECOVERY_AREA\XE\ONLINELOG\O1_MF_1_BLOKOKVT_.LOG' ORA-322 signalled during: alter database open... Sat Sep 12 18:19:16 2015 db_recovery_file_dest_size of 10240 MB is 0.98% used. This is a user-specified limit on the amount of space that will be used by this database for recovery-related files, and does not reflect the amount of space available in the underlying filesystem or ASM diskgroup. Dump file c:\oraclexe\app\oracle\admin\xe\bdump\alert_xe.log Mon Sep 14 01:52:27 2015 ORACLE V10.2.0.1.0 - Production vsnsta=0 vsnsql=14 vsnxtr=3 Windows NT Version V6.1 Service Pack 1 CPU : 4 - type 586, 2 Physical Cores Process Affinity : 0x00000000 Memory (Avail/Total): Ph:2955M/3988M, Ph+PgF:6925M/7974M, VA:3969M/4095M Mon Sep 14 01:52:27 2015 Starting ORACLE instance (normal) LICENSE_MAX_SESSION = 0 LICENSE_SESSIONS_WARNING = 0 Picked latch-free SCN scheme 2 Using LOG_ARCHIVE_DEST_10 parameter default value as USE_DB_RECOVERY_FILE_DEST Autotune of undo retention is turned on. IMODE=BR ILAT =10 LICENSE_MAX_USERS = 0 SYS auditing is disabled ksdpec: called for event 13740 prior to event group initialization Starting up ORACLE RDBMS Version: 10.2.0.1.0. System parameters with non-default values: sessions = 49 __shared_pool_size = 201326592 __large_pool_size = 4194304 __java_pool_size = 4194304 __streams_pool_size = 0 spfile = C:\ORACLEXE\APP\ORACLE\PRODUCT\10.2.0\SERVER\DBS\SPFILEXE.ORA sga_target = 805306368 control_files = C:\ORACLEXE\ORADATA\XE\CONTROL.DBF __db_cache_size = 591396864 compatible = 10.2.0.1.0 db_recovery_file_dest = C:\oraclexe\app\oracle\flash_recovery_area db_recovery_file_dest_size= 10737418240 undo_management = AUTO undo_tablespace = UNDO remote_login_passwordfile= EXCLUSIVE dispatchers = (PROTOCOL=TCP) (SERVICE=XEXDB) shared_servers = 4 job_queue_processes = 4 audit_file_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\ADUMP background_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\BDUMP user_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\UDUMP core_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\CDUMP db_name = XE open_cursors = 300 os_authent_prefix = pga_aggregate_target = 268435456 MMAN started with pid=4, OS id=2524 DBW0 started with pid=5, OS id=2528 LGWR started with pid=6, OS id=2532 CKPT started with pid=7, OS id=2536 SMON started with pid=8, OS id=2540 RECO started with pid=9, OS id=2544 CJQ0 started with pid=10, OS id=2548 MMON started with pid=11, OS id=2552 MMNL started with pid=12, OS id=2556 Mon Sep 14 01:52:31 2015 starting up 1 dispatcher(s) for network address '(ADDRESS=(PARTIAL=YES)(PROTOCOL=TCP))'... starting up 4 shared server(s) ... Oracle Data Guard is not available in this edition of Oracle. PSP0 started with pid=3, OS id=2520 PMON started with pid=2, OS id=2516 Mon Sep 14 01:52:32 2015 alter database mount exclusive Setting recovery target incarnation to 2 Mon Sep 14 01:52:37 2015 Successful mount of redo thread 1, with mount id 2771439520 Mon Sep 14 01:52:37 2015 Database mounted in Exclusive Mode Completed: alter database mount exclusive Mon Sep 14 01:52:37 2015 alter database open Mon Sep 14 01:52:39 2015 Errors in file c:\oraclexe\app\oracle\admin\xe\bdump\xe_lgwr_2532.trc: ORA-00322: log 1 of thread 1 is not current copy ORA-00312: online log 1 thread 1: 'C:\ORACLEXE\APP\ORACLE\FLASH_RECOVERY_AREA\XE\ONLINELOG\O1_MF_1_BLOKOKVT_.LOG' Mon Sep 14 01:52:39 2015 Errors in file c:\oraclexe\app\oracle\admin\xe\bdump\xe_lgwr_2532.trc: ORA-00322: log 1 of thread 1 is not current copy ORA-00312: online log 1 thread 1: 'C:\ORACLEXE\APP\ORACLE\FLASH_RECOVERY_AREA\XE\ONLINELOG\O1_MF_1_BLOKOKVT_.LOG' ORA-322 signalled during: alter database open... Mon Sep 14 02:06:53 2015 db_recovery_file_dest_size of 10240 MB is 0.98% used. This is a user-specified limit on the amount of space that will be used by this database for recovery-related files, and does not reflect the amount of space available in the underlying filesystem or ASM diskgroup. Mon Sep 14 02:25:36 2015 Starting ORACLE instance (normal) Shutting down instance: further logons disabled Mon Sep 14 02:25:56 2015 Stopping background process CJQ0 Mon Sep 14 02:25:56 2015 Stopping background process MMNL Mon Sep 14 02:25:57 2015 Stopping background process MMON Mon Sep 14 02:25:58 2015 Shutting down instance (immediate) License high water mark = 1 Mon Sep 14 02:25:58 2015 Stopping Job queue slave processes Mon Sep 14 02:25:58 2015 Job queue slave processes stopped Waiting for dispatcher 'D000' to shutdown All dispatchers and shared servers shutdown Mon Sep 14 02:26:01 2015 alter database close normal ORA-1109 signalled during: alter database close normal... Dump file c:\oraclexe\app\oracle\admin\xe\bdump\alert_xe.log Mon Sep 14 02:26:15 2015 ORACLE V10.2.0.1.0 - Production vsnsta=0 vsnsql=14 vsnxtr=3 Windows NT Version V6.1 Service Pack 1 CPU : 4 - type 586, 2 Physical Cores Process Affinity : 0x00000000 Memory (Avail/Total): Ph:1179M/3988M, Ph+PgF:4740M/7974M, VA:3969M/4095M Mon Sep 14 02:26:15 2015 Starting ORACLE instance (normal) LICENSE_MAX_SESSION = 0 LICENSE_SESSIONS_WARNING = 0 Picked latch-free SCN scheme 2 Using LOG_ARCHIVE_DEST_10 parameter default value as USE_DB_RECOVERY_FILE_DEST Autotune of undo retention is turned on. IMODE=BR ILAT =10 LICENSE_MAX_USERS = 0 SYS auditing is disabled ksdpec: called for event 13740 prior to event group initialization Starting up ORACLE RDBMS Version: 10.2.0.1.0. System parameters with non-default values: sessions = 49 __shared_pool_size = 201326592 __large_pool_size = 4194304 __java_pool_size = 4194304 __streams_pool_size = 0 spfile = C:\ORACLEXE\APP\ORACLE\PRODUCT\10.2.0\SERVER\DBS\SPFILEXE.ORA sga_target = 805306368 control_files = C:\ORACLEXE\ORADATA\XE\CONTROL.DBF __db_cache_size = 591396864 compatible = 10.2.0.1.0 db_recovery_file_dest = C:\oraclexe\app\oracle\flash_recovery_area db_recovery_file_dest_size= 10737418240 undo_management = AUTO undo_tablespace = UNDO remote_login_passwordfile= EXCLUSIVE dispatchers = (PROTOCOL=TCP) (SERVICE=XEXDB) shared_servers = 4 job_queue_processes = 4 audit_file_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\ADUMP background_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\BDUMP user_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\UDUMP core_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\CDUMP db_name = XE open_cursors = 300 os_authent_prefix = pga_aggregate_target = 268435456 PMON started with pid=2, OS id=5712 PSP0 started with pid=3, OS id=2396 MMAN started with pid=4, OS id=2612 DBW0 started with pid=5, OS id=6128 LGWR started with pid=6, OS id=2744 CKPT started with pid=7, OS id=2624 SMON started with pid=8, OS id=5292 RECO started with pid=9, OS id=3616 CJQ0 started with pid=10, OS id=4512 MMON started with pid=11, OS id=3712 Mon Sep 14 02:26:15 2015 starting up 1 dispatcher(s) for network address '(ADDRESS=(PARTIAL=YES)(PROTOCOL=TCP))'... MMNL started with pid=12, OS id=5620 Mon Sep 14 02:26:15 2015 starting up 4 shared server(s) ... Oracle Data Guard is not available in this edition of Oracle. Mon Sep 14 02:26:15 2015 alter database mount exclusive Mon Sep 14 02:26:20 2015 Setting recovery target incarnation to 2 Mon Sep 14 02:26:20 2015 Successful mount of redo thread 1, with mount id 2771462791 Mon Sep 14 02:26:20 2015 Database mounted in Exclusive Mode Completed: alter database mount exclusive Mon Sep 14 02:26:20 2015 alter database open Mon Sep 14 02:26:20 2015 Errors in file c:\oraclexe\app\oracle\admin\xe\bdump\xe_lgwr_2744.trc: ORA-00322: log 1 of thread 1 is not current copy ORA-00312: online log 1 thread 1: 'C:\ORACLEXE\APP\ORACLE\FLASH_RECOVERY_AREA\XE\ONLINELOG\O1_MF_1_BLOKOKVT_.LOG' Mon Sep 14 02:26:20 2015 Errors in file c:\oraclexe\app\oracle\admin\xe\bdump\xe_lgwr_2744.trc: ORA-00322: log 1 of thread 1 is not current copy ORA-00312: online log 1 thread 1: 'C:\ORACLEXE\APP\ORACLE\FLASH_RECOVERY_AREA\XE\ONLINELOG\O1_MF_1_BLOKOKVT_.LOG' ORA-322 signalled during: alter database open... Mon Sep 14 02:26:23 2015 Starting ORACLE instance (normal) Mon Sep 14 02:41:23 2015 db_recovery_file_dest_size of 10240 MB is 0.98% used. This is a user-specified limit on the amount of space that will be used by this database for recovery-related files, and does not reflect the amount of space available in the underlying filesystem or ASM diskgroup. Mon Sep 14 02:43:49 2015 Shutting down instance: further logons disabled Mon Sep 14 02:43:49 2015 Stopping background process CJQ0 Mon Sep 14 02:43:49 2015 Stopping background process MMNL Mon Sep 14 02:43:50 2015 Stopping background process MMON Mon Sep 14 02:43:51 2015 Shutting down instance (immediate) License high water mark = 1 Mon Sep 14 02:43:51 2015 Stopping Job queue slave processes Mon Sep 14 02:43:51 2015 Job queue slave processes stopped Waiting for dispatcher 'D000' to shutdown All dispatchers and shared servers shutdown Mon Sep 14 02:43:53 2015 alter database close normal ORA-1109 signalled during: alter database close normal... Dump file c:\oraclexe\app\oracle\admin\xe\bdump\alert_xe.log Mon Sep 14 02:44:13 2015 ORACLE V10.2.0.1.0 - Production vsnsta=0 vsnsql=14 vsnxtr=3 Windows NT Version V6.1 Service Pack 1 CPU : 4 - type 586, 2 Physical Cores Process Affinity : 0x00000000 Memory (Avail/Total): Ph:1001M/3988M, Ph+PgF:4633M/7974M, VA:3969M/4095M Mon Sep 14 02:44:13 2015 Starting ORACLE instance (normal) LICENSE_MAX_SESSION = 0 LICENSE_SESSIONS_WARNING = 0 Picked latch-free SCN scheme 2 Using LOG_ARCHIVE_DEST_10 parameter default value as USE_DB_RECOVERY_FILE_DEST Autotune of undo retention is turned on. IMODE=BR ILAT =10 LICENSE_MAX_USERS = 0 SYS auditing is disabled ksdpec: called for event 13740 prior to event group initialization Starting up ORACLE RDBMS Version: 10.2.0.1.0. System parameters with non-default values: sessions = 49 __shared_pool_size = 201326592 __large_pool_size = 4194304 __java_pool_size = 4194304 __streams_pool_size = 0 spfile = C:\ORACLEXE\APP\ORACLE\PRODUCT\10.2.0\SERVER\DBS\SPFILEXE.ORA sga_target = 805306368 control_files = C:\ORACLEXE\ORADATA\XE\CONTROL.DBF __db_cache_size = 591396864 compatible = 10.2.0.1.0 db_recovery_file_dest = C:\oraclexe\app\oracle\flash_recovery_area db_recovery_file_dest_size= 10737418240 undo_management = AUTO undo_tablespace = UNDO remote_login_passwordfile= EXCLUSIVE dispatchers = (PROTOCOL=TCP) (SERVICE=XEXDB) shared_servers = 4 job_queue_processes = 4 audit_file_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\ADUMP background_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\BDUMP user_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\UDUMP core_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\CDUMP db_name = XE open_cursors = 300 os_authent_prefix = pga_aggregate_target = 268435456 PMON started with pid=2, OS id=2228 PSP0 started with pid=3, OS id=2060 MMAN started with pid=4, OS id=5336 DBW0 started with pid=5, OS id=2160 LGWR started with pid=6, OS id=4384 SMON started with pid=8, OS id=6016 MMNL started with pid=12, OS id=5272 RECO started with pid=9, OS id=3296 Mon Sep 14 02:44:14 2015 starting up 1 dispatcher(s) for network address '(ADDRESS=(PARTIAL=YES)(PROTOCOL=TCP))'... CJQ0 started with pid=10, OS id=5488 MMON started with pid=11, OS id=2956 CKPT started with pid=7, OS id=764 Mon Sep 14 02:44:14 2015 starting up 4 shared server(s) ... Oracle Data Guard is not available in this edition of Oracle. Mon Sep 14 02:44:14 2015 alter database mount exclusive Mon Sep 14 02:44:18 2015 Setting recovery target incarnation to 2 Mon Sep 14 02:44:18 2015 Successful mount of redo thread 1, with mount id 2771432894 Mon Sep 14 02:44:18 2015 Database mounted in Exclusive Mode Completed: alter database mount exclusive Mon Sep 14 02:44:18 2015 alter database open Mon Sep 14 02:44:19 2015 Errors in file c:\oraclexe\app\oracle\admin\xe\bdump\xe_lgwr_4384.trc: ORA-00322: log 1 of thread 1 is not current copy ORA-00312: online log 1 thread 1: 'C:\ORACLEXE\APP\ORACLE\FLASH_RECOVERY_AREA\XE\ONLINELOG\O1_MF_1_BLOKOKVT_.LOG' Mon Sep 14 02:44:19 2015 Errors in file c:\oraclexe\app\oracle\admin\xe\bdump\xe_lgwr_4384.trc: ORA-00322: log 1 of thread 1 is not current copy ORA-00312: online log 1 thread 1: 'C:\ORACLEXE\APP\ORACLE\FLASH_RECOVERY_AREA\XE\ONLINELOG\O1_MF_1_BLOKOKVT_.LOG' ORA-322 signalled during: alter database open... Mon Sep 14 02:44:22 2015 Starting ORACLE instance (normal) Mon Sep 14 02:59:20 2015 db_recovery_file_dest_size of 10240 MB is 0.98% used. This is a user-specified limit on the amount of space that will be used by this database for recovery-related files, and does not reflect the amount of space available in the underlying filesystem or ASM diskgroup. Mon Sep 14 07:18:39 2015 Shutting down instance: further logons disabled Mon Sep 14 07:18:40 2015 Stopping background process MMNL Mon Sep 14 07:18:40 2015 Stopping background process CJQ0 Mon Sep 14 07:18:41 2015 Stopping background process MMON Mon Sep 14 07:18:42 2015 Shutting down instance (immediate) License high water mark = 1 Mon Sep 14 07:18:42 2015 Stopping Job queue slave processes Mon Sep 14 07:18:42 2015 Job queue slave processes stopped Waiting for dispatcher 'D000' to shutdown All dispatchers and shared servers shutdown Mon Sep 14 07:18:44 2015 alter database close normal ORA-1109 signalled during: alter database close normal... Dump file c:\oraclexe\app\oracle\admin\xe\bdump\alert_xe.log Mon Sep 14 07:18:55 2015 ORACLE V10.2.0.1.0 - Production vsnsta=0 vsnsql=14 vsnxtr=3 Windows NT Version V6.1 Service Pack 1 CPU : 4 - type 586, 2 Physical Cores Process Affinity : 0x00000000 Memory (Avail/Total): Ph:883M/3988M, Ph+PgF:4141M/7974M, VA:3969M/4095M Mon Sep 14 07:18:55 2015 Starting ORACLE instance (normal) LICENSE_MAX_SESSION = 0 LICENSE_SESSIONS_WARNING = 0 Picked latch-free SCN scheme 2 Using LOG_ARCHIVE_DEST_10 parameter default value as USE_DB_RECOVERY_FILE_DEST Autotune of undo retention is turned on. IMODE=BR ILAT =10 LICENSE_MAX_USERS = 0 SYS auditing is disabled ksdpec: called for event 13740 prior to event group initialization Starting up ORACLE RDBMS Version: 10.2.0.1.0. System parameters with non-default values: sessions = 49 __shared_pool_size = 201326592 __large_pool_size = 4194304 __java_pool_size = 4194304 __streams_pool_size = 0 spfile = C:\ORACLEXE\APP\ORACLE\PRODUCT\10.2.0\SERVER\DBS\SPFILEXE.ORA sga_target = 805306368 control_files = C:\ORACLEXE\ORADATA\XE\CONTROL.DBF __db_cache_size = 591396864 compatible = 10.2.0.1.0 db_recovery_file_dest = C:\oraclexe\app\oracle\flash_recovery_area db_recovery_file_dest_size= 10737418240 undo_management = AUTO undo_tablespace = UNDO remote_login_passwordfile= EXCLUSIVE dispatchers = (PROTOCOL=TCP) (SERVICE=XEXDB) shared_servers = 4 job_queue_processes = 4 audit_file_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\ADUMP background_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\BDUMP user_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\UDUMP core_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\CDUMP db_name = XE open_cursors = 300 os_authent_prefix = pga_aggregate_target = 268435456 PMON started with pid=2, OS id=2724 PSP0 started with pid=3, OS id=6088 MMAN started with pid=4, OS id=2788 DBW0 started with pid=5, OS id=2376 LGWR started with pid=6, OS id=4352 CKPT started with pid=7, OS id=3628 SMON started with pid=8, OS id=4376 RECO started with pid=9, OS id=5216 CJQ0 started with pid=10, OS id=2940 MMON started with pid=11, OS id=3252 Mon Sep 14 07:18:56 2015 starting up 1 dispatcher(s) for network address '(ADDRESS=(PARTIAL=YES)(PROTOCOL=TCP))'... MMNL started with pid=12, OS id=4620 Mon Sep 14 07:18:56 2015 starting up 4 shared server(s) ... Oracle Data Guard is not available in this edition of Oracle. Mon Sep 14 07:18:56 2015 alter database mount exclusive Mon Sep 14 07:19:00 2015 Setting recovery target incarnation to 2 Mon Sep 14 07:19:00 2015 Successful mount of redo thread 1, with mount id 2771499296 Mon Sep 14 07:19:00 2015 Database mounted in Exclusive Mode Completed: alter database mount exclusive Mon Sep 14 07:19:00 2015 alter database open Mon Sep 14 07:19:01 2015 Errors in file c:\oraclexe\app\oracle\admin\xe\bdump\xe_lgwr_4352.trc: ORA-00322: log 1 of thread 1 is not current copy ORA-00312: online log 1 thread 1: 'C:\ORACLEXE\APP\ORACLE\FLASH_RECOVERY_AREA\XE\ONLINELOG\O1_MF_1_BLOKOKVT_.LOG' Mon Sep 14 07:19:01 2015 Errors in file c:\oraclexe\app\oracle\admin\xe\bdump\xe_lgwr_4352.trc: ORA-00322: log 1 of thread 1 is not current copy ORA-00312: online log 1 thread 1: 'C:\ORACLEXE\APP\ORACLE\FLASH_RECOVERY_AREA\XE\ONLINELOG\O1_MF_1_BLOKOKVT_.LOG' ORA-322 signalled during: alter database open... Mon Sep 14 07:19:04 2015 Starting ORACLE instance (normal) Mon Sep 14 07:34:02 2015 db_recovery_file_dest_size of 10240 MB is 0.98% used. This is a user-specified limit on the amount of space that will be used by this database for recovery-related files, and does not reflect the amount of space available in the underlying filesystem or ASM diskgroup. Dump file c:\oraclexe\app\oracle\admin\xe\bdump\alert_xe.log Mon Sep 14 09:18:43 2015 ORACLE V10.2.0.1.0 - Production vsnsta=0 vsnsql=14 vsnxtr=3 Windows NT Version V6.1 Service Pack 1 CPU : 4 - type 586, 2 Physical Cores Process Affinity : 0x00000000 Memory (Avail/Total): Ph:3173M/3988M, Ph+PgF:7145M/7974M, VA:3972M/4095M Mon Sep 14 09:18:43 2015 Starting ORACLE instance (normal) LICENSE_MAX_SESSION = 0 LICENSE_SESSIONS_WARNING = 0 Picked latch-free SCN scheme 2 Using LOG_ARCHIVE_DEST_10 parameter default value as USE_DB_RECOVERY_FILE_DEST Autotune of undo retention is turned on. IMODE=BR ILAT =10 LICENSE_MAX_USERS = 0 SYS auditing is disabled ksdpec: called for event 13740 prior to event group initialization Starting up ORACLE RDBMS Version: 10.2.0.1.0. System parameters with non-default values: sessions = 49 __shared_pool_size = 201326592 __large_pool_size = 4194304 __java_pool_size = 4194304 __streams_pool_size = 0 spfile = C:\ORACLEXE\APP\ORACLE\PRODUCT\10.2.0\SERVER\DBS\SPFILEXE.ORA sga_target = 805306368 control_files = C:\ORACLEXE\ORADATA\XE\CONTROL.DBF __db_cache_size = 591396864 compatible = 10.2.0.1.0 db_recovery_file_dest = C:\oraclexe\app\oracle\flash_recovery_area db_recovery_file_dest_size= 10737418240 undo_management = AUTO undo_tablespace = UNDO remote_login_passwordfile= EXCLUSIVE dispatchers = (PROTOCOL=TCP) (SERVICE=XEXDB) shared_servers = 4 job_queue_processes = 4 audit_file_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\ADUMP background_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\BDUMP user_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\UDUMP core_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\CDUMP db_name = XE open_cursors = 300 os_authent_prefix = pga_aggregate_target = 268435456 PMON started with pid=2, OS id=2268 PSP0 started with pid=3, OS id=2272 MMAN started with pid=4, OS id=2276 DBW0 started with pid=5, OS id=2280 LGWR started with pid=6, OS id=2284 CKPT started with pid=7, OS id=2288 SMON started with pid=8, OS id=2292 RECO started with pid=9, OS id=2296 CJQ0 started with pid=10, OS id=2300 MMON started with pid=11, OS id=2304 MMNL started with pid=12, OS id=2308 Mon Sep 14 09:18:44 2015 starting up 1 dispatcher(s) for network address '(ADDRESS=(PARTIAL=YES)(PROTOCOL=TCP))'... starting up 4 shared server(s) ... Oracle Data Guard is not available in this edition of Oracle. Mon Sep 14 09:18:44 2015 alter database mount exclusive Mon Sep 14 09:18:50 2015 Setting recovery target incarnation to 2 Mon Sep 14 09:18:53 2015 Successful mount of redo thread 1, with mount id 2771546164 Mon Sep 14 09:18:53 2015 Database mounted in Exclusive Mode Completed: alter database mount exclusive Mon Sep 14 09:18:55 2015 alter database open Mon Sep 14 09:18:57 2015 Errors in file c:\oraclexe\app\oracle\admin\xe\bdump\xe_lgwr_2284.trc: ORA-00322: log 1 of thread 1 is not current copy ORA-00312: online log 1 thread 1: 'C:\ORACLEXE\APP\ORACLE\FLASH_RECOVERY_AREA\XE\ONLINELOG\O1_MF_1_BLOKOKVT_.LOG' Mon Sep 14 09:18:57 2015 Errors in file c:\oraclexe\app\oracle\admin\xe\bdump\xe_lgwr_2284.trc: ORA-00322: log 1 of thread 1 is not current copy ORA-00312: online log 1 thread 1: 'C:\ORACLEXE\APP\ORACLE\FLASH_RECOVERY_AREA\XE\ONLINELOG\O1_MF_1_BLOKOKVT_.LOG' ORA-322 signalled during: alter database open... Mon Sep 14 09:31:22 2015 db_recovery_file_dest_size of 10240 MB is 0.98% used. This is a user-specified limit on the amount of space that will be used by this database for recovery-related files, and does not reflect the amount of space available in the underlying filesystem or ASM diskgroup. Mon Sep 14 10:07:05 2015 Starting ORACLE instance (normal) Shutting down instance: further logons disabled Mon Sep 14 10:12:19 2015 Stopping background process MMNL Mon Sep 14 10:12:19 2015 Stopping background process CJQ0 Mon Sep 14 10:12:20 2015 Stopping background process MMON Mon Sep 14 10:12:21 2015 Shutting down instance (immediate) License high water mark = 1 Mon Sep 14 10:12:21 2015 Stopping Job queue slave processes Mon Sep 14 10:12:21 2015 Job queue slave processes stopped Waiting for dispatcher 'D000' to shutdown All dispatchers and shared servers shutdown Mon Sep 14 10:12:23 2015 alter database close normal ORA-1109 signalled during: alter database close normal... Dump file c:\oraclexe\app\oracle\admin\xe\bdump\alert_xe.log Mon Sep 14 10:12:29 2015 ORACLE V10.2.0.1.0 - Production vsnsta=0 vsnsql=14 vsnxtr=3 Windows NT Version V6.1 Service Pack 1 CPU : 4 - type 586, 2 Physical Cores Process Affinity : 0x00000000 Memory (Avail/Total): Ph:736M/3988M, Ph+PgF:4220M/7974M, VA:3972M/4095M Mon Sep 14 10:12:29 2015 Starting ORACLE instance (normal) LICENSE_MAX_SESSION = 0 LICENSE_SESSIONS_WARNING = 0 Picked latch-free SCN scheme 2 Using LOG_ARCHIVE_DEST_10 parameter default value as USE_DB_RECOVERY_FILE_DEST Autotune of undo retention is turned on. IMODE=BR ILAT =10 LICENSE_MAX_USERS = 0 SYS auditing is disabled ksdpec: called for event 13740 prior to event group initialization Starting up ORACLE RDBMS Version: 10.2.0.1.0. System parameters with non-default values: sessions = 49 __shared_pool_size = 201326592 __large_pool_size = 4194304 __java_pool_size = 4194304 __streams_pool_size = 0 spfile = C:\ORACLEXE\APP\ORACLE\PRODUCT\10.2.0\SERVER\DBS\SPFILEXE.ORA sga_target = 805306368 control_files = C:\ORACLEXE\ORADATA\XE\CONTROL.DBF __db_cache_size = 591396864 compatible = 10.2.0.1.0 db_recovery_file_dest = C:\oraclexe\app\oracle\flash_recovery_area db_recovery_file_dest_size= 10737418240 undo_management = AUTO undo_tablespace = UNDO remote_login_passwordfile= EXCLUSIVE dispatchers = (PROTOCOL=TCP) (SERVICE=XEXDB) shared_servers = 4 job_queue_processes = 4 audit_file_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\ADUMP background_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\BDUMP user_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\UDUMP core_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\CDUMP db_name = XE open_cursors = 300 os_authent_prefix = pga_aggregate_target = 268435456 PMON started with pid=2, OS id=6204 PSP0 started with pid=3, OS id=1012 MMAN started with pid=4, OS id=4244 DBW0 started with pid=5, OS id=1608 LGWR started with pid=6, OS id=1004 CKPT started with pid=7, OS id=5080 SMON started with pid=8, OS id=4292 RECO started with pid=9, OS id=6416 CJQ0 started with pid=10, OS id=3500 MMON started with pid=11, OS id=3232 Mon Sep 14 10:12:30 2015 starting up 1 dispatcher(s) for network address '(ADDRESS=(PARTIAL=YES)(PROTOCOL=TCP))'... MMNL started with pid=12, OS id=5172 Mon Sep 14 10:12:30 2015 starting up 4 shared server(s) ... Oracle Data Guard is not available in this edition of Oracle. Mon Sep 14 10:12:31 2015 alter database mount exclusive Mon Sep 14 10:12:37 2015 Setting recovery target incarnation to 2 Mon Sep 14 10:12:38 2015 Successful mount of redo thread 1, with mount id 2771523281 Mon Sep 14 10:12:38 2015 Database mounted in Exclusive Mode Completed: alter database mount exclusive Mon Sep 14 10:12:38 2015 alter database open Mon Sep 14 10:12:38 2015 Errors in file c:\oraclexe\app\oracle\admin\xe\bdump\xe_lgwr_1004.trc: ORA-00322: log 1 of thread 1 is not current copy ORA-00312: online log 1 thread 1: 'C:\ORACLEXE\APP\ORACLE\FLASH_RECOVERY_AREA\XE\ONLINELOG\O1_MF_1_BLOKOKVT_.LOG' Mon Sep 14 10:12:38 2015 Errors in file c:\oraclexe\app\oracle\admin\xe\bdump\xe_lgwr_1004.trc: ORA-00322: log 1 of thread 1 is not current copy ORA-00312: online log 1 thread 1: 'C:\ORACLEXE\APP\ORACLE\FLASH_RECOVERY_AREA\XE\ONLINELOG\O1_MF_1_BLOKOKVT_.LOG' ORA-322 signalled during: alter database open... Mon Sep 14 10:27:34 2015 db_recovery_file_dest_size of 10240 MB is 0.98% used. This is a user-specified limit on the amount of space that will be used by this database for recovery-related files, and does not reflect the amount of space available in the underlying filesystem or ASM diskgroup. Dump file c:\oraclexe\app\oracle\admin\xe\bdump\alert_xe.log Mon Sep 14 12:01:19 2015 ORACLE V10.2.0.1.0 - Production vsnsta=0 vsnsql=14 vsnxtr=3 Windows NT Version V6.1 Service Pack 1 CPU : 4 - type 586, 2 Physical Cores Process Affinity : 0x00000000 Memory (Avail/Total): Ph:2459M/3988M, Ph+PgF:6454M/7974M, VA:3971M/4095M Mon Sep 14 12:01:19 2015 Starting ORACLE instance (normal) Mon Sep 14 12:01:29 2015 LICENSE_MAX_SESSION = 0 LICENSE_SESSIONS_WARNING = 0 Picked latch-free SCN scheme 2 Using LOG_ARCHIVE_DEST_10 parameter default value as USE_DB_RECOVERY_FILE_DEST Autotune of undo retention is turned on. IMODE=BR ILAT =10 LICENSE_MAX_USERS = 0 SYS auditing is disabled ksdpec: called for event 13740 prior to event group initialization Starting up ORACLE RDBMS Version: 10.2.0.1.0. System parameters with non-default values: sessions = 49 __shared_pool_size = 201326592 __large_pool_size = 4194304 __java_pool_size = 4194304 __streams_pool_size = 0 spfile = C:\ORACLEXE\APP\ORACLE\PRODUCT\10.2.0\SERVER\DBS\SPFILEXE.ORA sga_target = 805306368 control_files = C:\ORACLEXE\ORADATA\XE\CONTROL.DBF __db_cache_size = 591396864 compatible = 10.2.0.1.0 db_recovery_file_dest = C:\oraclexe\app\oracle\flash_recovery_area db_recovery_file_dest_size= 10737418240 undo_management = AUTO undo_tablespace = UNDO remote_login_passwordfile= EXCLUSIVE dispatchers = (PROTOCOL=TCP) (SERVICE=XEXDB) shared_servers = 4 job_queue_processes = 4 audit_file_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\ADUMP background_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\BDUMP user_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\UDUMP core_dump_dest = C:\ORACLEXE\APP\ORACLE\ADMIN\XE\CDUMP db_name = XE open_cursors = 300 os_authent_prefix = pga_aggregate_target = 268435456 PMON started with pid=2, OS id=4740 MMAN started with pid=4, OS id=4748 DBW0 started with pid=5, OS id=4364 LGWR started with pid=6, OS id=4756 CKPT started with pid=7, OS id=4356 SMON started with pid=8, OS id=4372 RECO started with pid=9, OS id=4752 CJQ0 started with pid=10, OS id=4852 MMON started with pid=11, OS id=4348 MMNL started with pid=12, OS id=4360 Mon Sep 14 12:01:41 2015 starting up 1 dispatcher(s) for network address '(ADDRESS=(PARTIAL=YES)(PROTOCOL=TCP))'... starting up 4 shared server(s) ... Oracle Data Guard is not available in this edition of Oracle. PSP0 started with pid=3, OS id=4744 Mon Sep 14 12:01:47 2015 alter database mount exclusive Mon Sep 14 12:01:53 2015 Setting recovery target incarnation to 2 Mon Sep 14 12:01:54 2015 Successful mount of redo thread 1, with mount id 2771557996 Mon Sep 14 12:01:54 2015 Database mounted in Exclusive Mode Completed: alter database mount exclusive Mon Sep 14 12:01:55 2015 alter database open Mon Sep 14 12:01:57 2015 Errors in file c:\oraclexe\app\oracle\admin\xe\bdump\xe_lgwr_4756.trc: ORA-00322: log 1 of thread 1 is not current copy ORA-00312: online log 1 thread 1: 'C:\ORACLEXE\APP\ORACLE\FLASH_RECOVERY_AREA\XE\ONLINELOG\O1_MF_1_BLOKOKVT_.LOG' Mon Sep 14 12:01:57 2015 Errors in file c:\oraclexe\app\oracle\admin\xe\bdump\xe_lgwr_4756.trc: ORA-00322: log 1 of thread 1 is not current copy ORA-00312: online log 1 thread 1: 'C:\ORACLEXE\APP\ORACLE\FLASH_RECOVERY_AREA\XE\ONLINELOG\O1_MF_1_BLOKOKVT_.LOG' ORA-322 signalled during: alter database open... Mon Sep 14 22:02:47 2015 db_recovery_file_dest_size of 10240 MB is 0.98% used. This is a user-specified limit on the amount of space that will be used by this database for recovery-related files, and does not reflect the amount of space available in the underlying filesystem or ASM diskgroup. ... |
| 14.09.2015, 20:24 |
shketok, oerr ora 322 00322, 00000, "log %s of thread %s is not current copy" // *Cause: Check of log file header at database open found that an online // log appears to be an incorrectly restored backup. // *Action: Restore correct file or reset logs. так понятней? Если нет, то идешь к начальнику и говоришь ,что надо бы вам ораклового админа заполучить. ... |
| 15.09.2015, 02:51 |
_примус, честно не понятно. Сам студент. Курсовую задолжал, и вот после лета вылетает такая ошибка. Подскажите как лечить, и я был бы вам благодарен если бы вы писали по простому, что бы даже такой пень как я понял что делать. Благодарю за реакцию и помощь. ... |
| 15.09.2015, 14:23 |
redolog кривой лежит, база не может подняться. Надо либо подложить правильный redo, либо alter database open resetlogs - c вероятной потерей последних транзакций ... |
| 15.09.2015, 14:51 |
Учисьстудентлибо alter database open resetlogs И что, без неполного восстановления пройдет? ... |
| 15.09.2015, 15:05 |
tru55Учисьстудентлибо alter database open resetlogs И что, без неполного восстановления пройдет? Хрен его знает, студента shketokКурсовую задолжал, и вот после лета вылетает такая ошибка. Думаю он оракель на локальном развернул - бэкапов нет, рестора не было - сталбыть базка консистентна но, возможно, слегка поломана. Скажем, место под игрушки чистил - логи удалял :) ... |
| 15.09.2015, 15:12 |
shketok_примус, честно не понятно. Сам студент. Курсовую задолжал, и вот после лета вылетает такая ошибка. Подскажите как лечить, и я был бы вам благодарен если бы вы писали по простому, что бы даже такой пень как я понял что делать. Благодарю за реакцию и помощь. в логгруппе по одному мемберу? если да - open resetlogs. и как повезет :) ... |
| 15.09.2015, 15:18 |
SQL> alter database open resetlogs; SP2-0640: Not connected. В нете ничего не нашел по этой проблеме. Службы запускал, отключал. (OracleXETNSListner, OracleXEClrAgent, OracleServiceXE) Правильный redo понятия не имею где взять. Какфишкаляжет Думаю он оракель на локальном развернул - бэкапов нет, рестора не было - сталбыть базка консистентна но, возможно, слегка поломана. Скажем, место под игрушки чистил - логи удалял :) Все верно, так оно скорее всего и было. Но ьэкапов нет. Рестора не делал. Q.Tarantino в логгруппе по одному мемберу? если да - open resetlogs. и как повезет :) Честно не имею понятия о чем вы. Я слишком плохо ознакомлен с этой темой. Поэтому собственно и просил объяснять проще, как для чайника. ... |
| 15.09.2015, 18:49 |
| 15.09.2015, 21:37 |
| 15.09.2015, 22:39 |
shketok, пробуй Код: sql 1. 2. 3. ... |
| 15.09.2015, 22:49 |
| 15.09.2015, 23:43 |
shketok SQL> alter database open resetlogs; SP2-0640: Not connected. лучше так... Код: plsql 1. 2. 3. ... |
| 16.09.2015, 10:56 |
Q.Tarantinoshketok SQL> alter database open resetlogs; SP2-0640: Not connected. лучше так... Код: plsql 1. 2. 3. Всем огромное спасибо. Проблему решил. После ORA-01139 сделал следующее: sqlplus /nolog conn / as sysdba create spfile from pfile; create pfile from spfile; Добавил в $ORACLE_HOME/dbs/init<SID>.ora строку вида:*._allow_resetlogs_corruption=true startup pfile='init<SID>.ora' mount; recover database until cancel; alter database open resetlogs; Решение нашел в гугле, так понимаю ссылки на форуме на другие источники оставлять нежелательно, поэтому просто скопировал решение проблемы. Еще раз хотел поблагодарить всех кто пытался помочь. Без вас ничего бы не получилось. Дай бог и я когда нибудь смогу так же как вы помогать другим. ... |
| 16.09.2015, 13:23 |
shketokПроблему решил. а теперь лучше всего сделать экспорт данных, создать новую БД и в нее это все залить. ... |
| 16.09.2015, 14:16 |
Добрый день! у нас после отключение электропитании не запустился один сервер. ошибка ora-01033. пытался зарустить через: shu abort startup mount , тут без каких либо ошибок работает alter database open resetlogs; ошибки ora-01194,01110. Не знаю что делать дальше. Дайте советы чтобы исправить ошибку. выложил алерт за сегодня Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. 91. 92. 93. 94. 95. 96. 97. 98. 99. 100. 101. 102. 103. 104. 105. 106. 107. 108. 109. 110. 111. 112. 113. 114. 115. 116. 117. 118. 119. 120. 121. 122. 123. 124. 125. 126. 127. 128. 129. 130. 131. 132. 133. 134. 135. 136. 137. 138. 139. 140. 141. 142. 143. 144. 145. 146. 147. 148. 149. 150. 151. 152. 153. 154. 155. 156. 157. 158. 159. 160. 161. 162. 163. 164. 165. 166. 167. 168. 169. 170. 171. 172. 173. 174. 175. 176. 177. 178. 179. 180. 181. 182. 183. 184. 185. 186. 187. 188. 189. 190. 191. 192. 193. 194. 195. 196. 197. 198. 199. 200. 201. 202. 203. 204. 205. 206. 207. 208. 209. 210. 211. 212. 213. 214. 215. 216. 217. 218. 219. 220. 221. 222. 223. 224. 225. 226. 227. 228. 229. 230. 231. 232. 233. 234. 235. 236. 237. 238. 239. 240. 241. 242. 243. 244. 245. 246. 247. 248. 249. 250. 251. 252. 253. 254. 255. 256. 257. 258. 259. 260. 261. 262. 263. 264. 265. 266. 267. 268. 269. 270. 271. 272. 273. 274. 275. 276. 277. 278. 279. 280. 281. 282. 283. 284. 285. 286. 287. 288. 289. 290. 291. 292. 293. 294. 295. 296. 297. 298. 299. 300. 301. 302. 303. 304. 305. 306. 307. 308. 309. 310. 311. 312. 313. 314. 315. 316. 317. 318. 319. 320. 321. 322. 323. 324. 325. 326. 327. 328. 329. 330. 331. 332. 333. 334. 335. 336. 337. 338. 339. 340. 341. 342. 343. 344. 345. 346. 347. 348. 349. 350. 351. 352. 353. 354. 355. 356. 357. 358. 359. 360. 361. 362. 363. 364. 365. 366. 367. 368. 369. 370. 371. 372. 373. 374. 375. 376. 377. 378. 379. 380. 381. 382. 383. 384. 385. 386. 387. 388. 389. 390. 391. 392. 393. 394. 395. 396. 397. 398. 399. 400. 401. 402. 403. 404. 405. 406. 407. 408. 409. 410. 411. 412. 413. 414. 415. 416. 417. 418. 419. 420. 421. 422. 423. 424. 425. 426. 427. 428. 429. 430. 431. 432. 433. 434. 435. 436. 437. 438. 439. 440. 441. 442. 443. 444. 445. 446. 447. 448. 449. 450. 451. 452. 453. 454. 455. 456. 457. 458. 459. 460. 461. 462. 463. 464. 465. 466. 467. 468. 469. 470. 471. 472. 473. 474. 475. 476. 477. 478. 479. 480. 481. 482. 483. 484. 485. 486. 487. 488. 489. 490. 491. 492. 493. 494. 495. 496. 497. 498. 499. 500. 501. 502. 503. 504. 505. 506. 507. 508. 509. 510. 511. 512. 513. 514. 515. 516. 517. 518. 519. 520. 521. 522. 523. 524. 525. 526. 527. 528. 529. 530. 531. 532. 533. 534. 535. 536. 537. 538. 539. 540. 541. 542. 543. 544. 545. 546. 547. 548. 549. 550. 551. 552. 553. 554. 555. 556. 557. 558. 559. 560. 561. 562. 563. 564. 565. 566. 567. 568. 569. 570. 571. 572. 573. 574. 575. 576. 577. 578. 579. 580. 581. 582. 583. 584. 585. 586. 587. 588. 589. 590. 591. 592. 593. 594. 595. 596. 597. 598. 599. 600. 601. 602. 603. 604. 605. 606. 607. 608. 609. 610. 611. 612. 613. 614. 615. 616. 617. 618. 619. 620. 621. 622. 623. 624. 625. 626. 627. 628. 629. 630. 631. 632. 633. 634. 635. 636. 637. 638. 639. 640. 641. 642. 643. 644. 645. 646. 647. 648. 649. 650. 651. 652. 653. 654. 655. 656. 657. 658. 659. 660. 661. 662. 663. 664. 665. 666. 667. 668. 669. 670. 671. 672. 673. 674. 675. 676. 677. 678. 679. 680. 681. 682. 683. 684. 685. 686. 687. 688. 689. 690. 691. 692. 693. 694. 695. 696. 697. 698. 699. 700. 701. 702. 703. 704. 705. 706. 707. 708. 709. 710. 711. 712. 713. 714. 715. 716. 717. 718. 719. 720. 721. 722. 723. 724. 725. 726. 727. 728. 729. 730. 731. 732. 733. 734. 735. 736. 737. 738. 739. 740. 741. 742. 743. 744. 745. 746. 747. 748. 749. 750. 751. 752. 753. 754. 755. 756. 757. 758. 759. 760. 761. 762. 763. 764. 765. 766. 767. 768. 769. 770. 771. 772. 773. 774. 775. 776. 777. 778. 779. 780. 781. 782. 783. 784. 785. 786. 787. 788. 789. 790. 791. 792. 793. 794. 795. 796. 797. 798. 799. 800. 801. 802. 803. 804. 805. 806. 807. 808. 809. 810. 811. 812. 813. 814. 815. 816. 817. 818. 819. 820. 821. 822. 823. 824. 825. 826. 827. 828. 829. 830. 831. 832. 833. 834. 835. 836. 837. 838. 839. 840. 841. 842. 843. 844. 845. 846. 847. 848. 849. 850. 851. 852. 853. 854. 855. 856. 857. 858. 859. 860. 861. 862. 863. 864. 865. 866. 867. 868. 869. 870. 871. 872. 873. 874. 875. 876. 877. 878. 879. 880. 881. 882. 883. 884. 885. 886. 887. 888. 889. 890. 891. 892. 893. 894. 895. 896. 897. 898. 899. 900. 901. 902. 903. 904. 905. 906. 907. 908. 909. 910. 911. 912. 913. 914. 915. 916. 917. 918. 919. 920. 921. 922. 923. 924. 925. 926. 927. 928. 929. 930. 931. 932. 933. 934. 935. 936. 937. 938. 939. 940. 941. 942. 943. 944. 945. 946. 947. 948. 949. 950. 951. 952. 953. 954. 955. 956. 957. 958. 959. 960. 961. 962. 963. 964. 965. 966. 967. 968. 969. 970. 971. 972. 973. 974. 975. 976. 977. 978. 979. 980. 981. 982. 983. 984. 985. 986. 987. 988. 989. 990. 991. 992. 993. 994. 995. 996. 997. 998. 999. 1000. 1001. 1002. 1003. 1004. 1005. 1006. 1007. 1008. 1009. 1010. 1011. 1012. 1013. 1014. 1015. 1016. 1017. 1018. 1019. 1020. 1021. 1022. 1023. 1024. 1025. 1026. 1027. 1028. 1029. 1030. 1031. 1032. 1033. 1034. 1035. 1036. 1037. 1038. 1039. 1040. 1041. 1042. 1043. 1044. 1045. 1046. 1047. 1048. 1049. 1050. 1051. 1052. 1053. 1054. 1055. 1056. 1057. 1058. 1059. 1060. 1061. 1062. 1063. 1064. 1065. 1066. 1067. 1068. 1069. 1070. 1071. 1072. 1073. 1074. 1075. 1076. 1077. 1078. 1079. 1080. 1081. 1082. 1083. 1084. 1085. 1086. 1087. 1088. 1089. 1090. 1091. 1092. 1093. 1094. 1095. 1096. 1097. 1098. 1099. 1100. 1101. 1102. 1103. 1104. 1105. 1106. 1107. 1108. 1109. 1110. 1111. 1112. 1113. 1114. 1115. 1116. 1117. 1118. 1119. 1120. 1121. 1122. 1123. 1124. 1125. 1126. 1127. 1128. 1129. 1130. 1131. 1132. 1133. 1134. 1135. 1136. 1137. 1138. 1139. 1140. 1141. 1142. 1143. 1144. 1145. 1146. 1147. 1148. 1149. 1150. 1151. 1152. 1153. 1154. 1155. 1156. 1157. 1158. 1159. 1160. 1161. 1162. 1163. 1164. 1165. 1166. 1167. 1168. 1169. 1170. 1171. 1172. 1173. 1174. 1175. 1176. 1177. 1178. 1179. 1180. 1181. 1182. 1183. 1184. 1185. 1186. 1187. 1188. 1189. 1190. 1191. 1192. 1193. 1194. 1195. 1196. 1197. 1198. 1199. 1200. 1201. 1202. 1203. 1204. 1205. 1206. 1207. 1208. 1209. 1210. 1211. 1212. 1213. 1214. 1215. 1216. 1217. 1218. 1219. 1220. 1221. 1222. 1223. 1224. 1225. 1226. 1227. 1228. 1229. 1230. 1231. 1232. 1233. 1234. 1235. 1236. 1237. 1238. 1239. 1240. 1241. 1242. 1243. 1244. 1245. 1246. 1247. 1248. 1249. 1250. 1251. 1252. 1253. 1254. 1255. 1256. 1257. 1258. 1259. 1260. 1261. 1262. 1263. 1264. 1265. 1266. 1267. 1268. 1269. 1270. 1271. 1272. 1273. 1274. 1275. 1276. 1277. 1278. 1279. 1280. 1281. 1282. 1283. 1284. 1285. 1286. 1287. 1288. 1289. 1290. 1291. 1292. 1293. 1294. 1295. 1296. 1297. 1298. 1299. 1300. 1301. 1302. 1303. 1304. 1305. 1306. 1307. 1308. 1309. 1310. 1311. 1312. 1313. 1314. 1315. 1316. 1317. 1318. 1319. 1320. 1321. 1322. 1323. 1324. 1325. 1326. 1327. 1328. 1329. 1330. 1331. 1332. 1333. 1334. 1335. 1336. 1337. 1338. 1339. 1340. 1341. 1342. 1343. 1344. 1345. 1346. 1347. 1348. 1349. 1350. 1351. 1352. 1353. 1354. 1355. 1356. 1357. 1358. 1359. 1360. 1361. 1362. 1363. 1364. 1365. 1366. 1367. 1368. 1369. 1370. 1371. 1372. 1373. 1374. 1375. 1376. 1377. 1378. 1379. 1380. 1381. 1382. 1383. 1384. 1385. 1386. 1387. 1388. 1389. 1390. 1391. 1392. 1393. 1394. 1395. 1396. 1397. 1398. 1399. 1400. 1401. 1402. 1403. 1404. 1405. 1406. 1407. 1408. 1409. 1410. 1411. 1412. 1413. 1414. 1415. 1416. 1417. 1418. 1419. 1420. 1421. 1422. 1423. 1424. 1425. 1426. 1427. 1428. 1429. 1430. 1431. 1432. 1433. 1434. 1435. 1436. 1437. 1438. 1439. 1440. 1441. 1442. 1443. 1444. 1445. 1446. 1447. 1448. 1449. 1450. 1451. 1452. 1453. 1454. 1455. 1456. 1457. 1458. 1459. 1460. 1461. 1462. 1463. 1464. 1465. 1466. 1467. 1468. 1469. 1470. 1471. 1472. 1473. 1474. 1475. 1476. 1477. 1478. 1479. 1480. 1481. 1482. 1483. 1484. 1485. 1486. 1487. 1488. 1489. 1490. 1491. 1492. 1493. 1494. 1495. 1496. 1497. 1498. 1499. 1500. 1501. 1502. 1503. 1504. 1505. 1506. 1507. 1508. 1509. 1510. 1511. 1512. 1513. 1514. 1515. 1516. 1517. 1518. 1519. 1520. 1521. 1522. 1523. 1524. 1525. 1526. 1527. 1528. 1529. 1530. 1531. 1532. 1533. 1534. 1535. 1536. 1537. 1538. 1539. 1540. 1541. 1542. 1543. 1544. 1545. 1546. 1547. 1548. 1549. 1550. 1551. 1552. 1553. 1554. 1555. 1556. 1557. 1558. 1559. 1560. 1561. 1562. 1563. 1564. 1565. 1566. 1567. 1568. 1569. 1570. 1571. 1572. 1573. 1574. 1575. 1576. 1577. 1578. 1579. 1580. 1581. 1582. 1583. 1584. 1585. 1586. 1587. 1588. 1589. 1590. 1591. 1592. 1593. 1594. 1595. 1596. 1597. 1598. 1599. 1600. 1601. 1602. 1603. 1604. 1605. 1606. 1607. 1608. 1609. 1610. 1611. 1612. 1613. 1614. 1615. 1616. 1617. 1618. 1619. 1620. 1621. 1622. 1623. 1624. 1625. 1626. 1627. 1628. 1629. 1630. 1631. 1632. 1633. 1634. 1635. 1636. 1637. 1638. 1639. 1640. 1641. 1642. 1643. 1644. 1645. 1646. 1647. 1648. 1649. 1650. 1651. 1652. 1653. 1654. 1655. 1656. 1657. 1658. 1659. 1660. 1661. 1662. 1663. 1664. 1665. 1666. 1667. 1668. 1669. 1670. 1671. 1672. 1673. 1674. 1675. 1676. 1677. 1678. 1679. 1680. 1681. 1682. 1683. 1684. 1685. 1686. 1687. 1688. 1689. 1690. 1691. 1692. 1693. 1694. 1695. 1696. 1697. 1698. 1699. 1700. 1701. 1702. 1703. 1704. 1705. 1706. 1707. 1708. 1709. 1710. 1711. 1712. 1713. 1714. 1715. 1716. 1717. 1718. 1719. 1720. 1721. 1722. 1723. 1724. 1725. 1726. 1727. 1728. 1729. 1730. 1731. 1732. 1733. 1734. 1735. 1736. 1737. 1738. 1739. 1740. 1741. 1742. 1743. 1744. 1745. 1746. 1747. 1748. 1749. 1750. 1751. 1752. 1753. 1754. 1755. 1756. 1757. 1758. 1759. 1760. 1761. 1762. 1763. 1764. 1765. 1766. 1767. 1768. 1769. 1770. 1771. 1772. 1773. 1774. 1775. 1776. 1777. 1778. 1779. 1780. 1781. 1782. 1783. 1784. 1785. 1786. 1787. 1788. 1789. 1790. 1791. 1792. 1793. 1794. 1795. 1796. 1797. 1798. 1799. 1800. 1801. 1802. 1803. 1804. 1805. 1806. 1807. 1808. 1809. 1810. 1811. 1812. 1813. 1814. 1815. 1816. 1817. 1818. 1819. 1820. 1821. 1822. 1823. 1824. 1825. 1826. 1827. 1828. 1829. 1830. 1831. 1832. 1833. 1834. 1835. 1836. 1837. 1838. 1839. 1840. 1841. 1842. 1843. 1844. 1845. 1846. 1847. 1848. 1849. 1850. 1851. 1852. 1853. 1854. 1855. 1856. 1857. 1858. 1859. 1860. 1861. 1862. 1863. 1864. 1865. 1866. 1867. 1868. 1869. 1870. 1871. 1872. 1873. 1874. 1875. 1876. 1877. 1878. 1879. 1880. 1881. 1882. 1883. 1884. 1885. 1886. 1887. 1888. 1889. 1890. 1891. 1892. 1893. 1894. 1895. 1896. 1897. 1898. 1899. 1900. 1901. 1902. 1903. 1904. 1905. 1906. 1907. 1908. 1909. 1910. 1911. 1912. 1913. 1914. 1915. 1916. 1917. 1918. 1919. 1920. 1921. 1922. 1923. 1924. 1925. 1926. 1927. 1928. 1929. 1930. 1931. 1932. 1933. 1934. 1935. 1936. 1937. 1938. 1939. 1940. 1941. 1942. 1943. 1944. 1945. 1946. 1947. 1948. 1949. 1950. 1951. 1952. 1953. 1954. 1955. 1956. 1957. 1958. 1959. 1960. 1961. 1962. 1963. 1964. 1965. 1966. 1967. 1968. 1969. 1970. 1971. 1972. 1973. 1974. 1975. 1976. 1977. 1978. 1979. 1980. 1981. 1982. 1983. 1984. 1985. 1986. 1987. 1988. 1989. 1990. 1991. 1992. 1993. 1994. 1995. 1996. 1997. 1998. 1999. 2000. 2001. 2002. 2003. 2004. 2005. 2006. 2007. 2008. 2009. 2010. 2011. 2012. 2013. 2014. 2015. 2016. 2017. 2018. 2019. 2020. 2021. 2022. 2023. 2024. 2025. 2026. 2027. 2028. 2029. 2030. 2031. 2032. 2033. 2034. 2035. 2036. 2037. 2038. 2039. 2040. 2041. 2042. 2043. 2044. 2045. 2046. 2047. 2048. 2049. 2050. 2051. 2052. 2053. 2054. 2055. 2056. 2057. 2058. 2059. 2060. 2061. 2062. 2063. 2064. 2065. 2066. 2067. 2068. 2069. 2070. 2071. 2072. 2073. 2074. 2075. 2076. 2077. 2078. 2079. 2080. 2081. 2082. 2083. 2084. 2085. 2086. 2087. 2088. 2089. 2090. 2091. 2092. 2093. 2094. 2095. 2096. 2097. 2098. 2099. 2100. 2101. 2102. 2103. 2104. 2105. 2106. 2107. 2108. 2109. 2110. 2111. 2112. 2113. 2114. 2115. 2116. 2117. 2118. 2119. 2120. 2121. 2122. 2123. 2124. 2125. 2126. 2127. 2128. 2129. 2130. 2131. 2132. 2133. 2134. 2135. 2136. 2137. 2138. 2139. 2140. 2141. 2142. 2143. 2144. 2145. 2146. 2147. 2148. 2149. 2150. 2151. 2152. 2153. 2154. 2155. 2156. 2157. 2158. 2159. 2160. 2161. 2162. 2163. 2164. 2165. 2166. 2167. 2168. 2169. 2170. 2171. 2172. 2173. 2174. 2175. 2176. 2177. 2178. 2179. 2180. 2181. 2182. 2183. 2184. 2185. 2186. 2187. 2188. 2189. 2190. 2191. 2192. 2193. 2194. 2195. 2196. 2197. 2198. 2199. 2200. 2201. 2202. 2203. 2204. 2205. 2206. 2207. 2208. 2209. 2210. 2211. 2212. 2213. 2214. 2215. 2216. 2217. 2218. 2219. 2220. 2221. 2222. 2223. 2224. 2225. 2226. 2227. 2228. 2229. 2230. 2231. 2232. 2233. 2234. 2235. 2236. 2237. 2238. 2239. 2240. 2241. 2242. 2243. 2244. 2245. 2246. 2247. 2248. 2249. 2250. 2251. 2252. 2253. 2254. 2255. 2256. 2257. 2258. 2259. 2260. 2261. 2262. 2263. 2264. 2265. 2266. 2267. 2268. 2269. 2270. 2271. 2272. 2273. 2274. 2275. 2276. 2277. 2278. 2279. 2280. 2281. 2282. 2283. 2284. 2285. 2286. 2287. 2288. 2289. 2290. 2291. 2292. 2293. ... |
| 18.09.2017, 13:27 |
Такие портянки нужно под спойлер убирать.... revizorДобрый день! у нас после отключение электропитании не запустился один сервер. ошибка ora-01033. пытался зарустить через: shu abort startup mount , тут без каких либо ошибок работает alter database open resetlogs; ошибки ora-01194,01110. Не знаю что делать дальше. Дайте советы чтобы исправить ошибку. выложил алерт за сегодня Если хочется выложить много текста... Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. 91. 92. 93. 94. 95. 96. 97. 98. 99. 100. 101. 102. 103. 104. 105. 106. 107. 108. 109. 110. 111. 112. 113. 114. 115. 116. 117. 118. 119. 120. 121. 122. 123. 124. 125. 126. 127. 128. 129. 130. 131. 132. 133. 134. 135. 136. 137. 138. 139. 140. 141. 142. 143. 144. 145. 146. 147. 148. 149. 150. 151. 152. 153. 154. 155. 156. 157. 158. 159. 160. 161. 162. 163. 164. 165. 166. 167. 168. 169. 170. 171. 172. 173. 174. 175. 176. 177. 178. 179. 180. 181. 182. 183. 184. 185. 186. 187. 188. 189. 190. 191. 192. 193. 194. 195. 196. 197. 198. 199. 200. 201. 202. 203. 204. 205. 206. 207. 208. 209. 210. 211. 212. 213. 214. 215. 216. 217. 218. 219. 220. 221. 222. 223. 224. 225. 226. 227. 228. 229. 230. 231. 232. 233. 234. 235. 236. 237. 238. 239. 240. 241. 242. 243. 244. 245. 246. 247. 248. 249. 250. 251. 252. 253. 254. 255. 256. 257. 258. 259. 260. 261. 262. 263. 264. 265. 266. 267. 268. 269. 270. 271. 272. 273. 274. 275. 276. 277. 278. 279. 280. 281. 282. 283. 284. 285. 286. 287. 288. 289. 290. 291. 292. 293. 294. 295. 296. 297. 298. 299. 300. 301. 302. 303. 304. 305. 306. 307. 308. 309. 310. 311. 312. 313. 314. 315. 316. 317. 318. 319. 320. 321. 322. 323. 324. 325. 326. 327. 328. 329. 330. 331. 332. 333. 334. 335. 336. 337. 338. 339. 340. 341. 342. 343. 344. 345. 346. 347. 348. 349. 350. 351. 352. 353. 354. 355. 356. 357. 358. 359. 360. 361. 362. 363. 364. 365. 366. 367. 368. 369. 370. 371. 372. 373. 374. 375. 376. 377. 378. 379. 380. 381. 382. 383. 384. 385. 386. 387. 388. 389. 390. 391. 392. 393. 394. 395. 396. 397. 398. 399. 400. 401. 402. 403. 404. 405. 406. 407. 408. 409. 410. 411. 412. 413. 414. 415. 416. 417. 418. 419. 420. 421. 422. 423. 424. 425. 426. 427. 428. 429. 430. 431. 432. 433. 434. 435. 436. 437. 438. 439. 440. 441. 442. 443. 444. 445. 446. 447. 448. 449. 450. 451. 452. 453. 454. 455. 456. 457. 458. 459. 460. 461. 462. 463. 464. 465. 466. 467. 468. 469. 470. 471. 472. 473. 474. 475. 476. 477. 478. 479. 480. 481. 482. 483. 484. 485. 486. 487. 488. 489. 490. 491. 492. 493. 494. 495. 496. 497. 498. 499. 500. 501. 502. 503. 504. 505. 506. 507. 508. 509. 510. 511. 512. 513. 514. 515. 516. 517. 518. 519. 520. 521. 522. 523. 524. 525. 526. 527. 528. 529. 530. 531. 532. 533. 534. 535. 536. 537. 538. 539. 540. 541. 542. 543. 544. 545. 546. 547. 548. 549. 550. 551. 552. 553. 554. 555. 556. 557. 558. 559. 560. 561. 562. 563. 564. 565. 566. 567. 568. 569. 570. 571. 572. 573. 574. 575. 576. 577. 578. 579. 580. 581. 582. 583. 584. 585. 586. 587. 588. 589. 590. 591. 592. 593. 594. 595. 596. 597. 598. 599. 600. 601. 602. 603. 604. 605. 606. 607. 608. 609. 610. 611. 612. 613. 614. 615. 616. 617. 618. 619. 620. 621. 622. 623. 624. 625. 626. 627. 628. 629. 630. 631. 632. 633. 634. 635. 636. 637. 638. 639. 640. 641. 642. 643. 644. 645. 646. 647. 648. 649. 650. 651. 652. 653. 654. 655. 656. 657. 658. 659. 660. 661. 662. 663. 664. 665. 666. 667. 668. 669. 670. 671. 672. 673. 674. 675. 676. 677. 678. 679. 680. 681. 682. 683. 684. 685. 686. 687. 688. 689. 690. 691. 692. 693. 694. 695. 696. 697. 698. 699. 700. 701. 702. 703. 704. 705. 706. 707. 708. 709. 710. 711. 712. 713. 714. 715. 716. 717. 718. 719. 720. 721. 722. 723. 724. 725. 726. 727. 728. 729. 730. 731. 732. 733. 734. 735. 736. 737. 738. 739. 740. 741. 742. 743. 744. 745. 746. 747. 748. 749. 750. 751. 752. 753. 754. 755. 756. 757. 758. 759. 760. 761. 762. 763. 764. 765. 766. 767. 768. 769. 770. 771. 772. 773. 774. 775. 776. 777. 778. 779. 780. 781. 782. 783. 784. 785. 786. 787. 788. 789. 790. 791. 792. 793. 794. 795. 796. 797. 798. 799. 800. 801. 802. 803. 804. 805. 806. 807. 808. 809. 810. 811. 812. 813. 814. 815. 816. 817. 818. 819. 820. 821. 822. 823. 824. 825. 826. 827. 828. 829. 830. 831. 832. 833. 834. 835. 836. 837. 838. 839. 840. 841. 842. 843. 844. 845. 846. 847. 848. 849. 850. 851. 852. 853. 854. 855. 856. 857. 858. 859. 860. 861. 862. 863. 864. 865. 866. 867. 868. 869. 870. 871. 872. 873. 874. 875. 876. 877. 878. 879. 880. 881. 882. 883. 884. 885. 886. 887. 888. 889. 890. 891. 892. 893. 894. 895. 896. 897. 898. 899. 900. 901. 902. 903. 904. 905. 906. 907. 908. 909. 910. 911. 912. 913. 914. 915. 916. 917. 918. 919. 920. 921. 922. 923. 924. 925. 926. 927. 928. 929. 930. 931. 932. 933. 934. 935. 936. 937. 938. 939. 940. 941. 942. 943. 944. 945. 946. 947. 948. 949. 950. 951. 952. 953. 954. 955. 956. 957. 958. 959. 960. 961. 962. 963. 964. 965. 966. 967. 968. 969. 970. 971. 972. 973. 974. 975. 976. 977. 978. 979. 980. 981. 982. 983. 984. 985. 986. 987. 988. 989. 990. 991. 992. 993. 994. 995. 996. 997. 998. 999. 1000. 1001. 1002. 1003. 1004. 1005. 1006. 1007. 1008. 1009. 1010. 1011. 1012. 1013. 1014. 1015. 1016. 1017. 1018. 1019. 1020. 1021. 1022. 1023. 1024. 1025. 1026. 1027. 1028. 1029. 1030. 1031. 1032. 1033. 1034. 1035. 1036. 1037. 1038. 1039. 1040. 1041. 1042. 1043. 1044. 1045. 1046. 1047. 1048. 1049. 1050. 1051. 1052. 1053. 1054. 1055. 1056. 1057. 1058. 1059. 1060. 1061. 1062. 1063. 1064. 1065. 1066. 1067. 1068. 1069. 1070. 1071. 1072. 1073. 1074. 1075. 1076. 1077. 1078. 1079. 1080. 1081. 1082. 1083. 1084. 1085. 1086. 1087. 1088. 1089. 1090. 1091. 1092. 1093. 1094. 1095. 1096. 1097. 1098. 1099. 1100. 1101. 1102. 1103. 1104. 1105. 1106. 1107. 1108. 1109. 1110. 1111. 1112. 1113. 1114. 1115. 1116. 1117. 1118. 1119. 1120. 1121. 1122. 1123. 1124. 1125. 1126. 1127. 1128. 1129. 1130. 1131. 1132. 1133. 1134. 1135. 1136. 1137. 1138. 1139. 1140. 1141. 1142. 1143. 1144. 1145. 1146. 1147. 1148. 1149. 1150. 1151. 1152. 1153. 1154. 1155. 1156. 1157. 1158. 1159. 1160. 1161. 1162. 1163. 1164. 1165. 1166. 1167. 1168. 1169. 1170. 1171. 1172. 1173. 1174. 1175. 1176. 1177. 1178. 1179. 1180. 1181. 1182. 1183. 1184. 1185. 1186. 1187. 1188. 1189. 1190. 1191. 1192. 1193. 1194. 1195. 1196. 1197. 1198. 1199. 1200. 1201. 1202. 1203. 1204. 1205. 1206. 1207. 1208. 1209. 1210. 1211. 1212. 1213. 1214. 1215. 1216. 1217. 1218. 1219. 1220. 1221. 1222. 1223. 1224. 1225. 1226. 1227. 1228. 1229. 1230. 1231. 1232. 1233. 1234. 1235. 1236. 1237. 1238. 1239. 1240. 1241. 1242. 1243. 1244. 1245. 1246. 1247. 1248. 1249. 1250. 1251. 1252. 1253. 1254. 1255. 1256. 1257. 1258. 1259. 1260. 1261. 1262. 1263. 1264. 1265. 1266. 1267. 1268. 1269. 1270. 1271. 1272. 1273. 1274. 1275. 1276. 1277. 1278. 1279. 1280. 1281. 1282. 1283. 1284. 1285. 1286. 1287. 1288. 1289. 1290. 1291. 1292. 1293. 1294. 1295. 1296. 1297. 1298. 1299. 1300. 1301. 1302. 1303. 1304. 1305. 1306. 1307. 1308. 1309. 1310. 1311. 1312. 1313. 1314. 1315. 1316. 1317. 1318. 1319. 1320. 1321. 1322. 1323. 1324. 1325. 1326. 1327. 1328. 1329. 1330. 1331. 1332. 1333. 1334. 1335. 1336. 1337. 1338. 1339. 1340. 1341. 1342. 1343. 1344. 1345. 1346. 1347. 1348. 1349. 1350. 1351. 1352. 1353. 1354. 1355. 1356. 1357. 1358. 1359. 1360. 1361. 1362. 1363. 1364. 1365. 1366. 1367. 1368. 1369. 1370. 1371. 1372. 1373. 1374. 1375. 1376. 1377. 1378. 1379. 1380. 1381. 1382. 1383. 1384. 1385. 1386. 1387. 1388. 1389. 1390. 1391. 1392. 1393. 1394. 1395. 1396. 1397. 1398. 1399. 1400. 1401. 1402. 1403. 1404. 1405. 1406. 1407. 1408. 1409. 1410. 1411. 1412. 1413. 1414. 1415. 1416. 1417. 1418. 1419. 1420. 1421. 1422. 1423. 1424. 1425. 1426. 1427. 1428. 1429. 1430. 1431. 1432. 1433. 1434. 1435. 1436. 1437. 1438. 1439. 1440. 1441. 1442. 1443. 1444. 1445. 1446. 1447. 1448. 1449. 1450. 1451. 1452. 1453. 1454. 1455. 1456. 1457. 1458. 1459. 1460. 1461. 1462. 1463. 1464. 1465. 1466. 1467. 1468. 1469. 1470. 1471. 1472. 1473. 1474. 1475. 1476. 1477. 1478. 1479. 1480. 1481. 1482. 1483. 1484. 1485. 1486. 1487. 1488. 1489. 1490. 1491. 1492. 1493. 1494. 1495. 1496. 1497. 1498. 1499. 1500. 1501. 1502. 1503. 1504. 1505. 1506. 1507. 1508. 1509. 1510. 1511. 1512. 1513. 1514. 1515. 1516. 1517. 1518. 1519. 1520. 1521. 1522. 1523. 1524. 1525. 1526. 1527. 1528. 1529. 1530. 1531. 1532. 1533. 1534. 1535. 1536. 1537. 1538. 1539. 1540. 1541. 1542. 1543. 1544. 1545. 1546. 1547. 1548. 1549. 1550. 1551. 1552. 1553. 1554. 1555. 1556. 1557. 1558. 1559. 1560. 1561. 1562. 1563. 1564. 1565. 1566. 1567. 1568. 1569. 1570. 1571. 1572. 1573. 1574. 1575. 1576. 1577. 1578. 1579. 1580. 1581. 1582. 1583. 1584. 1585. 1586. 1587. 1588. 1589. 1590. 1591. 1592. 1593. 1594. 1595. 1596. 1597. 1598. 1599. 1600. 1601. 1602. 1603. 1604. 1605. 1606. 1607. 1608. 1609. 1610. 1611. 1612. 1613. 1614. 1615. 1616. 1617. 1618. 1619. 1620. 1621. 1622. 1623. 1624. 1625. 1626. 1627. 1628. 1629. 1630. 1631. 1632. 1633. 1634. 1635. 1636. 1637. 1638. 1639. 1640. 1641. 1642. 1643. 1644. 1645. 1646. 1647. 1648. 1649. 1650. 1651. 1652. 1653. 1654. 1655. 1656. 1657. 1658. 1659. 1660. 1661. 1662. 1663. 1664. 1665. 1666. 1667. 1668. 1669. 1670. 1671. 1672. 1673. 1674. 1675. 1676. 1677. 1678. 1679. 1680. 1681. 1682. 1683. 1684. 1685. 1686. 1687. 1688. 1689. 1690. 1691. 1692. 1693. 1694. 1695. 1696. 1697. 1698. 1699. 1700. 1701. 1702. 1703. 1704. 1705. 1706. 1707. 1708. 1709. 1710. 1711. 1712. 1713. 1714. 1715. 1716. 1717. 1718. 1719. 1720. 1721. 1722. 1723. 1724. 1725. 1726. 1727. 1728. 1729. 1730. 1731. 1732. 1733. 1734. 1735. 1736. 1737. 1738. 1739. 1740. 1741. 1742. 1743. 1744. 1745. 1746. 1747. 1748. 1749. 1750. 1751. 1752. 1753. 1754. 1755. 1756. 1757. 1758. 1759. 1760. 1761. 1762. 1763. 1764. 1765. 1766. 1767. 1768. 1769. 1770. 1771. 1772. 1773. 1774. 1775. 1776. 1777. 1778. 1779. 1780. 1781. 1782. 1783. 1784. 1785. 1786. 1787. 1788. 1789. 1790. 1791. 1792. 1793. 1794. 1795. 1796. 1797. 1798. 1799. 1800. 1801. 1802. 1803. 1804. 1805. 1806. 1807. 1808. 1809. 1810. 1811. 1812. 1813. 1814. 1815. 1816. 1817. 1818. 1819. 1820. 1821. 1822. 1823. 1824. 1825. 1826. 1827. 1828. 1829. 1830. 1831. 1832. 1833. 1834. 1835. 1836. 1837. 1838. 1839. 1840. 1841. 1842. 1843. 1844. 1845. 1846. 1847. 1848. 1849. 1850. 1851. 1852. 1853. 1854. 1855. 1856. 1857. 1858. 1859. 1860. 1861. 1862. 1863. 1864. 1865. 1866. 1867. 1868. 1869. 1870. 1871. 1872. 1873. 1874. 1875. 1876. 1877. 1878. 1879. 1880. 1881. 1882. 1883. 1884. 1885. 1886. 1887. 1888. 1889. 1890. 1891. 1892. 1893. 1894. 1895. 1896. 1897. 1898. 1899. 1900. 1901. 1902. 1903. 1904. 1905. 1906. 1907. 1908. 1909. 1910. 1911. 1912. 1913. 1914. 1915. 1916. 1917. 1918. 1919. 1920. 1921. 1922. 1923. 1924. 1925. 1926. 1927. 1928. 1929. 1930. 1931. 1932. 1933. 1934. 1935. 1936. 1937. 1938. 1939. 1940. 1941. 1942. 1943. 1944. 1945. 1946. 1947. 1948. 1949. 1950. 1951. 1952. 1953. 1954. 1955. 1956. 1957. 1958. 1959. 1960. 1961. 1962. 1963. 1964. 1965. 1966. 1967. 1968. 1969. 1970. 1971. 1972. 1973. 1974. 1975. 1976. 1977. 1978. 1979. 1980. 1981. 1982. 1983. 1984. 1985. 1986. 1987. 1988. 1989. 1990. 1991. 1992. 1993. 1994. 1995. 1996. 1997. 1998. 1999. 2000. 2001. 2002. 2003. 2004. 2005. 2006. 2007. 2008. 2009. 2010. 2011. 2012. 2013. 2014. 2015. 2016. 2017. 2018. 2019. 2020. 2021. 2022. 2023. 2024. 2025. 2026. 2027. 2028. 2029. 2030. 2031. 2032. 2033. 2034. 2035. 2036. 2037. 2038. 2039. 2040. 2041. 2042. 2043. 2044. 2045. 2046. 2047. 2048. 2049. 2050. 2051. 2052. 2053. 2054. 2055. 2056. 2057. 2058. 2059. 2060. 2061. 2062. 2063. 2064. 2065. 2066. 2067. 2068. 2069. 2070. 2071. 2072. 2073. 2074. 2075. 2076. 2077. 2078. 2079. 2080. 2081. 2082. 2083. 2084. 2085. 2086. 2087. 2088. 2089. 2090. 2091. 2092. 2093. 2094. 2095. 2096. 2097. 2098. 2099. 2100. 2101. 2102. 2103. 2104. 2105. 2106. 2107. 2108. 2109. 2110. 2111. 2112. 2113. 2114. 2115. 2116. 2117. 2118. 2119. 2120. 2121. 2122. 2123. 2124. 2125. 2126. 2127. 2128. 2129. 2130. 2131. 2132. 2133. 2134. 2135. 2136. 2137. 2138. 2139. 2140. 2141. 2142. 2143. 2144. 2145. 2146. 2147. 2148. 2149. 2150. 2151. 2152. 2153. 2154. 2155. 2156. 2157. 2158. 2159. 2160. 2161. 2162. 2163. 2164. 2165. 2166. 2167. 2168. 2169. 2170. 2171. 2172. 2173. 2174. 2175. 2176. 2177. 2178. 2179. 2180. 2181. 2182. 2183. 2184. 2185. 2186. 2187. 2188. 2189. 2190. 2191. 2192. 2193. 2194. 2195. 2196. 2197. 2198. 2199. 2200. 2201. 2202. 2203. 2204. 2205. 2206. 2207. 2208. 2209. 2210. 2211. 2212. 2213. 2214. 2215. 2216. 2217. 2218. 2219. 2220. 2221. 2222. 2223. 2224. 2225. 2226. 2227. 2228. 2229. 2230. 2231. 2232. 2233. 2234. 2235. 2236. 2237. 2238. 2239. 2240. 2241. 2242. 2243. 2244. 2245. 2246. 2247. 2248. 2249. 2250. 2251. 2252. 2253. 2254. 2255. 2256. 2257. 2258. 2259. 2260. 2261. 2262. 2263. 2264. 2265. 2266. 2267. 2268. 2269. 2270. 2271. 2272. 2273. 2274. 2275. 2276. 2277. 2278. 2279. 2280. 2281. 2282. 2283. 2284. 2285. 2286. 2287. 2288. 2289. 2290. 2291. 2292. 2293. ... |
| 18.09.2017, 13:31 |
ORA-01033 oracle initialization or shutdown in progress
Добрый Э - Эх, спасибо за совет. С утра не могу решить проблему и торопясь закинул в таком виде. ... |
| 18.09.2017, 13:40 |
revizor, OER 7451 in Load Indicator : Error Code = OSD-04500: задан недопустимый параметр ! ... |
| 18.09.2017, 13:54 |
archlog, а как должно быть? ... |
| 18.09.2017, 14:07 |
revizorarchlog, а как должно быть?должно быть: Congrats! задан допустимый параметр ! ... |
| 18.09.2017, 14:09 |
--Eugene--, но как сделать чтобы было Задано допустимый параметр? Спрашиваю от не знания решение этой проблемы. ... |
| 18.09.2017, 14:13 |
revizor, наймите специалиста - так однозначно будет проще. Или вы как себе представляете помощь? Угадать какой из параметров у вас установлен не корректно?!?! ... |
| 18.09.2017, 14:56 |
Самое интересное здесь : Код: plaintext 1. 2. 3. 4. 5. (ORA-214 значит 00214, 00000, "control file '%s' version %s inconsistent with file '%s' version %s") Файлы на диске повреждены, надо восстанавливать с резервной копии. Можно пробовать упражнения с _allow_resetlogs_corruption (ищи на форуме), но не факт, что закончиться успешно. Чтобы такого не происходило в будущем надо использовать серверные диски: с выключенным кешем на запись, RAID-контроллеры c BBU/Flash+Supercap или SSD с PLP (power loss protection). ... |
| 18.09.2017, 15:52 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1885231]: |
182ms |
54ms |
| others: | 240ms |
| total: | 522ms |
