Отключение диска из дисковой группы
Добрый день. У меня есть дисковая группа в ASM, состоящая из 2 дисков (избыточность NORMAL). С периодичностью 1 раз в 2-3 недели из данной группы отключается диск (переходит в режим offline). При этом диск не битый и он не отключается физически от СХД. ОС: Red Hat Enterprise Linux Server release 6.6 (Santiago) 2.6.32 504.23.4.el6.x86_64 (64-bit) БД: Oracle Database 11g Enterprise Edition Release 11.2.0.4.0 - 64bit Production ASM: 11.2.0.4.0 Логи прилагаются. Лог БДORA-27061: waiting for async I/Os failed Linux-x86_64 Error: 5: Input/output error Additional information: -1 Additional information: 49152 WARNING: failed to write mirror side 2 of virtual extent 7501 logical extent 1 of file 275 in group 2 on disk 2 allocation unit 1067203 NOTE: process _dbw0_edw (16222) initiating offline of disk 2.3915945088 (FLASHDG_0002) with mask 0x7e in group 2 Sun Nov 05 04:43:56 2017 WARNING: Write Failed. group:2 disk:2 AU:144100 offset:574976 size:473600 WARNING: Write Failed. group:2 disk:2 AU:144101 offset:0 size:574976 WARNING: Write Failed. group:2 disk:2 AU:144101 offset:574976 size:473600 NOTE: Suppress further IO Write errors on group:2 disk:2 Errors in file /opt/oracle/diag/rdbms/edw/EDW/trace/EDW_lgwr_16224.trc: ORA-15081: failed to submit an I/O operation to a disk WARNING: failed to write mirror side 2 of virtual extent 813 logical extent 1 of file 261 in group 2 on disk 2 allocation unit 144101 Лог ASMSun Nov 05 04:43:56 2017 NOTE: process _user21308_+asm (21308) initiating offline of disk 2.3915945088 (FLASHDG_0002) with mask 0x7e in group 2 NOTE: checking PST: grp = 2 Sun Nov 05 04:43:56 2017 GMON checking disk modes for group 2 at 63 for pid 22, osid 21308 NOTE: checking PST for grp 2 done. NOTE: sending set offline flag message 1014749468 to 1 disk(s) in group 2 WARNING: Disk FLASHDG_0002 in mode 0x7f is now being offlined NOTE: initiating PST update: grp = 2, dsk = 2/0xe9689480, mask = 0x6a, op = clear GMON updating disk modes for group 2 at 64 for pid 22, osid 21308 NOTE: group FLASHDG: updated PST location: disk 0001 (PST copy 0) NOTE: PST update grp = 2 completed successfully NOTE: initiating PST update: grp = 2, dsk = 2/0xe9689480, mask = 0x7e, op = clear GMON updating disk modes for group 2 at 65 for pid 22, osid 21308 NOTE: group FLASHDG: updated PST location: disk 0001 (PST copy 0) NOTE: cache closing disk 2 of grp 2: FLASHDG_0002 NOTE: PST update grp = 2 completed successfully Sun Nov 05 04:44:48 2017 WARNING: PST-initiated drop of 1 disk(s) in group 2(.3153618477)) SQL> alter diskgroup FLASHDG drop disk FLASHDG_0002 force /* ASM SERVER */ NOTE: requesting all-instance membership refresh for group=2 Sun Nov 05 04:44:49 2017 GMON updating for reconfiguration, group 2 at 66 for pid 24, osid 25213 NOTE: cache closing disk 2 of grp 2: (not open) FLASHDG_0002 NOTE: group FLASHDG: updated PST location: disk 0001 (PST copy 0) NOTE: group 2 PST updated. Sun Nov 05 04:44:49 2017 NOTE: membership refresh pending for group 2/0xbbf8662d (FLASHDG) GMON querying group 2 at 67 for pid 13, osid 4454 NOTE: cache closing disk 2 of grp 2: (not open) _DROPPED_0002_FLASHDG SUCCESS: refreshed membership for 2/0xbbf8662d (FLASHDG) NOTE: starting rebalance of group 2/0xbbf8662d (FLASHDG) at power 1 SUCCESS: alter diskgroup FLASHDG drop disk FLASHDG_0002 force /* ASM SERVER */ SUCCESS: PST-initiated drop disk in group 2(3153618477)) Starting background process ARB0 Sun Nov 05 04:44:52 2017 ARB0 started with pid=25, OS id=25233 NOTE: assigning ARB0 to group 2/0xbbf8662d (FLASHDG) with 1 parallel I/O cellip.ora not found. NOTE: Attempting voting file refresh on diskgroup FLASHDG Sun Nov 05 04:45:16 2017 NOTE: Rebalance has restored redundancy for any existing control file or redo log in disk group FLASHDG Sun Nov 05 04:59:23 2017 NOTE: requesting all-instance membership refresh for group=2 Sun Nov 05 04:59:27 2017 GMON updating for reconfiguration, group 2 at 68 for pid 23, osid 26338 NOTE: cache closing disk 2 of grp 2: (not open) _DROPPED_0002_FLASHDG NOTE: group 2 PST updated. WARNING: offline disk number 2 has references (1105446 AUs) Sun Nov 05 04:59:27 2017 NOTE: membership refresh pending for group 2/0xbbf8662d (FLASHDG) GMON querying group 2 at 69 for pid 13, osid 4454 NOTE: cache closing disk 2 of grp 2: (not open) _DROPPED_0002_FLASHDG SUCCESS: refreshed membership for 2/0xbbf8662d (FLASHDG) NOTE: Attempting voting file refresh on diskgroup FLASHDG Sun Nov 05 05:03:03 2017 NOTE: stopping process ARB0 SUCCESS: rebalance completed for group 2/0xbbf8662d (FLASHDG) Лог сервераNov 5 03:06:01 bigoak rsyslogd: [origin software="rsyslogd" swVersion="5.8.10" x-pid="2777" x-info=" http://www.rsyslog.com%22%5D]http://www.rsyslog.com"] rsyslogd was HUPed Nov 5 03:06:50 bigoak rhsmd: In order for Subscription Manager to provide your system with updates, your system must be registered with the Customer Portal. Please enter your Red Hat login to ensure your system is up-to-date. Nov 5 04:43:56 bigoak kernel: mtip32xx 0000:05:00.0: 69 command(s) timed out: tagmap [0000000000000000 FFFFFFFFFFFFFFFE ] Nov 5 04:44:01 bigoak kernel: mtip32xx 0000:04:00.0: 1 command(s) timed out: tagmap [0000000000000000 0000000000200000 ] Заранее благодарю за помощь. ... |
| 07.11.2017, 12:04:30 |
Было нечто подобное, только диск отваливался из состава RAIDa. Тоже долго голову ломали... Помогло обновление прошивки самого диска ... |
| 07.11.2017, 16:16:09 |
start [/forum/topic.php?fid=52&gotonew=1&tid=1884956]: |
44ms |
| others: | 204ms |
| total: | 322ms |
